TCL 65S450F no logo, bleeping sounds?
This topic has been answered.
  • Diah
    • Feb 2013
    • 6498
    try this... plug out the TV from wall copy the file after extract the zip factory_update_param.aml on root USB stick formated Fat32 or Fat not bigger than 2Gb.. insert first at USB 1 then press power on the TV keep press while you plug the TV in wall... for at least 5-7 second... hope your screen will come on say no data for update but it will wipe the rest in command i wrote in the script.
    you may try all USB ports one by one for several time as we dont know which on the Amlogic boot related to USB ports
    • nomoresonys
      • 12307
      • U.S.
      #102
      It's getting interesting
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8342
        Originally posted by Diah
        you are lucky as the Soc Amlogic.. it had bootloader section on it which we can trick it with PC..connect yours TV with male to male USB with PC let see how the PC show
        here we are with tools
        Oyyy... I got to set this up. stby...
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8342
          I did this step first:
          Took a 4GB USB flash drive and resized it to 1.6GB, formatted it with FAT32 and copied this .aml file to root.
          Reassembled the main board and put a new heat pad on it.
          Plugged in the USB drive (only one USB on this thing), Pressed the power button and plugged the TV in and kept pressing for 7 seconds. Nothing happened.
          Unplugged the TV again for 20seconds, plugged the TV in while keeping the power depressed until it rebooted. Then the USB drive started blinking, so I let it finish.
          Unfortunately I didn't see anything on the screen.
          Here is what I got out on the USB:
          So... this thing is listening on the USB, but I have to see something on the screen yet.
          • Diah
            • Feb 2013
            • 6498
            the android on the stick mean the TV start and booted and sync the usb stick so it write data of android on it.. good sign, it mean also if you fed it with HDMI signal and do change the source you will hear sound
            try this
            1- dont rezise the stick keep it in full format Fat32 and put the file on it then try..the same way
            2- with out stick in USB port if you press power and keep pressing then plug it in wall the Amlogic will call the recovery hope screen come on
            3- with out any things as it sart and USB stick blinking... mean it start.. plug the TV with LAN cable to yours router.... log in yours router and check the TV IP... we may use it by using ADB on PC to reboot the TV in recovery
            • Diah
              • Feb 2013
              • 6498
              yours TV starting and of sure you have now the audio optic lit red.. and you can hear sound too if there are source.... but now we have the Soc GPU cutting off for some reason
              one i described about the Kernel...
              second they are load.. so if all above post didn't work for you.. to bring recovery on..
              try remove the rest of the back cover to have access to panel buffer boards... and from there we reduce the load by disconnecting the U ribbon cable at each half a time or both side together...
              if this didn't bring little part of screen on... then stop and try to find firmware to write it again...
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8342
                try this
                Had to put a network switch in here to do all that. O.k. here is what happened:
                The exact thing than last time and still nothing on the screen.
                I did plug the TV into my network and my switch started blinking. I did an IP scan and the main board does pull an IP address.
                I don't think I can change the HDMI, since I can't see anything, unless it is switching automatically to the HDMI port in use.
                • Diah
                  • Feb 2013
                  • 6498
                  do please as post 106
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8342
                    I already tried to disconnect the ribbon cables. With only one from either side connected / disconnected, both on and both off. That doesn't do squat.
                    Yeah... firmware... sure! If I could find it, I would have flashed the shit out of the TV already.
                    • Diah
                      • Feb 2013
                      • 6498
                      i am talking on U ribbon which they are at the middle of each side not the LVDS..... now yours MB working and booting complete and pick IP.. need to try now at this stage.. dont histaed
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8342
                        Naah... nothing on the display.
                        • Diah
                          • Feb 2013
                          • 6498
                          LOL... you are swimming at opposite my direction..
                          please read the specs of yours soc T962 for example to know how communicated or try its second boot to have screen on.
                          rebrand it with other brand LOL you have the tools like this TVs all used the Soc Xiaomi Mi TV 4 Pro 4A 32"/43" (India) / Skyworth G6A / TCL P4
                          • nomoresonys
                            • 12307
                            • U.S.
                            #113
                            So what's up with this being a new tv but no firmware easily available from the tcl website. Are they the sort of weirdos that want you to contact them personally to get the firmware or sum such?
                            • nomoresonys
                              • 12307
                              • U.S.
                              #114
                              Towards the bottom they have options, one says get more help-amazon support, boy howdy there's nothing like trying to go thru 2 entities to get one piece of firmware or do you need more? I noticed it's there but not clickable on that screen, lol=nightmare https://support.tcl.com/troubleshoot...arch=156097362
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8342
                                I am going to try Diah’s other trick first. I never seen such a poor support on a TV . No wonder Amazon said to put it into the . FireTV my @$$.
                                So far I cannot proof that the screen is shorted, since I don’t see anything happening on the LVDS. If Dihs other trick doesn’t work I am going to try a new main board and see what that does.
                                • Diah
                                  • Feb 2013
                                  • 6498
                                  before you go for debranding , let us try to wake up the Soc GPU, as yours set working now 100% but with out GPU output.
                                  use external source HDMI with yours TV HIDMI input with function ARC , play movie how long you can..... beside it also put several JPG Photos with 1080P resolution on USB root and insert it in USB Port same time... the idea to make the Soc crazy with sources which it need GPU. this could help to repair its self and switched it on.
                                  other things as you want to test the panel... show here please the clear high resolution photo of the panel edge boards specially to the area of 2 LVDS sockets
                                  • Diah
                                    • Feb 2013
                                    • 6498
                                    we found it... Amlogic Soc called T800 platform or Just T
                                    go to XDA and dounload as zip to put it on root usb stick and use the method of the power key as i explained before for example V127
                                    • Diah
                                      • Feb 2013
                                      • 6498
                                      at yours case need firmware as ,img format not zip.. so it will be downgrade if the version you found less than the one now on the set.
                                      write there at xda,,, it was there .img but no more to download... the threat owner look he is from asia and have access to TCL easy to give you one after you upload there the SW label of yours MB
                                      • CapLeaker
                                        Leaking Member
                                        • Dec 2014
                                        • 8342
                                        The only label on the main board is on my post 66
                                        • Diah
                                          • Feb 2013
                                          • 6498
                                          its T800
                                          • Teban1306
                                            [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                                            by Teban1306
                                            Hello everyone!
                                            I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                                            System Information:
                                            • Model: Lenovo ThinkPad T14 Gen 1
                                            • Machine Type: 20S1S4E600 (Intel i7 variant)
                                            • Current BIOS: N2XET42W (1.33) - Latest version
                                            • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                                            What I'm trying to achieve:
                                            Replace the default "LENOVO" boot logo with a custom image during POST.
                                            🔧 What I've tried:
                                            09-14-2025, 11:49 AM
                                          • Verlengsnoer
                                            Bios splash/logo change
                                            by Verlengsnoer
                                            at firs, i hope this is the right place to post my question.
                                            Im looking for a tool to change the bios logo.
                                            everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
                                            i know that HP has a build in option to change the splash logo.
                                            but i want to change the manufacturer logo to an own logo.
                                            I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
                                            10-28-2022, 09:52 AM
                                          • conghuyms
                                            MacBook Air A2179 stuck logo , pls help me !
                                            by conghuyms
                                            Hey everyone,
                                            I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
                                            When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
                                            I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
                                            Today, 08:30 AM
                                          • Echoo
                                            Fujitsu D757 sff desktop pc bios logo reset
                                            by Echoo
                                            Fujitsu D757 sff desktop pc with company logo and it doesn't work to restore the factory logo with UefiModL tool. I need to restore many of these machines to the factory Fujitsu boot logo! Does anyone know a solution?
                                            11-25-2024, 01:54 AM
                                          • smarty
                                            Can anyone identify PCB logo?
                                            by smarty
                                            Can anyone identify logo shown below?
                                            The logo I showed can be found on the PCB's of laptops NP530U3B, NP530U3C, NP540U3B, NP540U3C, etc.
                                            I assume this is a logo of one of the PCB's manufacturers, but I'm not sure.
                                            Neither ChatGPT nor Copilot know the correct answer.
                                            TIA
                                            09-10-2024, 11:48 PM
