Vizio e3d320vx stuck on V logo - Looking for schems/firmware
  • kisk
    Computer Tech
    • Jan 2014
    • 78
    This is a 1080 smart 3d tv I bought off of someone for cheap and was hoping to get it up an running. When you turn it on, it displays the Vizio "V" logo and that's it. Must unplug to turn it off. Tried the 30s reset with no luck.
    I have read a few fixes that suggested that the firmware was corrupted/badflashed and thats keeping the set from booting. I have a GQ-4X programmer with SOIC8 adapter.
    As far as the firmware, I cannot find any downloads/dumps for this model, although I have read that there was at least one new fw release for this tv. I was curious if other similar models might use the same firmware that I could download instead?
    Has anyone ever played with something like this or have a schematic of this or a similar model? This is the first Vizio I've worked on.
    Thanks!
  • ecking767
    • Oct 2009
    • 492
    Re: Vizio e3d320vx stuck on V logo - Looking for schems/firmware
    you have to replace your main board, the firmware isn't on a SOIC8. Its U52 on your main board. you will need an very expensive programmer to copy and write to that type of IC chip.
    • kisk
      Computer Tech
      • Jan 2014
      • 78
      Looked for about an hour and could not find U52. Do you have schematics of the tv and/or board I could take a look at? The mainboard pn is 3632-1532-0150. I have been unable to find one.
      Depending on what type ic chip the firmware is stored on I may be willing to invest in a programmer that would handle it as the cost of the board is +/- $75.
      Thanks for your response!
      • ecking767
        • Oct 2009
        • 492
        OKAY its U12 on the back side of your main board
        check ebay for a replacement board, I found 2 and 1 repair service
        to program U12 you will need to spend about $1,000 for a programmer
        • kisk
          Computer Tech
          • Jan 2014
          • 78
          Great, thanks for the info! I did find this that does program nands, including the Hyrix H27U's for $278:
          http://www.ebay.com/itm/TNM-2000-USB...-/321207236799
          I'm thinking about it. In the meantime, I don't have access to a good copy of the firmware so I guess I'll be buying a board
            Firmware/flash is surely Vizio's biggest weakness. Aside from that, the modern sets are really reliable TVs, from what I've seen, and usually with decent LG panels in them.
            Almost seems deliberate.
            • ecking767
              • Oct 2009
              • 492
              its look OK to buy and I see HYNIX on the device list. I will check it out the device list for other EEPROM that Vizio smart TV's use. The price have came down for a Wellon programmer its about $650.
              But also keep in mind soldering a TSOP48 can be a challenge.
              • kisk
                Computer Tech
                • Jan 2014
                • 78
                Just to update: I ended up buying a used mainboard for this set and it has worked flawlessly in the bedroom for almost a year.
                Still haven't pulled the trigger on buying that programmer though
                • wkw1957
                  • Nov 2019
                  • 4
                  Are pre-programmed eeproms even available for this model? I've been trying to fix this same model TV for someone with the same problem. Displays logo and can't be turned off. I noticed eBay sellers had eeproms for other Vizios but I couldn't find this model listed. I did find a parts kit which was advertised as fixing this problem but turned out to be a total waste of money. All it contained were two 3.3V regulator chips, two fuses and a cap. All these parts checked out OK in the TV.
                    • 12145
                    • U.S.
                    This might be a match, seems pretty pricey for a 32 inch tv tho at 60 bux, unless the 3d vision is just great, probably the best price tho since most are sold out: https://www.ebay.com/itm/Vizio-32-E3...YAAOSw-uhduyMq
                      • 12145
                      • U.S.
                      What is your full model number or service code on the back cover of the tv?
                      • wkw1957
                        • Nov 2019
                        • 4
                        It is also a E3D320VX just like the original poster's TV. The main board has this number along the edge: 0171-2272-3834. I would like to find just the eeprom chip if possible. I've seen them for sale for other models. But a cheap enough main board will do. Doubt if the owner will want to pay for replacing a $60 board.
                          • 12145
                          • U.S.
                          Are there any letters after the E3D320VX or a service code number near the model number on back cover?
                          • wkw1957
                            • Nov 2019
                            • 4
                            No additional characters. The only thing else on the label is a model and serial number if those will help.
                            Model No. 10223320022
                            Serial No. LAQKJRAM1601057
                              • 12145
                              • U.S.
                              Trying to figure out if any will interchange, it seems like a real head scratcher, shopjimmy had 2 listed, out of stock now: https://www.shopjimmy.com/catalogsea...lt/?q=E3D320VX then there's this on ebay that says its from e3d320vx with a slightly different number, 3642 vs 3632: https://www.ebay.ca/itm/VIZIO-3642-1...cAAOSwax5Ythu-
                                • 12145
                                • U.S.
                                Strange if you click one of the ones on shopjimmy it says will fit 2 different models, then if you click the other one it only lists one model, I don't know what to make of it.
                                  • 12145
                                  • U.S.
                                  From looking closer at the various boards, this is probably the one that looks just like yours, from what I can tell: https://www.ebay.com/itm/VIZIO-3632-...YAAOSwIAJb1nkZ
                                  • wkw1957
                                    • Nov 2019
                                    • 4
                                    0171-2272-3834 is the number on my main board and that is the $94 one on that site.
                                      • 12145
                                      • U.S.
                                      I think the one in post #17 is the same, crazy price tho, 70 bux plus 10 shipping.
                                        • 12145
                                        • U.S.
                                        This one has eeprom BUT I don't see 3632-1532-0150 or 3632-1532-0395 in the compatible numbers, could maybe contact m and ask if they have one for yours??: https://www.ebay.com/itm/VIZIO-EEPRO....c100009.m1982
                                        • Bob1394
                                          Vizio M65-C1 | Logo appears for 10 seconds then off
                                          by Bob1394
                                          I have used the search, and am stumped.
                                          My Vizio M65-C1, Vizio logo appears for about 10 seconds then goes off.Power LED blinks 15 times then the TV powers down.
                                          I have read through many threads on the M65-C1 including the following threads. I feel like I must be looking right past the solution to my problem:
                                          https://www.badcaps.net/forum/showthread.php?t=81088
                                          https://www.badcaps.net/forum/showthread.php?t=84241 (not clear on the Eprom actions)
                                          Observations
                                          1) [Interaction] Power turned on via TV button (or remote)...
                                          02-08-2023, 01:03 PM
                                        • Super360
                                          Vizio E701i-A3 Vizio logo flashing then turns off
                                          by Super360
                                          Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                                          07-25-2024, 07:06 PM
                                        • JaquesPratt
                                          Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                          by JaquesPratt
                                          I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                          This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                          07-16-2024, 01:04 AM
                                        • jason123
                                          Vizio D50-F1 - Can't update Software / Firmware
                                          by jason123
                                          Wondering if any of you have seen this before. I got this TV with lower half of the screen dim. Fixed the LED backlight issue - smooth
                                          I noticed that the System update lists current firmware is V1.0.6 and is able to find on the Vizio server 2.60.23-1... it downloads fully.. but instead of restarting, it just goes back to the previous screen "NO SIGNAL - HDMI1"
                                          I got the code and followed the update via flash drive - and it does exactly the same thing. Firmware is copied by the TV 100%, and then nothing - instead of restarting, it just goes back to the previous...
                                          08-15-2021, 06:48 AM
                                        • Lee M.
                                          Vizio E55-DO firmware corrupted?
                                          by Lee M.
                                          I was given this set and do not have the original remote. It will turn on with the power button and display "oobe V1.1.12 firmware V0" but that's all it will do. It does not respond to the input select button or volume button. I have a remote from the cable company and programmed it for Vizio and it will turn the set on and off but that's it, no response from any other buttons. The white standby led comes on bright at first and then dims but stays on while the set is on. I pulled the back off and looked for anything obvious like loose connectors, bad solder, bad caps and didn't find...
                                          04-02-2023, 03:12 PM
