samsung le32s86bd main board or psu fault?
  • charlierfc
    • Mar 2013
    • 93
    • scotland
    Hi everybody hope you are all well.
    ok, i have a samsung le32s86bdx/xeu here,(not the model i stated on the title! i missed a bit)
    When i first turned on the set it powered as i should, the picture was fine backlight fine ect, then after about 30 sec the picture started to brake up, the back light started flickering untill the backlight went out.
    Now when i power on the set i get the sound from the speakers for a bit but no backlight.The tv cycles from standby to on with no backlight to off and again continuous.
    After opening the set i see no bad caps(looks like they have been previously tested as the tops are marked with a pen!)
    iv checked the outputs from psu, they seem fine,well maybe a bit high as the power to inverter is 27.7 not the 24 stated.
    Im wondering, would this mean the main board is at fault? or is the higher reading from the psu causing the fault?
    Any ideas?
    thanks in advance, Charlie.
    Last edited by charlierfc; 01-08-2014, 03:24 PM. Reason: missed the rest of model number
  • anotherdude
    • Feb 2013
    • 488
    Re: samsung le32s86bd main board or psu fault?
    try giving the main board some heat with a hair dryer near the shielded area
    sounds similar to what i've had previously
    or wait for others to chime in, as i'm not as clued up as them but a small ammount of heat won't do any harm
    • charlierfc
      • Mar 2013
      • 93
      • scotland
      Good idea, ill give it a go. maybe some small caps on the main boad.iv not inspected fully as the battery on my cap tester and multi meter low and dont want to give false readings
      • charlierfc
        • Mar 2013
        • 93
        • scotland
        ok. im having a steady 27.3 v to the inverterboad yet the backlight remains off.
        I have visually inspected the transformers they look ok, iv checked the small fuses they test ok.
        ill fully test tomorrow when i have fresh batterys.
          Post good clear pictures of the boards, model number of the power supply board BN-XXXXX????
          Also check your batteries of your meter, when batt is low, the meter read out will be higher than normal . The backlights will not come on until the inverter gets the BL_ON (or INV ON) from the main board. You can try disconnecting the cable between the power supply and the main board to see if the backlights will come on, it may have built-in pull up resistors on the power supply board.
            Many backlight inverters have an over voltage circuit which engages after about 26V to shut off the inverter.
            • charlierfc
              • Mar 2013
              • 93
              • scotland
              OK-
              The reading i get from the rail from psu, leading to the main board (after fresh battery in meter!)
              1 n/c actual 0.0
              2 13v " 12.2
              3 13v 12.2
              4 gnd 0.0
              5 5.3 5.2
              6 5.3 5.2
              7 5.3 0.0
              8 5.3 0.0
              9 gnd 12.0
              10 gnd 0.0
              11 gnd 5.2
              12 12v 3.4
              these readings seem odd where ground is getting 12v?
              im wondering, is whats printed onm the psu what is ment to be coming out that rail?
              • selldoor
                Slow Learner
                • 7870
                What did you get on the 24v connector
                What are you using as ground- should be a ground screw
                • charlierfc
                  • Mar 2013
                  • 93
                  • scotland
                  i was using a spare screw hole on the panel frame.
                  what do you mewan on the 24v connector? to the inverter board? i think it was 24.4 after i put the new batterys in my meter as previously i had 27! my meter was flashing the battery change icon to be fair!
                  • charlierfc
                    • Mar 2013
                    • 93
                    • scotland
                    same reading as above using the earth screw with the earth wire attatched.
                    same reading from the inverter 24.4
                    bn41-00879b i think is the main board number
                      Unplug the main board, do you get 12V and 13V stable?
                      • selldoor
                        Slow Learner
                        • 7870
                        Yes that is what I meant - you didnt report the retest with new battery
                          "1 n/c actual 0.0
                          2 13v " 12.2
                          3 13v 12.2
                          4 gnd 0.0
                          5 5.3 5.2
                          6 5.3 5.2
                          7 5.3 0.0
                          8 5.3 0.0
                          9 gnd 12.0
                          10 gnd 0.0
                          11 gnd 5.2
                          12 12v 3.4"
                          Still not providing us the pictures and the model number of the power supply board.
                          Can we see the pictures of this connector? Is it double-row pin? It is missing the ps_on , bl_on (inv on) label, etc.
                          • charlierfc
                            • Mar 2013
                            • 93
                            • scotland
                            do thewse pics help?
                            ill a\dd more wehwen im back, im getting dragged shopping!
                            • charlierfc
                              • Mar 2013
                              • 93
                              • scotland
                              Ok, another question...would a faulty tcon cause the backlight to remain off?
                              When the tv was on it worked fine, i moved it thern the screen filled with vertical lines. Now the tv is just cycling again, any help wouild be appreciated
                              • multimeter
                                • Jan 2011
                                • 739
                                • united kingdom
                                no,you would just have a white screen,from the backlights with no tcon
                                reseat the ribbons on the tcon and mainboard
                                fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
                                please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
                                • charlierfc
                                  • Mar 2013
                                  • 93
                                  • scotland
                                  Tv still cycling with no backlight now.
                                  When the tv is cycling i dont have any output from oth b/l output from the psu although the pin next to it called the on/off has a 3.5 the 24v detect also has 5.4
                                  • charlierfc
                                    • Mar 2013
                                    • 93
                                    • scotland
                                    Ok. The tv has been cycling for 10 min now the backlight has come on. The b/l pin now has 5.2 v.
                                    • multimeter
                                      • Jan 2011
                                      • 739
                                      • united kingdom
                                      that sounds like cap issues,have you heated the board to see if the fault dissapears?
                                      • charlierfc
                                        • Mar 2013
                                        • 93
                                        • scotland
                                        What board, the psu? Or the main board.
                                        I do have a capacitence tester...and a hair drier lol, but its hard to pin point as it sometimes works strait away. Would a cap problem cause screen distortation? Last time it cam on with bit of yellow distortation allomg the screen. Its fine this time though
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • ygorsan
                                          by ygorsan
                                          🧩 Problem Summary:
                                          • I
                                          07-28-2025, 08:34 AM
                                        • Lee M.
                                          Samsung UN75RU8000FXZA bad main board?
                                          by Lee M.
                                          When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                                          11-08-2023, 07:46 PM
                                        • JDC
                                          (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                          by JDC
                                          ONN 100012588
                                          Issue: No Power, Then Rebooting After Main Board Change
                                          Short answer: replace main board and power board
                                          Technical answer: replace main board and Q306 & Q307 on power board.
                                          Long answer:
                                          TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                          07-15-2022, 07:39 AM
