I'm planning to try to freeze the chip when I get home this evening. If that doesn't work then I'll test the voltages as suggested by lotas because that seems like the easiest next step. One question for Diah to make sure that I understand the last post... Are you saying that I could (at least temporarily) cause the TV to remain on by connecting the Error Detection pin on the lower LVDS to the chassis through a 1K resistor? If so, would I need to also remove that pin from what it's currently attached to on the TCON board? (That may be a bit beyond my skill set, but I might give it a try as long as I'm sure that I understand the suggestion.)
Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
about the SOS signal pin on LVDS socket..
usually LG assigned the line of SOS error at pin 6 at the lower LVDS when we count from downside ( remember when you did test by disconnect only this lower LVDS the TV no more 5 blink )
it could be not the the pin No 6 or 7 or 5... to know which one when the TV start normal this SOS pin will be low... and when the 5 blink start it will be high.. so easy to know which one are the error signal pins
after you be sure of this poins... follow it on the T-CON.... it will be go to R and C... so you can terminated from the R,, not from the socket to avoid damage the socket...... it is also on the Main boards side you can trace it as it will go to R first,,, so you can terminated from mainboards.... which one easy to you do it... but the line which come from MB need to go to chassis via 1KR
sorry i cant follow with you today as the champion league football will start soon..but of sure other member will answer you if you have questions.
goof luckComment
EazyBone Clearly my knowledge is somewhat limited here, but I think that the idea of Diah's "freeze" suggestion is that the eMMC chip has rewritable memory that may be "stuck,' with the error flag set. (That would explain why the pattern test isn't working even though I unplugged the TV while the screen was working.) So the thought is that freezing it may allow the memory to get unstuck so the flag would be cleared. If that were to happen then the TV would actually be fixed. Of course, it would only be truly fixed if the cause of the problem was just a random occurrence that put the eMMC into a bad state. The eMMC would ultimately need to be replaced if it's failing, and clearly nothing would be fixed if the eMMC's error was caused by a problem within the panel. My hope is that it's just related to the eMMC... that seems possible given that the TV is able to turn on with no visible signs of a panel problem after a hard reset (albeit only for a few seconds). Perhaps Diah can chime in and let me know if my assumptions are correct.Comment
this is all just theories, could be or could be not. no one able to repair T-CON. including me, but we can attempt testing to be more close to the issue causer.EazyBone Clearly my knowledge is somewhat limited here, but I think that the idea of Diah's "freeze" suggestion is that the eMMC chip has rewritable memory that may be "stuck,' with the error flag set. (That would explain why the pattern test isn't working even though I unplugged the TV while the screen was working.) So the thought is that freezing it may allow the memory to get unstuck so the flag would be cleared. If that were to happen then the TV would actually be fixed. Of course, it would only be truly fixed if the cause of the problem was just a random occurrence that put the eMMC into a bad state. The eMMC would ultimately need to be replaced if it's failing, and clearly nothing would be fixed if the eMMC's error was caused by a problem within the panel. My hope is that it's just related to the eMMC... that seems possible given that the TV is able to turn on with no visible signs of a panel problem after a hard reset (albeit only for a few seconds). Perhaps Diah can chime in and let me know if my assumptions are correct.
until now we do know only
1- there are SOS flag coming from T-CON / Panel side ( disconnecting the lower LVDS TV remain on )
2- necessary Voltage ,the PSU provide the set and they are fine at T-CON / Panel side
3- its not resolution issue ( when you left the set after hard reset on first page select region the error flag come again )
4- from yours photos panel displaying perfect picture with out distributing in image for few seconds
5- by terminated the panel power (EVDD) in case if you did it correct the error flag remain.
6- no success by testing T-CON Panel with stand alone test.
also the finger now only on the T-CON only which caused this error.
as you are with limited know how , replacing T-CON On Sony and on OLED Set not easy and going smooth as some one thinking just put in and screw it to chassis... there are much problem could appear , the marriage of New T-CON with Panel & with Main boards. ...... burring in image from the old set which the T-CON come from.
this why i do try... just try to let the set run longer than few seconds.. thought set at condition running for short time are very hard to solve and to know the reason rather one with out function.
so let stop talking theory and all the tests i do know i wrote choice what are suitable to you from freezing to lamp test to trick out the SOS Flag.
Great summary and advice Diah, your a fine troubleshooter, you don't ASSUME anything and you explain everything very well, that takes lots of patience, and you get EXTRA points for not taking crap from anyone, well done.
EazyBone That's what I was thinking until I read Diah's comment about it being a non-trivial task with OLEDs... It sounds like there may be data that needs to be transferred (or something like that). I can certainly swap the boards, but I don't have the hardware to program an EEPROM or swap a surface mount chip. I wonder if this can be done manually with a lot of enthusiasm but limited tools?Comment
Okay, So I connected everything except the 2 EVDD sockets on the TCON and did a hard reset. After doing that I pressed the power button. The power supply didn't click, but about 5 seconds later the optic light turned on briefly and went out again. A few seconds after that the optic light came back and stayed on. I left it in this state long enough to convince myself that it was stable. Then I pressed the power button again. This time I heard the power supply click on and off, the optic light turned off, and the power LED began flashing 4 times.
I then connected the EVDD sockets and found no change. (The TV turns on after a hard reset for 10-15 seconds and then turn off again.)Comment
who wrote here to press the power to turn off.... my question was only to see if it remain on at this test and it does. so SOS flag caused by Panel module."" my post #46 point 5 ... if you do it correct ""Okay, So I connected everything except the 2 EVDD sockets on the TCON and did a hard reset. After doing that I pressed the power button. The power supply didn't click, but about 5 seconds later the optic light turned on briefly and went out again. A few seconds after that the optic light came back and stayed on. I left it in this state long enough to convince myself that it was stable. Then I pressed the power button again. This time I heard the power supply click on and off, the optic light turned off, and the power LED began flashing 4 times.
do this test again... after the optic come on and remain on.... give time round 5 minute to remain on.... while its on plug back first only the EVDD socket at the middle , screen should come on and hopefully remain on.. try to capture the screen with camera to see what it will display at time you plug the EVDD socketLast edited by Diah; 02-22-2024, 01:58 AM.Comment
I did leave it on for a couple of minutes to make sure that the light remained on, although it wasn’t as long as 5 minutes. I pressed the power button after a couple of minutes because even though the optic light was on, I hadn’t heard the relay click on the power supply. This suggested to me that the TV was probably in standby mode. (I still believe this to be true.)
I’ll do the same test again tonight, but try harder to get the TV in a mode where the relay is engaged. If successful (and the optic light stays on) then I’ll attach the EVDD as you suggested.Comment
by Dan20701Hello all just wondering if anyone knows how to do a hard reset on this model, XVR58C-21D-8CH-V1.1 ?
There are videos on youtube for every other model but this one, I do not have the switch on the board or reset jumpers.
https://www.youtube.com/watch?v=Ao7EwIMDx_c
I do have 2 little pads right next to the firmware chip, I have shorted these and powered the system on and waited a wile
with no luck. I will add picture of these 2 pads.
I do have the bin file from the firmware if its any good to anyone maybe able to edit out the pass I am not sure.
Hi friends.
I have a Plaud Note that's asking me to unlink the SSO account.
Is there a solution to unlink this device?-
10-27-2025, 09:40 AM -
Hey there people
While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
This is what I tried, but not in any order.
Google
YouTube
BIOS
Command Prompt (administrator privileges)
On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...-
Channel: Schematic Requests ONLY!
10-25-2025, 02:22 AM -
by ash91Hello gentelmen .... this is my first post and sorry for my bad english,
so my proplem is my laptop keep losing hard drive even if i but the
hard disk in the cady (the box that can replace the dvd rom with hard disk)
when i turn the laptop on the massage that said no boot media found pop on
the hard disk is fine and to be sure i try another hard
i also update my bios to the last update
the 5 volt is present on the hard connector on the motherboard
the dvd rom work fine when i but a windows dvd in it
also when i boot from flash... -
by madura2010Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
i checked the connectivity of ribbon=good communication with hard and motherboard
changed hard disk and checked=3f0 error persist
sata power=+5v available
Then checked data capacitors=all good
Then checked data lines path connectivity to pch=all good
reflashed... - Loading...
