Samsung LE26A457C1D Power problem, It Banged
    Re: Samsung LE26A457C1D Power problem, It Banged
    Any standby output from power supply?
    • aar5384
      • Jan 2014
      • 82
      • England
      Nothing at all, it blws the slow blow 6.3 everytime
        Is there a BN44-###### number printed on the power board? To look up schematic.
        • aar5384
          • Jan 2014
          • 82
          • England
          Bn44-00214a
            Great. Got it
            So it is FP801S that is blowing? (6.3AH)
            • selldoor
              Slow Learner
              • 7870
              #26
              You could start checking for full shorts. on all the big components. Perhaps start with the
              3 diodes at the end of the board furthest from the mains socket.
              I would still consider making up a light bulb.
              You did get the bridge in the right way round? and test it again.
              Perhaps a clear picture of the back of the board would help us
              • aar5384
                • Jan 2014
                • 82
                • England
                #27
                Yep thats the fuse blowing, including the one in plug lead
                I thought about the light bulb but its something i couldnt get my head around and the shop round here only sells some nasty looking things that look like there made for offices and mine are led :/
                T rectifier oh cock! its in wrong way round! i put it in writing facing forwards instead of cut corner to the left lmao! Hangs head in shame!
                I will turn it around in a couple of hours when i get back and let you know
                Thanks for that :P i feel a right Noob now
                • selldoor
                  Slow Learner
                  • 7870
                  #28
                  Better test it again when you take it out, in case you have cocked sorry cooked it.
                  • aar5384
                    • Jan 2014
                    • 82
                    • England
                    #29
                    Thinking the same thing, good job I ordered 2 now when I turn it around , I Will be edging away from the plug socket as I knock it in with a brush pole expecting a loud bang lol
                    • aar5384
                      • Jan 2014
                      • 82
                      • England
                      #30
                      Ok so ive taked the bridge out and tested it and its fine, however it still blew the fuse. I then started testing all the diodes so i disconnected them all and checked all of them and all again seem fine :/
                      • aar5384
                        • Jan 2014
                        • 82
                        • England
                        #31
                        And thats the underside
                          If you power it up without the bridge installed does the fuse still blow?
                          • aar5384
                            • Jan 2014
                            • 82
                            • England
                            #33
                            My soldering iron resembles that of a iron thats used to stamp burns into the ass of a cow, and if i remove it again the board around the bridge might be destroyed beyond repair so im a bit scared to take it out unless its the only way
                            it only blew the 5 am fuse in the plug this time and not the one on board, i was looking and forgive me i dont know what some of them are but if the green thing above power connector or resistor or the white box marked 330n K things that connect straight after fuse line between live and negative, do they fail often and allow current to short out?
                              They can, there's also usually a MOV which can fail short, it is surge protector.
                              • aar5384
                                • Jan 2014
                                • 82
                                • England
                                #35
                                Wonders what the MOV is
                                • aar5384
                                  • Jan 2014
                                  • 82
                                  • England
                                  #36
                                  Just out of poking around i poped out resister RX801S and tested it and the meter didnt read anything from it either way around :/
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    #37
                                    got to say had to laugh at this i can imagain you doing it lol
                                    • aar5384
                                      • Jan 2014
                                      • 82
                                      • England
                                      #38
                                      I realy did do it lol
                                      I remember when i was like 6 or 7 and had a little black and white tv with a music tape player on in the bedroom , i went to plug it in one morning and we had plug sockets without on/off switches on them, and i pushed the plug in and it went was a bang and sparks flew out of the plug arc ing like realy scarey and the wire fell out of the plug and i kinda craped myself then too
                                        MOV:- http://en.wikipedia.org/wiki/Varistor
                                        for future ref.
                                        • aar5384
                                          • Jan 2014
                                          • 82
                                          • England
                                          #40
                                          Ok it didnt blow after i took out the bridge
                                            09-07-2024, 05:50 AM
                                          • jesterace
                                            Samsung UE46ES8000 Blown fuse but no other signs of short
                                            by jesterace
                                            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                            09-11-2024, 03:14 PM
                                          • howardc64
                                            Samsung UN55JU650DF network/streaming problem
                                            by howardc64
                                            Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                            This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                            07-09-2025, 12:44 PM
                                          • alro7779
                                            Samsung UN55MU6103F video problem; has colored stripes on the display
                                            by alro7779
                                            Hello, everyone!
                                            A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                            09-27-2025, 11:29 PM
                                            09-06-2024, 11:40 PM
