I understand it very little but looks like it kind of harkens back to when kings ran things, I'd call it dictatorship. Canada=constitutional monarchy and a parliamentary democracy. monarchy and dictator mean the same thing, ran by one person. I'm sure its a whole lot more complicated than that but it boils down to the same shiit we have down here...ours is a SYSTEM that is corrupted by some probably many politicians and a few billionaires making deals behind closed doors and with each other. I know what would be a good start, term limits, we have them for president but nothing else, that's f&%king stupid, wonder who made that law/rule. The way they get these laws passed is they hide them in other shiit when it's time to vote, I consider that a criminal act. Like the bill might be about say not locking old ladies up just because they're old, way way back on page 1,233 will say this bill will not allow term limits for politicians, its just SICK.
TCL 65S450F no logo, bleeping sounds?
This topic has been answered.
Worked for me, brought me here: https://faserf-my.sharepoint.com/per...2FT800T02&ga=1Comment
Diah Well... same thing. Reformated the drive to 4GB (FAT32) and put that V999.img on the drive. Plugged the drive in and did a reset on the tv. The USB blinks a few times and the TV goes into its usual bleeping loop thingy. After a while, the USB drive ends up with a couple more folders and that's it. Still haven't seen anything on the screen.Comment
Since the firmware update the TV took by itself, I never seen anything on the screen. For shits and giggles I checked out the LVDS again for another sanity check, Same as before, nothing on the LVDS.Comment
Amlogic Soc suffer from heat if its under load such fimware update / read write etc.. i remember you wrote you changed new heatsink... so the original was small... it sound the Soc got BGA at time it under Online update... try heating the soc from the top.. with hot air gun... you will not loss anythings.
I tried one more last ditch attempt with this board and did following:
1) reflowing it / No go
2) found 3 TCL groups on Telegram, one of it is a bot. I have to say that this TV wasn't in their list. However they were saying that the update file should be update.img, not V999.img. Tried that, no go.
The only thing I haven't done is to put a TTL on the main board and see what's happening. I don't think there will be anything fruitful coming out of this. It's just another week for the replacement main board to arrive.Comment
use on PC ADB ..
adb connect yours TV IIP after that keep presst OK on the RC as you cant see.. to be sure its connected to ADB
adb devices it should show server started
adb reboot it will let the TV reboot
adb reboot recovery hope yours recovery will come onComment
wow... yours TCL are working but just GPU out , either it can pick IP if you connect it to yours Router... so plug it in router and read the IP of it from inside the router.. and let assign same IP each time it plugged in LAN,
use on PC ADB ..
I know it is polling an IP address from the router. Problem is the TV is starting something every 12 seconds or so and there is a bleeping sound. It isn't fully rebooting but it seems the TV is trying something and failing. It's the weirdest thing on a TV I ever saw. It is there, but yet it is not accept anything besides an IP.
the file of upgrade or V999.img you put it on USB stick MBR mode fat32
the file i give to you at post 101 factory_update_param.aml change it by add the file name you have in .img format
for example
--wipe_data
--wipe_cache
--wipe_media
--update_package=/sdcard/v999.img
or
you can download from the link i gave before zip file and let the ,aml format in this way
--wipe_data
--wipe_cache
--wipe_media
--update_package=/sdcard/updatw.zip
use the same way you did at post 104
let try again...
for example
--wipe_data
--wipe_cache
--wipe_media
or
--wipe_data
--wipe_cache
--wipe_media
by VerlengsnoerHi all,
at firs, i hope this is the right place to post my question.
Im looking for a tool to change the bios logo.
everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
i know that HP has a build in option to change the splash logo.
but i want to change the manufacturer logo to an own logo.
I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
...10-28-2022, 09:52 AM -
by EchooFujitsu D757 sff desktop pc with company logo and it doesn't work to restore the factory logo with UefiModL tool. I need to restore many of these machines to the factory Fujitsu boot logo! Does anyone know a solution?11-25-2024, 01:54 AM
by smartyCan anyone identify logo shown below?
The logo I showed can be found on the PCB's of laptops NP530U3B, NP530U3C, NP540U3B, NP540U3C, etc.
I assume this is a logo of one of the PCB's manufacturers, but I'm not sure.
Neither ChatGPT nor Copilot know the correct answer.
TIA1 Photo -
by q2v5Lenovo T480s
Model 20L8-S3TE00
Board ET481-U10
Chip MX25L12873F
Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...-
Channel: BIOS Requests ONLY!
by p.puhakkaHello forum!
I have received a lot of help here, regarding bios modding. Very thankful!
Now I have a lot of Fujitsu K557 desktops, and those have custom bios logo/custom splash screen, and I need to change them to the original Fujitsu logo.
I am looking for the easiest way, because I have about 40pcs of them, and I think there is some "official" way to do this.
I have tried a lot of Fujitsu tools, which can inject the logo to the bios file, but no luck.
Any suggestions? Thanks! - Loading...
