TCL 65S450F no logo, bleeping sounds?
This topic has been answered.
You can not trust amazon ratings, they gave this one 4 1/2: https://www.amazon.com/TCL-65S450F-C...0C1HZX7M1?th=1 -
Try doing a reset via recovery.
How to get into Recovery.
1. To do this, turn off the TV using the remote control, press and hold the power button (on the back right of the TV), after 7 seconds the white LED will start blinking quickly, release the button and wait another 20 seconds, recovery mode should load.
2. Unplug from the socket and hold down the button. Plug in. Do not release the button for 30-40 seconds. Naturally, no flash drives, the ports are empty.Last edited by lotas; 08-09-2024, 05:43 AM.Leave a comment:
You probably already tried simple reset, unplug tv hold power button down if there is one for 30 seconds, wait a minute and try it. Bad firmware sounds very possible, It seems like nobody at tcl has a clue, selling a tv that immediately cries for a firmware update before people even have a chance to see if the latest update is a good one, I always try to research updates to see if the latest update is good and won't mess the tv up or rob it of any functionality like they pull sometimes.Last edited by nomoresonys; 08-09-2024, 05:21 AM.Leave a comment:
I don't think there is anything wrong with the panel. It's the firmware that's buggered. Very poor designed. Even how it's mounted to a wall mount. Good thing the TV doesn't weigh anything. I think it is so light, you take a tube of liquid nails and just glue it to the wall. Save the extra $$$ and no TV wall mount required!
EDIT:
I had to come back and edit this. There are further savings to be had! Skip the tube of liquid nails and put a couple of strips of double sided tape. It's good enough!That reminded me of the time I used velcro for a 32 inch tv. A couple days later I hear the velcro letting loose, started for it but too late crashed to the floor shattered. Luckily it was just a storm tv that already had a line panel fault, I think the velcro would have been ok but I didn't use enough.
Lol, I didn't thing you would buy a tcl on purpose, I really really don't trust tcl or hisense and not samsung anymore.Leave a comment:
The wife works for Amazon, and I used to. They will take it back you just need to escalate it or talk to someone else because they will. Each time you connect to their service department you generally will get a different person. Just have them retry it because it obviously needs to go back.
I don't think replacing the main board will work.. that's my opinion because I've had a couple where I disc one ribbon from TCON, or if it was all in one and I'd get half a picture. Also, most of them had sound and responded to remote clicks and would hear beeps or whatever.
I never did replace a main board though. But tape method sometimes worked so I just called it panel a d moved on.
EDIT:
I had to come back and edit this. There are further savings to be had! Skip the tube of liquid nails and put a couple of strips of double sided tape. It's good enough!Last edited by CapLeaker; 08-09-2024, 04:30 AM.Leave a comment:
βββLeave a comment:
Well that's f@#%ed up, maybe try to contact someone higher up the food chain at amazon, seems like they should make it right.Leave a comment:
EazyBone
i haven't had any experience with TCL. It's a brand that isn't much around in my neck of the woods. If it would have been me, I wouldn't have bought this piece of sh*t!CAD$500 for 65β what did he expect. So TCL sez send it back to Amazon. Amazon sez send it back to TCL. What a bunch of π€‘.
At first I thought it's in a boot loop, but no it isn't. The bleeping sounds are from the Ethernet cable plugged in, connecting every 10 to 15 seconds.
Shopjmmy has the 65S450G version main boards, but this one is an 65S450F version. On top of that there are v.1 and a v.2 of the G revision board. The layout is exact the same.
I think the flash went corrupt on it, but without a working dump, there is not much of a chance. I tried to DL firmware from Roku, but it wants some Roku and a serial number. The serial isnβt t bad, but how do I get that darn Roku number, if that stupid thing doesn't want to turn on?. Frustrating.
Definitely send it back. The flashing from the led means it's looking for a internet connection (I know you said you Ethernet it) but generally happens to every TCL I get home, flashes until connected to Internet.
I have also had several TCLs give blank white screen, generally newer ones 2022 and above and it was always a panel short. I pick them up thinking backlights potentially but literally every one has a panel short. This TV doesn't bootloop, generally the Google ones only do. This is Roku right?
So yes, this brand does this now for some reason. TCL before like 2021 doesn't do this almost ever. With my limited experience that is, I think I've had 10 or so of these white screen TCLs. Some I could get tape method to work, most wouldn't even do that.
Several people I got them from had them replaced by warranty and then gave to me. So they are dying within 6 months.
Edit, the newer Hisense also does this.Last edited by EazyBone; 08-08-2024, 04:38 PM.Leave a comment:
Got a brand spankin' new TCL 65S450F here. Plugged the TV in and it booted up and wanted a firmware update right away. O.k. I guess it did that or not... I got no forking clue. Came back in 10 mins later and the screen is black, backlights on. The Standby light is blinking and every 10 to 15 seconds makes bleeping noises. That's all she does. Tried a factory reset and that must work as I can adjust the volume of the bleeping and it returns to factory volume afterwards. Also tried big black button with the circle right button on the remote and no go.
EDIT: No bootloop the bleeping sounds come with ethernet connected.
Before I send it back... anyone has an ideais going on or anyone ran into a similar issue with this TV brand?
by VerlengsnoerHi all,
at firs, i hope this is the right place to post my question.
Im looking for a tool to change the bios logo.
everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
i know that HP has a build in option to change the splash logo.
but i want to change the manufacturer logo to an own logo.
I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
...10-28-2022, 09:52 AM -
by EchooFujitsu D757 sff desktop pc with company logo and it doesn't work to restore the factory logo with UefiModL tool. I need to restore many of these machines to the factory Fujitsu boot logo! Does anyone know a solution?11-25-2024, 01:54 AM
by smartyCan anyone identify logo shown below?
The logo I showed can be found on the PCB's of laptops NP530U3B, NP530U3C, NP540U3B, NP540U3C, etc.
I assume this is a logo of one of the PCB's manufacturers, but I'm not sure.
Neither ChatGPT nor Copilot know the correct answer.
TIA1 Photo -
by q2v5Lenovo T480s
Model 20L8-S3TE00
Board ET481-U10
Chip MX25L12873F
Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...-
Channel: BIOS Requests ONLY!
by p.puhakkaHello forum!
I have received a lot of help here, regarding bios modding. Very thankful!
Now I have a lot of Fujitsu K557 desktops, and those have custom bios logo/custom splash screen, and I need to change them to the original Fujitsu logo.
I am looking for the easiest way, because I have about 40pcs of them, and I think there is some "official" way to do this.
I have tried a lot of Fujitsu tools, which can inject the logo to the bios file, but no luck.
Any suggestions? Thanks! - Loading...
