TCL 65S450F no logo, bleeping sounds?
This topic has been answered.
    • 12307
    • U.S.
    #141
    I understand it very little but looks like it kind of harkens back to when kings ran things, I'd call it dictatorship. Canada=constitutional monarchy and a parliamentary democracy. monarchy and dictator mean the same thing, ran by one person. I'm sure its a whole lot more complicated than that but it boils down to the same shiit we have down here...ours is a SYSTEM that is corrupted by some probably many politicians and a few billionaires making deals behind closed doors and with each other. I know what would be a good start, term limits, we have them for president but nothing else, that's f&%king stupid, wonder who made that law/rule. The way they get these laws passed is they hide them in other shiit when it's time to vote, I consider that a criminal act. Like the bill might be about say not locking old ladies up just because they're old, way way back on page 1,233 will say this bill will not allow term limits for politicians, its just SICK.
    • Diah
      • Feb 2013
      • 6499
      confused:
      any result of the firmware mater??
      if nothings good i could delete mega link as i did just for your set
      • CapLeaker
        Leaking Member
        • 8342
        I just got home and downloaded the 2GB file from Mega link no problem. I guess I need to resize the partition of the 4GB memory stick? Right now the partition is only 1.6GB. I'll try it tonight when its quiet and the house calmed down a bit.
        • CapLeaker
          Leaking Member
          • 8342
          every time i click on this Microsoft wants a login.
            • 12307
            • U.S.
            #145
            • CapLeaker
              Leaking Member
              • 8342
              Diah Well... same thing. Reformated the drive to 4GB (FAT32) and put that V999.img on the drive. Plugged the drive in and did a reset on the tv. The USB blinks a few times and the TV goes into its usual bleeping loop thingy. After a while, the USB drive ends up with a couple more folders and that's it. Still haven't seen anything on the screen.
              • CapLeaker
                Leaking Member
                • 8342
                Thats strange, I'm just using firefox. I also have an ad blocker.
                Me too. Firefox and ublock
                • Diah
                  • Feb 2013
                  • 6499
                  keep yours stick as normal fat 32 mbr mode and put the end file on it in format v999.img be sure urb pc showing file exertion format.
                    • 12307
                    • U.S.
                    #149
                    Maybe try another usb drive.
                    • CapLeaker
                      Leaking Member
                      • 8342
                      I did keep the partition at a FAT32 MBR 4GB. Extracted the zip and pushed the V999.img to the stick which filled it almost up. The TV reacted almost the same when I tried the small file. However the outcome is always the same and results in a loop of some sort where the TV makes a bleeping sound every 12 seconds or so with the backlights on and nothing on the screen.
                      Since the firmware update the TV took by itself, I never seen anything on the screen. For shits and giggles I checked out the LVDS again for another sanity check, Same as before, nothing on the LVDS.
                      • Diah
                        • Feb 2013
                        • 6499
                        Amlogic Soc suffer from heat if its under load such fimware update / read write etc.. i remember you wrote you changed new heatsink... so the original was small... it sound the Soc got BGA at time it under Online update... try heating the soc from the top.. with hot air gun... you will not loss anythings.
                        • CapLeaker
                          Leaking Member
                          • 8342
                          I tried one more last ditch attempt with this board and did following:
                          1) reflowing it / No go
                          2) found 3 TCL groups on Telegram, one of it is a bot. I have to say that this TV wasn't in their list. However they were saying that the update file should be update.img, not V999.img. Tried that, no go.
                          The only thing I haven't done is to put a TTL on the main board and see what's happening. I don't think there will be anything fruitful coming out of this. It's just another week for the replacement main board to arrive.
                          • Diah
                            • Feb 2013
                            • 6499
                            wow... yours TCL are working but just GPU out , either it can pick IP if you connect it to yours Router... so plug it in router and read the IP of it from inside the router.. and let assign same IP each time it plugged in LAN,
                            use on PC ADB ..
                            adb connect yours TV IIP after that keep presst OK on the RC as you cant see.. to be sure its connected to ADB
                            adb devices it should show server started
                            adb reboot it will let the TV reboot
                            adb reboot recovery hope yours recovery will come on
                            • CapLeaker
                              Leaking Member
                              • 8342
                              use on PC ADB ..
                              I know it is polling an IP address from the router. Problem is the TV is starting something every 12 seconds or so and there is a bleeping sound. It isn’t fully rebooting but it seems the TV is trying something and failing. It’s the weirdest thing on a TV I ever saw. It is there, but yet it is not accept anything besides an IP.
                                • Jul 2011
                                • 6070
                                I would be very interested in if when you put the new main board if it will do anything more than what it has been doing
                                • CapLeaker
                                  Leaking Member
                                  • 8342
                                  Ha! I am waiting for that result too!
                                  • Diah
                                    • Feb 2013
                                    • 6499
                                    I know it is polling an IP address from the router. Problem is the TV is starting something every 12 seconds or so and there is a bleeping sound. It isn't fully rebooting but it seems the TV is trying something and failing. It's the weirdest thing on a TV I ever saw. It is there, but yet it is not accept anything besides an IP.
                                    let try again...
                                    the file of upgrade or V999.img you put it on USB stick MBR mode fat32
                                    the file i give to you at post 101 factory_update_param.aml change it by add the file name you have in .img format
                                    for example
                                    --wipe_data
                                    --wipe_cache
                                    --wipe_media
                                    --update_package=/sdcard/v999.img
                                    or
                                    you can download from the link i gave before zip file and let the ,aml format in this way
                                    --wipe_data
                                    --wipe_cache
                                    --wipe_media
                                    --update_package=/sdcard/updatw.zip​
                                    use the same way you did at post 104
                                    • CapLeaker
                                      Leaking Member
                                      • 8342
                                      let try again...
                                      for example
                                      --wipe_data
                                      --wipe_cache
                                      --wipe_media
                                      or
                                      --wipe_data
                                      --wipe_cache
                                      --wipe_media
                                      Nope... no go for me that way. I think the only way to do something maybe is over that factory programming port on the main PCB.
                                      • CapLeaker
                                        Leaking Member
                                        • 8342
                                        Finally this TV is fixed. Got a new main board, chucked that in, turned the TV on and SUCCESS!
                                        • Diah
                                          • Feb 2013
                                          • 6499
                                          disconnect it from internet and disable auto update lol
                                          • Teban1306
                                            [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                                            by Teban1306
                                            Hello everyone!
                                            I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                                            System Information:
                                            • Model: Lenovo ThinkPad T14 Gen 1
                                            • Machine Type: 20S1S4E600 (Intel i7 variant)
                                            • Current BIOS: N2XET42W (1.33) - Latest version
                                            • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                                            What I'm trying to achieve:
                                            Replace the default "LENOVO" boot logo with a custom image during POST.
                                            🔧 What I've tried:
                                            09-14-2025, 11:49 AM
                                          • Verlengsnoer
                                            Bios splash/logo change
                                            by Verlengsnoer
                                            at firs, i hope this is the right place to post my question.
                                            Im looking for a tool to change the bios logo.
                                            everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
                                            i know that HP has a build in option to change the splash logo.
                                            but i want to change the manufacturer logo to an own logo.
                                            I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
                                            10-28-2022, 09:52 AM
                                          • conghuyms
                                            MacBook Air A2179 stuck logo , pls help me !
                                            by conghuyms
                                            Hey everyone,
                                            I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
                                            When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
                                            I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
                                            Today, 08:30 AM
                                          • Echoo
                                            Fujitsu D757 sff desktop pc bios logo reset
                                            by Echoo
                                            Fujitsu D757 sff desktop pc with company logo and it doesn't work to restore the factory logo with UefiModL tool. I need to restore many of these machines to the factory Fujitsu boot logo! Does anyone know a solution?
                                            11-25-2024, 01:54 AM
                                          • smarty
                                            Can anyone identify PCB logo?
                                            by smarty
                                            Can anyone identify logo shown below?
                                            The logo I showed can be found on the PCB's of laptops NP530U3B, NP530U3C, NP540U3B, NP540U3C, etc.
                                            I assume this is a logo of one of the PCB's manufacturers, but I'm not sure.
                                            Neither ChatGPT nor Copilot know the correct answer.
                                            TIA
                                            09-10-2024, 11:48 PM
