Element Flx-3210 won't turn on
  • RoniRoni
    • Feb 2014
    • 19
    I have above listed tv. The red stand by light does not change after touching the power button. I have looked at caps and none are bulged.I have tested output voltages and the only thing that maybe wrong is the 12 volt is showing 10.8. Also the voltage at the large cap is showing297 all the time. Any ideas would help. Thank you and hope everyone has a great day.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Element Flx-3210 won't turn on
    As you have read the previous posts regarding this set you will know that some have had success by replacing the two caps under the heatshield. If yours are HE brand then
    maybe try the same. Without seeing your boards it is impossible to see other problems that may be visible.
    • RoniRoni
      • Feb 2014
      • 19
      Does anyone have a way to check if this set has the VGA shut down problem? Any way to test for that?
      • RoniRoni
        • Feb 2014
        • 19
        Any way to force the set to come on?
        • RoniRoni
          • Feb 2014
          • 19
          I have done some more testing today. This set has a 200 P00 MLT666A AH power supply. I disconnected connector 5 ( the one with 5, 12, 24 volt, grd). The only terminal with power with it not connected to the main board is 5vsb, and with it connected to the main board all terminals have correct voltage. Im starting to think that its the power button. Does anyone know how those touch buttons work? Also is there a way to test for my theory? Thank you
          • johnboy1313
            • Nov 2012
            • 1959
            I would suspect the main board
            • RoniRoni
              • Feb 2014
              • 19
              Is there a way to test the main board?
              • RoniRoni
                • Feb 2014
                • 19
                Has anyone on here heard or worked on one of these sets that had the VGA shut down issue? If so was you able to fix it and do you know what causes the issue?
                  Which version is your model? There are more than one version of this model: http://www.shopjimmy.com/catalogsear...ement+Flx-3210
                  • RoniRoni
                    • Feb 2014
                    • 19
                    How do I know what version I have. It was made march of 07.
                      Any one of those in shop jimmy matches your board?
                      • RoniRoni
                        • Feb 2014
                        • 19
                        I'm sorry I don't understand what your telling me or asking me?
                        • mmartell
                          • Oct 2013
                          • 3189
                          www.shopjimmy.com
                          • RoniRoni
                            • Feb 2014
                            • 19
                            Ok I have gone to jimmy website now what? I'm looking for more knowledge then parts.
                              Click on the link on post 9, then you will see lots of boards for your model.
                              • RoniRoni
                                • Feb 2014
                                • 19
                                Does anyone know anything about the VGA causing the set to shut off and never to be powered up again? Was it a software glitch, or a hardware fault? I thought I read somewhere that pin 9 becomes shorted but I can't seem to find that info again or I may have misunderstood. Please any leads would help. Thank you
                                • philliesfan30m
                                  • Aug 2013
                                  • 542
                                  they wanna know what the numbers are off the mainboard you have in your tv so they know what board to troubleshoot.
                                  • RoniRoni
                                    • Feb 2014
                                    • 19
                                    Another question, A lot of these proview tv use similar main boards. Mine uses a 899 kj0 uf3212xa1h I was wondering if I find another part number cheap on ebay will the tv work. What I mean is I understand that the splash screen maybe different. Also understand that the inputs maybe different. I want to know if it will make the set function as the model that main board came from. Has anyone mixed and match main boards on this type of set? If so what has happened?
                                    • RoniRoni
                                      • Feb 2014
                                      • 19
                                      Has anyone ever reflowed a main board before? I have done a computer motherboard once. I was wondering if these main board run that hot?
                                      • Pentium4
                                        CapXon Be Gone
                                        • Sep 2011
                                        • 3741
                                        Why are you ignoring responses? Post some pictures, and then maybe you'll get some help.
                                        • pajdek
                                          Lenovo Y700-17ISK turn on and off
                                          by pajdek
                                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                          09-20-2023, 02:49 AM
                                        • ThetraXXL
                                          LG OLED C1, SOS-Turn Off, Stand alone test
                                          by ThetraXXL
                                          Hello guys,
                                          I recently picked up an LG C1 in 65 inch size. Previous owner told me that the TV won‘t start, so I did believe due to PSU issue, but not this time. I could narrow it down to the T-Con or Panel.
                                          PSU and Mainboard work both like intended, all Voltages available, Optical on when T-Con lower Ribbon is disconnected and I even managed to get some picture with P-Only, IN-STOP cycle but only for 2 sec. before shutdown.
                                          For the stand alone test the panel starts with some flashing horizontal white lines and then continues to build up some color on the...
                                          10-29-2024, 10:33 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
                                        • masoksian
                                          Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                          by masoksian
                                          I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                          The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                          The system does not turn on, there is no post.
                                          I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                          The problem continues in the same way.
                                          I tried to turn on the Fn key, nothing came to the screen....
                                          02-15-2025, 12:08 PM
                                        • dqtech
                                          lenovo x240 nm-a091 wont turn on
                                          by dqtech
                                          i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
                                          board number VIUX1 NM-A091 REV:1.0...
                                          02-07-2024, 01:57 AM
