Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4499
    • Italy - Milan
    #81
    You are right with doubt on power board, if 1²v (sorry, my phone screen keyboard is getting mad) or ²4v are low then tcon does not start well and tells the MB it hàs à problem, but your action of buying à power board is so rookiē, power boards càn be easily tested on bench, and tcon? have you followed my purchàse advices? For the tcon doubts i understand but i only pàrtiàlly agree.. i will explain in future..
    • odie34
      • May 2016
      • 41
      Davi.p Both the T-Con and power board are returnable. I could see trying to fix the original power board if it turns out that that’s the problem, although in that case I’d probably sell the one I bought rather than returning it. (It doesn’t seem right to return a part that aided in the repair… and I got a good deal on it.) The bottom line is that I was running out of patience and needed to be able to definitively rule some things out.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4499
        • Italy - Milan
        #83
        Try a first step with simple hair dryer at max temp, this is not a reflow obviously but we don't need it i think..
        • odie34
          • May 2016
          • 41
          I received the replacement power board and T-Con today. I installed them one-at-a-time, but the problem still remains… The TV turned on and acted fine, but then shut down a few seconds later. At this point the only things left are the main board and the panel. The panel seems more likely given the other tests we’ve done, although the screen looks perfect for the few seconds while the TV is on. I suppose it could be a problem with the LVDS cable, but how often does that happen? Any suggestions?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4499
            • Italy - Milan
            #85
            5 flashes seems panel at this point but try at power off with hairdryer on the MB processor, then turn it on, if the defect varies bad processor soldering, try also to Ram/Rom..
            • odie34
              • May 2016
              • 41
              I know that you can remove one of the two cables between the T-Con and the panel on standard (non-OLED) TVs to help identify where a short is in the panel. Can you do the same thing with OLEDs or might that damage something? (It would be a pretty definitive test if the TV stayed on when connected to one side but not the other.)
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4499
                • Italy - Milan
                #87
                you can do it
                • odie34
                  • May 2016
                  • 41
                  Sorry that it's taken so long, but I wanted give a quick update to everyone who has helped me through this process... Unfortunately it turns out that the problem was a bad panel. Over the course of my tests and board swaps I was finally able to get definitive proof, which can be seen about 12 seconds into the video at https://youtu.be/HD1rEY37GRY
                  You can see a thin black line about 10% down from the top of the screen. Very disappointing, but it was fun working on it and I really wanted to thank you all for your help. Hopefully I'll have better luck next time.
                  • Diah
                    • Feb 2013
                    • 6460
                    still yours OLED usable, don't trash it, try to isolated the error sos signal rail... or add load like lamp to the EVDD line to handle and take any over load current so the the SOS will not trick on..
                    • odie34
                      • May 2016
                      • 41
                      Darn! I didn't realize that that was a possibility. I thought that there was nothing to do if there was a short in the screen so I recycled it. Next time...
                      • EazyBone
                        • Jun 2023
                        • 1356
                        • United states
                        #91
                        The boards were worth like $200-300 on eBay also
                        • odie34
                          • May 2016
                          • 41
                          I still have the boards. I'll list them when I have time...
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4499
                            • Italy - Milan
                            #93
                            it could have tried something to save it, if you are in time tell me..
                            • odie34
                              • May 2016
                              • 41
                              Sorry.. it's already gone, but I'll know for next time. Thanks for all of your help.
                              • saticon
                                Aka James
                                • Aug 2025
                                Hi
                                so I’ve been gifted a XR55A80J also with 5 flash.
                                When I first got it, it already had been faulting and the person had already bought a new tv. I took it home and it worked for about 2 weeks without issue.
                                if it did error, it would do it early in the morning but after pulling the power and trying again it turn on.
                                but then Monday morning it didn’t want to turn on. So I opened it and gave all the connectors a bit of a reseat and a light coat of deoxit.
                                This worked once in the week, seemed to help. But this time it didn’t.
                                i usually will swap parts because i do them in warranty. But I had a look at the power.
                                so yeah I did try panel test mode, but it doesn’t want to do it and as I read in this thread , there is a newer tcon with update firmware..
                                anyway the fault, panel works perfectly when it turns on no dead lines. But now it doesn’t want to turn on.
                                its almost as if sitting for a long while made it work (like components or solder joints were settling.
                                but you mention the voltages and the linear regulators are an issue. Voltages did seem a bit low when I put the converter into jumpered state. Why would the switch mode controllers be throttling it so low (there is a load issue?)
                                anyway, you seem near as knowledgeable as our sony tech lead. I think it’s a tcon but I’m wondering if it’s a regulator or a dry joint on the memory or processor(lg)?
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4499
                                  • Italy - Milan
                                  #96
                                  please open your own thread and copy paste all your info..
                                  • Dan20701
                                    Dahua XVR Hard Reset, Locked 8 Channel CCTV NVR
                                    by Dan20701
                                    Hello all just wondering if anyone knows how to do a hard reset on this model, XVR58C-21D-8CH-V1.1 ?
                                    There are videos on youtube for every other model but this one, I do not have the switch on the board or reset jumpers.
                                    https://www.youtube.com/watch?v=Ao7EwIMDx_c
                                    I do have 2 little pads right next to the firmware chip, I have shorted these and powered the system on and waited a wile
                                    with no luck. I will add picture of these 2 pads.
                                    I do have the bin file from the firmware if its any good to anyone maybe able to edit out the pass I am not sure.
                                    02-28-2025, 09:13 AM
                                  • mateusassuncao
                                    Plaud Note hard reset
                                    by mateusassuncao
                                    Hi friends.
                                    I have a Plaud Note that's asking me to unlink the SSO account.
                                    Is there a solution to unlink this device?
                                    10-27-2025, 09:40 AM
                                  • sheffieldyorky
                                    ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
                                    by sheffieldyorky
                                    Hey there people
                                    While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
                                    This is what I tried, but not in any order.
                                    Google
                                    YouTube
                                    BIOS
                                    Command Prompt (administrator privileges)
                                    On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
                                    10-25-2025, 02:22 AM
                                  • ash91
                                    Hp pavilion 15 not detect hard drive
                                    by ash91
                                    Hello gentelmen .... this is my first post and sorry for my bad english,
                                    so my proplem is my laptop keep losing hard drive even if i but the
                                    hard disk in the cady (the box that can replace the dvd rom with hard disk)
                                    when i turn the laptop on the massage that said no boot media found pop on
                                    the hard disk is fine and to be sure i try another hard
                                    i also update my bios to the last update
                                    the 5 volt is present on the hard connector on the motherboard
                                    the dvd rom work fine when i but a windows dvd in it
                                    also when i boot from flash...
                                    06-07-2023, 01:45 PM
                                  • madura2010
                                    DAY11AM6E0 hard disk drive and optical disk drive not detected
                                    by madura2010
                                    Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                                    i checked the connectivity of ribbon=good communication with hard and motherboard
                                    changed hard disk and checked=3f0 error persist
                                    sata power=+5v available
                                    Then checked data capacitors=all good
                                    Then checked data lines path connectivity to pch=all good
                                    reflashed...
                                    03-12-2023, 09:09 AM
