Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
  • odie34
    • May 2016
    • 41
    Here are the voltages:
    The fuses on the top left (F1, F3 and F5) all measure 21.6V on both sides.
    FL2 and FL1 (below the fuses) both measure 2.24V on both sides.
    R77 measures 12.7V on both sides.
    R76 measures 0V on both sides.
    I'm hoping that 0V at R76 tells us something...
    • EazyBone
      • Jun 2023
      • 1356
      • United states
      Diah the OLED I had that was broken I was still able to get it to color cycle a bad picture and mine also had a emmc no?
      https://www.badcaps.net/forum/troubl...-5-blink/page3
      • Diah
        • Feb 2013
        • 6460
        disconnect the screen ribbon close to R76 and test again​
        yours are not in deep sleep
        • odie34
          • May 2016
          • 41
          Still 0V with the ribbon cable near R76 disconnected. (I'm guessing that that's a good thing.) Do you want me to try it with the other ribbon cable disconnected?
          • Diah
            • Feb 2013
            • 6460
            no need... just measure the R with beep ton and the diode D1 with diode mode,,, you can compare value of R76 with R77
            if every things fine follow my post #20 if still same result replace t-con
            • odie34
              • May 2016
              • 41
              Sorry... I'm not exactly sure what you're asking (or how to compare the value of R76 with R77). I unplugged the TV and measured resistance of R76 and R77. Both measured 0 ohms, I assume because of the circuit they're in. The diode measured 1.63 in one direction and .146 in the other direction. Does this answer the question?
              • lotas
                • Jan 2016
                • 4786
                • Russia
                #27
                R76 - if this jumper sits on the ground, then there will be no voltage on it.
                • Diah
                  • Feb 2013
                  • 6460
                  every things are fine... do the freezing test to the eMMC as i wrote at post #20
                  lotas
                  R76 are the LOCK2 lune connect via the sandwich boards
                  • odie34
                    • May 2016
                    • 41
                    That jumper doesn't appear to sit on ground, and even if it did, wouldn't we still expect to see non-zero voltage on the other side of R76? I measured resistance from the bottom of R76 to ground and it measured 3.7K. Then I reversed the polarity and it measured 8.2K. Interestingly, I got the same values when testing from the top of R76. As stated earlier, resistance is 0 across the resistor (in either polarity).
                    As you know, I'm no expert. But is it possible that the resistor is bad? (I'm not used to seeing bad resistors. I've seen lots of bad transistors, diodes and capacitors, but I can't remember seeing a bad resistor.) It would be nice to have proof of a bad TCON.. Is this it?
                    • odie34
                      • May 2016
                      • 41
                      I don't have any freeze spray, so that test will need to wait unless you can suggest an alternative. And if the spray causes the TV to stay on longer, does that mean that the TCON needs to be replaced, or does it mean that the panel is drawing too much current (so it's a panel problem)?
                      • lotas
                        • Jan 2016
                        • 4786
                        • Russia
                        #31
                        Originally posted by Diah
                        lotas
                        What does LOCK2 lune connect have to do with it?
                        • Diah
                          • Feb 2013
                          • 6460
                          electronic repair need patient... no alternative. right now... eMMC if it had bad sector and it could recovered with freezing ( this happen many time ) the cheapest way to repair.. other about the panel are not on my mind... up to you you can judge as you wish as well you scrap it if you like. LOL
                          • Diah
                            • Feb 2013
                            • 6460
                            • odie34
                              • May 2016
                              • 41
                              So are you saying that freezing the eMMC could be a permanent fix? And are you also saying that you don't think it's a bad panel?
                              • lotas
                                • Jan 2016
                                • 4786
                                • Russia
                                #35
                                Where does this confidence come from? You don’t know how control points are marked.
                                • Diah
                                  • Feb 2013
                                  • 6460
                                  Where does this confidence come from? You don't know how control points are marked.
                                  don't be rude and funny over here.. by playing corrector man.. if you have some things help the owner of the threat welcome.
                                  no place to explain how are LOCK work .. it had IN and OUT for adjusting the currents....... you wrote GND and i said NO. and the ownet give you the measurement with GND.. so could you stop.--?
                                  @odie34
                                  try it first and then you will know if you have luck or not. or you don't want to spend 1$ on air Can...?
                                  • lotas
                                    • Jan 2016
                                    • 4786
                                    • Russia
                                    #37
                                    Check the supply voltage at the outputs of the DC/DC converters (some of which they are signed for, some of which they are not signed for), the power supply may be too low or unstable.
                                    • EazyBone
                                      • Jun 2023
                                      • 1356
                                      • United states
                                      #38
                                      Use can of air duster and turn it upside down. Do not shake it before doing this. This will freeze the chip. Pretty sure it's just a test to SEE if it's bad, it won't fix it. But maybe it does. I'm interested to see.
                                      • odie34
                                        • May 2016
                                        • 41
                                        Diah I’m happy to get a can! I had assumed that the TV had a bad panel and that I wouldn’t be able to fix it. Now I’m hopeful and wanted to confirm that you think that the panel may be okay, and that the only problem may be the TCON. It’s an added bonus if the cold spray could actually fix it. (I thought it was just a diagnostic tool.) I’ll try to pick some up tomorrow.
                                        • Diah
                                          • Feb 2013
                                          • 6460
                                          Diah I'm happy to get a can! I had assumed that the TV had a bad panel and that I wouldn't be able to fix it. Now I'm hopeful and wanted to confirm that you think that the panel may be okay, and that the only problem may be the TCON. It's an added bonus if the cold spray could actually fix it. (I thought it was just a diagnostic tool.) I'll try to pick some up tomorrow.
                                          from yours both photos of the screen..the panel module look fine to me... but in case as you wrote it could be pull or drop currents... you can use Car filament lamp ( Lamp for trucks with one Filament 24V) or ( one with 2 Filament 12V ) we connect the lamp direct on the EVVD line and chassis ... any drop or pull over currents the lamp will show us by remain on or turn off.
                                          one things more from my side as last comment .. i marked for you the line of SOS signal. at the lower LVDS socket.. if we take it out from circuit and let the line which come from MB connect via 1KR to chassis the TV will remain ON. so you can see if the screen had bad cells.
                                          good luck
                                          • Dan20701
                                            Dahua XVR Hard Reset, Locked 8 Channel CCTV NVR
                                            by Dan20701
                                            Hello all just wondering if anyone knows how to do a hard reset on this model, XVR58C-21D-8CH-V1.1 ?
                                            There are videos on youtube for every other model but this one, I do not have the switch on the board or reset jumpers.
                                            https://www.youtube.com/watch?v=Ao7EwIMDx_c
                                            I do have 2 little pads right next to the firmware chip, I have shorted these and powered the system on and waited a wile
                                            with no luck. I will add picture of these 2 pads.
                                            I do have the bin file from the firmware if its any good to anyone maybe able to edit out the pass I am not sure.
                                            02-28-2025, 09:13 AM
                                          • mateusassuncao
                                            Plaud Note hard reset
                                            by mateusassuncao
                                            Hi friends.
                                            I have a Plaud Note that's asking me to unlink the SSO account.
                                            Is there a solution to unlink this device?
                                            10-27-2025, 09:40 AM
                                          • sheffieldyorky
                                            ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
                                            by sheffieldyorky
                                            Hey there people
                                            While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
                                            This is what I tried, but not in any order.
                                            Google
                                            YouTube
                                            BIOS
                                            Command Prompt (administrator privileges)
                                            On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
                                            10-25-2025, 02:22 AM
                                          • ash91
                                            Hp pavilion 15 not detect hard drive
                                            by ash91
                                            Hello gentelmen .... this is my first post and sorry for my bad english,
                                            so my proplem is my laptop keep losing hard drive even if i but the
                                            hard disk in the cady (the box that can replace the dvd rom with hard disk)
                                            when i turn the laptop on the massage that said no boot media found pop on
                                            the hard disk is fine and to be sure i try another hard
                                            i also update my bios to the last update
                                            the 5 volt is present on the hard connector on the motherboard
                                            the dvd rom work fine when i but a windows dvd in it
                                            also when i boot from flash...
                                            06-07-2023, 01:45 PM
                                          • madura2010
                                            DAY11AM6E0 hard disk drive and optical disk drive not detected
                                            by madura2010
                                            Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                                            i checked the connectivity of ribbon=good communication with hard and motherboard
                                            changed hard disk and checked=3f0 error persist
                                            sata power=+5v available
                                            Then checked data capacitors=all good
                                            Then checked data lines path connectivity to pch=all good
                                            reflashed...
                                            03-12-2023, 09:09 AM
