Sony KDL-46S2530 Sound & No Picture.
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    hi there guys got a Sony KDL-46S2530 which has sound and no picture. i have tested the power board and the volatges going to the main board and inverter and they are as follows if anyone knows what the problem could be ?
    Power Board To Inverter :
    GND
    POWER ON - 3.33V
    PFC DET - 0.01V
    RELY ON - 3.34V
    GND
    GND
    GND
    GND
    18V - 18.12V
    18V - 18.12V
    18V - 18.12V
    18V - 18.12V
    Power Board To AV Board :
    UNREG15V - 16.32V
    UNREG15V - 16.32V
    AVGND
    AVGND
    BY3-3V - 3.35V
    GND
    UNREG10.5V - 12.66V
    UNREG10.5V - 12.66V
    GND
    GND
    VNREG33V - 37.7V
    GND
    REG18V - 18.1V
    REG18V - 18.1V
    If anyone could help me out on this one
  • tonyuk
    • Feb 2014
    • 238
    Re: Sony KDL-46S2530 Sound & No Picture.
    allways helps if you can post up some pics of the boards
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      if you need any info off the boards just let me know cheers.
        Any LED blinking code?
        Pictures of the inverter boards with covers removed and pictures of the labels on the inverter board connectors.
        Service manuals:
        http://elektrotanya.com/?q=showresul...oria=&kat2=all
        • Mikeyboy2007
          • Mar 2013
          • 745
          • Scotland
          no blinking LED code, could it be a problem with inverters though as i get backlights come on, just no picture ?
          • truep
            • Aug 2010
            • 373
            Since the backlights are on, it's probably a TCON issue. Check the fuse on the TCON. Also check that there is voltage at the fuse.
            • Mikeyboy2007
              • Mar 2013
              • 745
              • Scotland
              sorry truep how do i go about doing that ?
                Take good clear pictures of the T-CON board, right now it is not clear enough to see the fuse.
                BTW "i get backlights come on" that was another missing clue.
                • Mikeyboy2007
                  • Mar 2013
                  • 745
                  • Scotland
                  sorry Budm your right, should mentioned that from the start, camera is poor quality so got exact same board image from Google images.
                  • Mikeyboy2007
                    • Mar 2013
                    • 745
                    • Scotland
                    anyone ??
                      check the fuse - little green device marked "P".
                      • Mikeyboy2007
                        • Mar 2013
                        • 745
                        • Scotland
                        Tom checked that and it read -660
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          when the sets switched on what voltage do you get to each side of the fuse.
                          • Mikeyboy2007
                            • Mar 2013
                            • 745
                            • Scotland
                            what do i switch it to on the multimeter is it 20V or the fuse symbol ?
                              20V DC, red probe one end, black probe on chassis, note reading down, then switch red probe to other end and note reading down again.
                              • Mikeyboy2007
                                • Mar 2013
                                • 745
                                • Scotland
                                jumping between 0.44v - 0.48v on one side and other side is solid at 4.99v
                                  Replace the fuse. It is blown and probably causing your fault.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    fuse is open circuit then there may be a test you can do to see if theres a short on the board lets see what one of the others members say.
                                    • Mikeyboy2007
                                      • Mar 2013
                                      • 745
                                      • Scotland
                                      will i replace fuse or not ? bit confused.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        yes try it if you have a spare one of the correct rating thats what i would do at worst i guess it will blow again or work perfectly ok.
                                        • DKWS89
                                          Sony XBR 49x900E - Sound and backlight on but no picture
                                          by DKWS89
                                          Hey Guys,
                                          So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                                          All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                                          12-14-2023, 04:30 PM
                                        • KYBOSH
                                          Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
                                          by KYBOSH
                                          Previous owner said TV just went blank one day.
                                          They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
                                          Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
                                          The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
                                          There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
                                          I just downloaded the Sony KD-75X7800F Service Manual and...
                                          11-19-2024, 10:12 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • ronni
                                          Sony KD-43XE8005 with sound, backlight, no picture
                                          by ronni
                                          I have a Sony KD-43XE8005 with no picture on the TV when powered on. Audio and backlight work ok when powering on. Solid white indication light showing on front of tv bezel.
                                          When removing the left hand ribbon cable from the T-con board, a white image is displayed on that half of the screen and a black screen is shown on the right. If I gently rub the ribbon cable on the right an image or purple black bars appear. The cable doesnt appear damaged, and if swapped with the other ribbon cable the same flickering symptoms can be seen.
                                          Removing the LVDS cable results in...
                                          12-01-2022, 08:44 AM
