Samsung LE32M87BD - stuck in standby - blinking LED
  • noledud
    • Dec 2013
    • 413
    • united kingdom
    #61
    Re: Samsung LE32M87BD - stuck in standby - blinking LED
    got a replacement main board and its still the same so looks like i was wrong in the first place, im now thinking it is the PS due to the strange low voltages. The seller has one and i will contact asking if i can exchange. Are you thinking it is the PS also as i don't want to swap and it not be that
    • brandrade04
      • May 2014
      • 3
      • Portugal
      #62
      did you find de solution for this problem?? I have a TV with the same behavior!!
      Thk!!
      • underbird
        • Oct 2013
        • 5
        • romania
        #63
        Man the solution its very simple ,i solved same problem with my samsung lcd le40r81bxxec.
        change capacitor on power board and after write memory dump all willl be fine
        • underbird
          • Oct 2013
          • 5
          • romania
          #64
          change capacitor on power board and after write memory 24c256 dump all willl be fine
          epp
          • brandrade04
            • May 2014
            • 3
            • Portugal
            #65
            Hello underbird,
            I am not a expert, could you explain it with more detail?? Which capacitor?? Write memory dump??
            Thank you!!
            • senndogg
              • Dec 2011
              • 383
              • Albania
              #66
              Hello guys!
              I think i got the solution to this M87BD with this symptoms:
              -Constant rebooting.
              -Turning on after circa 30min with stripes and faulty image.
              Fortunately i have a similar one in my workshop with a faulty T-con, the infamous AS15, but thats another story. I started swapping boards. PSU was ok. i didnt want to remove the mainboard so next was the scaler bn41-00895b.
              This was the culprit. TV went on and picture was ok.
              My guess was reflowing and reballing the DNIe and the Micronas chips.
              But no luck. Anyway thanks to the fellows of the Polish site, i managed to succeed with removing the capacitor C6108_FRC (1uF/50V). I soldered another electrolytic similar one. TV is running flawless.
              I hope this helps. Credits go to the polish technician, i just used google translate.
              • cecherel
                • 3
                • Romania
                #67
                Originally posted by senndogg
                Hello guys!
                I have almost the same simptoms with this model (continous loop, only starts with heat blower on the scaler board, and after a while it displays some horizontal lines) i replaced the capacitor today and i hope it will work, i'm excited, i was looking for a solution for about 6 months.
                I'll get back with an answer.
                • cecherel
                  • 3
                  • Romania
                  #68
                  It works !!! Thank you !!! Thanks also to the polish guy!
                    Thanks for the tips, did you measure the cap to see what kind of failure it has?
                    • cecherel
                      • 3
                      • Romania
                      #70
                      I've measured the cap and it had 0.8 uF. I just tried heating the bad cap and when heated it goes at 1uF.
                        Probably more of an ESR thing than anything. Could cause a voltage regulator to become unstable.
                        • zipak
                          • Aug 2012
                          • 5
                          • Czech republic
                          #72
                          Thanks for info about 1uF cap. I changed this cap to new one and TV work again. Than I measured the Capacity and ESR of the original cap and measurement shows increased ESR value than expected. Once again thank for tip.
                          Bretislav
                          • johnkte
                            • Jun 2015
                            • Greece
                            #73
                            have the same problem in a LE32M86BD. I was ready to try reflow cpu, but saw this post. Changed the 1uF capacitor and it simple worked. Capacitor seems to have very large ESR. Thank you guys !!!
                            P.S. Respect to polish guy !!
                            • ammarben
                              • May 2013
                              • 63
                              • algeria
                              #74
                              Thanks for the tips
                              • steviewonder
                                • Dec 2013
                                • 183
                                • england
                                #75
                                1000uf,10v under the screening can is faulty. a warm-up with a hairdrier should give results.there's two of them,but generally only the lower one of the two dries out.Located under the screening tin on the signals pcb.
                                • steviewonder
                                  • Dec 2013
                                  • 183
                                  • england
                                  #76
                                  oops, this only applies to the R87BD...but same symptoms
                                  • brandrade04
                                    • May 2014
                                    • 3
                                    • Portugal
                                    #77
                                    Hello all,
                                    some days ago I visited this post and replaced the C6108_FRC (1uF/50V), that solved my problem too!!
                                    Thanks!!!
                                    • Joun
                                      • Jul 2011
                                      • 191
                                      • Greece
                                      #78
                                      This is what internet is for..
                                      Replace that cap(it had ESR about 500 Ohms! ) and TV is working for some hours now..
                                      Thank you!
                                      • YeOldeGinge
                                        • Nov 2014
                                        • 30
                                        • Telford and Wrekin
                                        #79
                                        I had something similar with one of my TV's I think it may be a short on one of the ccfl tubes (Back light) or a shorted back light led(Back light) depending on the type of back light it has.
                                        Hope this helps
                                        YeOldeGinge :P
                                          09-07-2024, 05:50 AM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • Ukdigger
                                          Samsung UE46f5000AK Stuck on Standby
                                          by Ukdigger
                                          When the Main board is disconnected, the back lights are off but tapping on the chassis makes them light up and all voltages are then good. Connecting the main board up makes the TV work normally until moved. LED INERFACE STRIP BN41-01971A has a short on the first 2 pins on the left of the picture, the cable tests good. All the other pins and all LED strips test good. Is there an easy way to fix the short or do I need a new interface. Any help would welcome.
                                          PSU number bn44-00610A L46SF_dpn
                                          1 B13v 12.4
                                          3 B13v 12.4
                                          5 Vamp 12.4
                                          7 Vamp 12.4
                                          9 GND...
                                          08-08-2024, 09:17 AM
                                        • Rusenga
                                          Samsung UA39EH5003R Stuck on standby
                                          by Rusenga
                                          Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
                                          Connector CNM803:
                                          TV ON
                                          Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
                                          TV OFF
                                          Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
                                          09-18-2021, 11:51 AM
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
