sony 55X850D black screen no front white or red led light.
  • Ihandyrepair
    • Sep 2017
    • 44
    Hi guys
    strange one
    I have a dead Sony 55X850D
    when plug in, black screen, no front white or red LED, no back light no screen
    Voltages I get
    3.3v LD/power and main board
    reg 12V
    reg 19V
    3.3v on power on pin
    no Tcon on
    no tcon 12v
    no BL_on
    I do get BL_ERR 2.0v
    I tried to bypass it by ground it but still get same symptom
    I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
    or is possible the chip next to it? Pin 5 and 6 are connected. where I measure another similar chip, the pin 5 and 6 are not connected
    I just want to confirm with you guys before I take it out
    also If you guys know what spec should I use as there is no label or markings on the cap
    thanks
    • 12330
    • U.S.
    Hm, check those other little caps right in that area and also any other caps that size and compare.
      • 12330
      • U.S.
      This might not be the most precise approach but there's a longtime pro tech on youtube, that grabs one of those mlc caps off of his scrap boards that is the same physical size and throws it in there, he swears that he hasn't blown anything up yet, lol.
      • lotas
        • Jan 2016
        • 4859
        • Russia
        10 Ohm is a completely normal resistance, it can power the processor core, but there is always low resistance, if something shorted, the fuse would blow, what is the voltage on this inductor relative to ground?
        • Diah
          • Feb 2013
          • 6564
          this set from years 2016 with edge BL, which LEDs had build in zener diode one or more shorted so you have BL_ERR.
          front LED could be turned off from user setting before it got fault at LEDs. since it send power_on.. so dont play with MB go head to take screen apart.. shorting BL_ERR to ground will not working at this set as it had frame dynamic Dimming.
            • 12330
            • U.S.
            I agree with Diah, the bl-err is your clue, it can be very hard to tell if an mlc cap is bad unless you know what ohm they are suppose to read, getting very hot might be a clue to a bad cap. Have seen many shorted mlc caps on mainboards WITHOUT fuse being shorted.
            • Ihandyrepair
              • Sep 2017
              • 44
              Thanks for the tip
              here is another similar setup on the same board
              Red circle is the one I am thinking possible shorted cap
              now measured 39 ohms on caps end or chip legs 5-6
              yellow circle
              Both caps measure 7k ohms
              and same for the chip next legs 5-6
              as for the backlights error, won’t remove the line BL_ERR to LD board and ground on the main board side would at least try to turn on the backlights (by pass the error)
              but I get no reaction
              • Diah
                • Feb 2013
                • 6564
                i did explained at my early post why grounding BL_ERR to ground didn't work...
                if you tried it one more you will end by toasting yours PSU
                  • 12330
                  • U.S.
                  Think I would investigate those backlights, a guy here that works on a lot of sonys said he never had one with voltage at the bl-err pin that wasn't due to bad led/s.
                  • Ihandyrepair
                    • Sep 2017
                    • 44
                    sorry I missed the part about dynamic dimming.
                    I guess Sony edge BL is different system than spread out led strips.
                    the 65X950G I was able to ground the BL_ERR to turn on the back lights to check if that is the real problem
                    thanks, got it, I will order the led first before taking it apart.
                    I will update you guys later when I am done
                      • 12330
                      • U.S.
                      Lol, meant to say have seen many shorted mlc caps without fuse being open/blown.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4539
                        • Italy - Milan
                        why don't you write entire model numbers? It is useful for other one's searching..
                        • Ihandyrepair
                          • Sep 2017
                          • 44
                          Hey guys
                          I took the panel off
                          borh edge led strips looks good
                          I tested with the led tester
                          none burnt
                          all seems to work
                          each section 56.9 to 57.0v
                          no sign of any led is not working
                          what should I do?
                          • lotas
                            • Jan 2016
                            • 4859
                            • Russia
                            Why would you disassemble the backlight if you don’t even have a boot, the TV should have a standby mode, go into working mode and give an error, if the auxiliary is not working properly, but this is not the case, then the problem is in the motherboard...
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4539
                              • Italy - Milan
                              test the psb with leds and no mb connected, force bl-on,.tcon-on
                              both psb and mb can be dried by an overvoltage.. surge at mains..
                                • 12330
                                • U.S.
                                https://www.badcaps.net/forum/troubl...but-then-black
                                Well lotus it's right here in this thread so who is right? If the fault is on the mainboard WHERE is it??:
                                  • 12330
                                  • U.S.
                                  ANY other opinions are welcome also, what do you guys think?
                                  • Ihandyrepair
                                    • Sep 2017
                                    • 44
                                    I just noticed that if I unplug the cable from LD board to mainboard and power it on
                                    the backlight will turn on.
                                    so most likely the LD board is ok and issue could be the main board right?
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4539
                                      • Italy - Milan
                                      i think yes, the mb controls the local dimming BL maybe, but mb software is KO maybe, so LD goes error and BL_ERR rises..
                                        • 12330
                                        • U.S.
                                        Interesting, well I sure hope this one gets fixed, I gave up on mine that had bl-err, didn't care for the picture quality much when it was working, so didn't spend any more time on it, usually don't give up but just got sick of it.
                                        • Gigabyte_PL
                                          PS4 PRO - black screen, white light
                                          by Gigabyte_PL
                                          I have problem with my Playstation 4 PRO. After a long break, I turned on the console and tried to play game. Game started, but after a minute it froze the console and crashed to the main menu. I tried running another game and the same problem.
                                          Error returned: CE-34878-0 (I changed HDD)
                                          I updated the software in the console. I unplugged the console, put it aside for a week and now I want to turn it on but there is no image. The console lights up white, there is communication via HDMI with the monitor - but only a black screen (but it detects the...
                                          01-04-2024, 05:46 AM
                                        • Audeze
                                          Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                          by Audeze
                                          I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                          Does...
                                          10-06-2024, 08:54 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • VcemPzd
                                          Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                          by VcemPzd
                                          Hello everyone !
                                          My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                          04-28-2025, 10:14 AM
                                        • Raulnn
                                          TD Systems K50DLG12US half black and half white screen
                                          by Raulnn
                                          good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                                          By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                                          01-20-2024, 04:49 PM
