TCL 65S450F no logo, bleeping sounds?
This topic has been answered.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8286
    Got a brand spankin' new TCL 65S450F here. Plugged the TV in and it booted up and wanted a firmware update right away. O.k. I guess it did that or not... I got no forking clue. Came back in 10 mins later and the screen is black, backlights on. The Standby light is blinking and every 10 to 15 seconds makes bleeping noises. That's all she does. Tried a factory reset and that must work as I can adjust the volume of the bleeping and it returns to factory volume afterwards. Also tried big black button with the circle right button on the remote and no go.
    EDIT: No bootloop the bleeping sounds come with ethernet connected.
    Before I send it back... anyone has an idea is going on or anyone ran into a similar issue with this TV brand?
  • Answer selected by CapLeaker at 09-17-2024, 01:31 PM.
    CapLeaker
    Leaking Member
    • Dec 2014
    • 8286
    Finally this TV is fixed. Got a new main board, chucked that in, turned the TV on and SUCCESS!
    • EazyBone
      • Jun 2023
      • 1351
      • United states
      Definitely send it back. The flashing from the led means it's looking for a internet connection (I know you said you Ethernet it) but generally happens to every TCL I get home, flashes until connected to Internet.
      I have also had several TCLs give blank white screen, generally newer ones 2022 and above and it was always a panel short. I pick them up thinking backlights potentially but literally every one has a panel short. This TV doesn't bootloop, generally the Google ones only do. This is Roku right?
      So yes, this brand does this now for some reason. TCL before like 2021 doesn't do this almost ever. With my limited experience that is, I think I've had 10 or so of these white screen TCLs. Some I could get tape method to work, most wouldn't even do that.
      Several people I got them from had them replaced by warranty and then gave to me. So they are dying within 6 months.
      Edit, the newer Hisense also does this.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8286
        EazyBone
        i haven't had any experience with TCL. It's a brand that isn't much around in my neck of the woods. If it would have been me, I wouldn't have bought this piece of sh*t! CAD$500 for 65” what did he expect. So TCL sez send it back to Amazon. Amazon sez send it back to TCL. What a bunch of 🤡.
        At first I thought it's in a boot loop, but no it isn't. The bleeping sounds are from the Ethernet cable plugged in, connecting every 10 to 15 seconds.
        Shopjmmy has the 65S450G version main boards, but this one is an 65S450F version. On top of that there are v.1 and a v.2 of the G revision board. The layout is exact the same.
        I think the flash went corrupt on it, but without a working dump, there is not much of a chance. I tried to DL firmware from Roku, but it wants some Roku and a serial number. The serial isn’t t bad, but how do I get that darn Roku number, if that stupid thing doesn't want to turn on? . Frustrating.
        • nomoresonys
          • 12216
          • U.S.
          Well that's f@#%ed up, maybe try to contact someone higher up the food chain at amazon, seems like they should make it right.
          • EazyBone
            • Jun 2023
            • 1351
            • United states
            The wife works for Amazon, and I used to. They will take it back you just need to escalate it or talk to someone else because they will. Each time you connect to their service department you generally will get a different person. Just have them retry it because it obviously needs to go back.
            I don't think replacing the main board will work.. that's my opinion because I've had a couple where I disc one ribbon from TCON, or if it was all in one and I'd get half a picture. Also, most of them had sound and responded to remote clicks and would hear beeps or whatever.
            I never did replace a main board though. But tape method sometimes worked so I just called it panel a d moved on.
            • nomoresonys
              • 12216
              • U.S.
              Yep that's it "escalating"
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8286
                It is fuxed up all right. I am not getting too much involved with it. Some one higher up ordered this piece of sh*t and bypassed me, they can deal with it too. I just never seen something as poor made than this thing from the user manual that doesn't even tell you how to do a reset, to a TV that dies after it does a firmware upgrade by itself!
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8286
                  I don't think there is anything wrong with the panel. It's the firmware that's buggered. Very poor designed. Even how it's mounted to a wall mount. Good thing the TV doesn't weigh anything. I think it is so light, you take a tube of liquid nails and just glue it to the wall. Save the extra $$$ and no TV wall mount required!
                  EDIT:
                  I had to come back and edit this. There are further savings to be had! Skip the tube of liquid nails and put a couple of strips of double sided tape. It's good enough!
                  • nomoresonys
                    • 12216
                    • U.S.
                    Lol, I didn't thing you would buy a tcl on purpose, I really really don't trust tcl or hisense and not samsung anymore.
                    • nomoresonys
                      • 12216
                      • U.S.
                      EDIT:
                      I would go for bubble gum. That reminded me of the time I used velcro for a 32 inch tv. A couple days later I hear the velcro letting loose, started for it but too late crashed to the floor shattered. Luckily it was just a storm tv that already had a line panel fault, I think the velcro would have been ok but I didn't use enough.
                      • nomoresonys
                        • 12216
                        • U.S.
                        You probably already tried simple reset, unplug tv hold power button down if there is one for 30 seconds, wait a minute and try it. Bad firmware sounds very possible, It seems like nobody at tcl has a clue, selling a tv that immediately cries for a firmware update before people even have a chance to see if the latest update is a good one, I always try to research updates to see if the latest update is good and won't mess the tv up or rob it of any functionality like they pull sometimes.
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8286
                          I thought about that Velcro idea, but it's more expensive than the double sided sticky tape. Bubble gum, or double sided tape is about the same thing. lol. Yes, I did try that reset method and it does it, but still same thing. I left the TV unplugged yesterday when I left. I am going there again in the afternoon and plug it back in. I don't have any hopes for it, besides manually flashing it somehow.
                          • lotas
                            • Jan 2016
                            • 4708
                            • Russia
                            Try doing a reset via recovery.
                            How to get into Recovery.
                            1. To do this, turn off the TV using the remote control, press and hold the power button (on the back right of the TV), after 7 seconds the white LED will start blinking quickly, release the button and wait another 20 seconds, recovery mode should load.
                            2. Unplug from the socket and hold down the button. Plug in. Do not release the button for 30-40 seconds. Naturally, no flash drives, the ports are empty.
                            • nomoresonys
                              • 12216
                              • U.S.
                              You can not trust amazon ratings, they gave this one 4 1/2: https://www.amazon.com/TCL-65S450F-C...0C1HZX7M1?th=1
                              • nomoresonys
                                • 12216
                                • U.S.
                                Don't know if this is just their hype or what, it says contact us to get a repair manual or sum such: https://support.tcl.com/us/self-repair-options
                                • nomoresonys
                                  • 12216
                                  • U.S.
                                  Not sure if this is fire os or roku, the one in post # 14 appears to be fire os.
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 8286
                                    This TCL has the power button in the middle on the bottom. I tried your suggestion #1 , but I do not get to the fast blinking LED. Suggestion #2 I tried too, but the screen stays blank.
                                    The back lights are OK.
                                    Today I plugged the TV in without any cables connected, just power. It did its every 10 second bleeping thing again.
                                    Then I tried the blind factory reset through the menu: Home screen, Down Arrow 7 times, press O.k., Right Arrow 1 time, Down Arrow 7 times, press O.K., and then two more times press O.K. and the TV should factory reset. Now after this, the TV stopped bleeping every 10 seconds, but the black screen remains. I do not see anything but black light on. No OSD or anything.
                                    I did notice that the optical output stays on with the back lights off?
                                    • CapLeaker
                                      Leaking Member
                                      • Dec 2014
                                      • 8286
                                      Thanks for all the help guys... but:
                                      Here we go again... TCL?
                                      click that link and go to the "order the required parts for tv parts click this link". Well... the 65S450F-CA isn't listed. This is a fireTV, not a roku. Off course there is nothing available. What a miserable service from TCL. I am gonna that TV soon. This thing belongs in to the .
                                      Keep any ideas coming!
                                      Just too bad badcaps doesn't have more required emoji's for this thread. lol
                                      • EazyBone
                                        • Jun 2023
                                        • 1351
                                        • United states
                                        It might be the main board then. I've had DOA fire tvs and main board was culprit. Didn't do blank white though.. did you try disconnecting each side of TCON ribbon to see half a picture or try tape just to see?
                                        • nomoresonys
                                          • 12216
                                          • U.S.
                                          You probably already toggled thru the sources, maybe repair the remote but seems like it's working, did you see a recessed reset button on the back or side.
                                          • Teban1306
                                            [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                                            by Teban1306
                                            Hello everyone!
                                            I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                                            System Information:
                                            • Model: Lenovo ThinkPad T14 Gen 1
                                            • Machine Type: 20S1S4E600 (Intel i7 variant)
                                            • Current BIOS: N2XET42W (1.33) - Latest version
                                            • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                                            What I'm trying to achieve:
                                            Replace the default "LENOVO" boot logo with a custom image during POST.
                                            🔧 What I've tried:
                                            09-14-2025, 11:49 AM
                                          • Verlengsnoer
                                            Bios splash/logo change
                                            by Verlengsnoer
                                            at firs, i hope this is the right place to post my question.
                                            Im looking for a tool to change the bios logo.
                                            everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
                                            i know that HP has a build in option to change the splash logo.
                                            but i want to change the manufacturer logo to an own logo.
                                            I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
                                            10-28-2022, 09:52 AM
                                          • Echoo
                                            Fujitsu D757 sff desktop pc bios logo reset
                                            by Echoo
                                            Fujitsu D757 sff desktop pc with company logo and it doesn't work to restore the factory logo with UefiModL tool. I need to restore many of these machines to the factory Fujitsu boot logo! Does anyone know a solution?
                                            11-25-2024, 01:54 AM
                                          • smarty
                                            Can anyone identify PCB logo?
                                            by smarty
                                            Can anyone identify logo shown below?
                                            The logo I showed can be found on the PCB's of laptops NP530U3B, NP530U3C, NP540U3B, NP540U3C, etc.
                                            I assume this is a logo of one of the PCB's manufacturers, but I'm not sure.
                                            Neither ChatGPT nor Copilot know the correct answer.
                                            TIA
                                            09-10-2024, 11:48 PM
                                          • q2v5
                                            Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                                            by q2v5
                                            Lenovo T480s
                                            Model 20L8-S3TE00
                                            Board ET481-U10
                                            Chip MX25L12873F
                                            Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                                            2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                                            The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                                            08-15-2024, 10:40 PM
