Sony KDL-52V4100 13 blink code
  • tibimakai
    • Jan 2012
    • 3680
    Re: Sony KDL-52V4100 13 blink code
    I have tried the resistor on both balancers and it didn't change anything.
    • tibimakai
      • Jan 2012
      • 3680
      I have replaced all the ccfl tubes, still didn't fix the issue.
      I have done some measurements on the balancers with the common harness removed and the on the left side test points were much lower then the right ones. Around 4-5.5V on the left and the right were high as before.
      Not sure if this means anything though.
      It's very confusing this TV, since it has two balancers and two inverters, it's a first for me a TV like this.
      • tibimakai
        • Jan 2012
        • 3680
        Should I have a resistor at each balancer board?
        • tibimakai
          • Jan 2012
          • 3680
          Any help with this TV?
          I'm lost with it.
          • tibimakai
            • Jan 2012
            • 3680
            In the manual it says that, that side where the tubes are darker, there the problem is.
            But if I read about how many times wants to start up, like three times if it's an inverter problem is detected, I don't see that happening. I don't even see two time startup either, which suggests a balancer error.
            To me, it seems like it's starting up once and then shows the error code.
            The darker side is the D4 inverter side.
            If it would be an inverter problem, the tubes wouldn't even turn on, am I right?
            They turn on for two seconds, so the inverter is fine. Though in the manual it suggests an inverter problem in this case.
            I'm very confused, I would appreciate some help. There are four balancer boards and two inverters. It would be to expensive, to start replacing them all, one by one.
            • tibimakai
              • Jan 2012
              • 3680
              Bud, should I solder in a 100 Ohm resistor to each side, left and right balancer?
              How could I locate the bad board first? At least, if I could locate the bad board, then I could check for bad components.
                should I solder in a 100 Ohm resistor to each side: Yes.
                • tibimakai
                  • Jan 2012
                  • 3680
                  OK, I have tried that way too.
                  I'm still getting 17.46V at the cathode, which is still to high.
                    17.46V on the 100 Ohms resistor? I cannot see how it can develop that much voltage on the resistor. I need to look at the balancer board to see how it is all connected. You do have high voltage for sure, otherwise you will not be getting output voltage on the Cathode side.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      There are 4 pins on the primary side of the transformers. The two inner ones send the signal to the diode. One end it seems like it's going to the ground, at least by measuring with the Ohm meter shows 0.3 to the ground. The other end goes to the diode.
                      The outer pins are going to the other transformer's outer pins. They are connected in series between them. If I measure on one board from one end to the other end, with the joining harness between other balancer boards, each balancer board shows 6.0 Ohm. All inner coil shows 0.5-0.7 Ohm. All secondary coils are 268-272 Ohms.
                      It seems like all the transformers are fine. All the ccfl tubes I have replaced from another TV, which didn't have ccfl tube issues(had tab bonding issues).
                      The only thing left, is the comparator on the balancer board and the two inverters.
                      The weakest side is the D4 inverter (next to the PS).
                      How can I be sure that an inverter is working or not? The way I have tested it, is by setting the multimeter to VAC and holding the red probe close to the pink wire at the output of the inverter.
                      The D4 inverter showed less then at the D5 inverter.
                      But at the balancer that high voltage, can be caused by a bad inverter?
                        Does the LD stay at 11~12VDC with the resistors in place?
                        "There are 4 pins on the primary side of the transformers" they are actually secondary side per page 45~46. they are connected in series and not connected to ground.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          I will measure it today.
                          In that drawing it seems like there are only two coils, but to me it seems like there are two on one side and one on the other(tubes).
                          I will look at this again and try to figure out where the pins are actually going.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            At LD, still drops the voltage to 0.7V with a 120 Ohm resistor on the right balancer boar and one one on the left balancer board.
                            There is only 10.65V, not 12V.
                              "At LD, still drops the voltage to 0.7V with a 120 Ohm resistor on the right balancer boar and one one on the left balancer board."
                              Are you saying the LD is at 0.7V or 10.65V (per training manual, it should be around 11~12V, 10.65 is close enough)
                              • tibimakai
                                • Jan 2012
                                • 3680
                                It's 10.65V when I turn it on, then as the tubes turn on, the voltage drops to 0.7V.
                                  So it did trip the comparator which is strange since we grounded the input to the comparator IC using the resistor. You may be able to disconnect that LD line and feed it with external 12V power source to fool he main board that the balancer circuit is OK. I did not have a chance to probe my balancer boards yet to see if any one of the secondary side of the transformer is tied to the circuit ground as it is measured on you board.
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    Just to be sure, I'm not doing something stupid. These diodes are double diodes, right? The one pin toward the comparator is the cathode and the two pins going toward the test points are the anodes.
                                      Yes, the center pin is the common Cathode, the other are the Anode for the each diode. They are setup as a simple rectifier to produce positive voltage to trip the comparator IC.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        So I'm measuring everything correctly. Negative probe is the chassy of the TV.
                                          OK, I look at my board, the two inner pins of the transformer, on of the inner pin is connected to ground, the other pin is connected to the Anode of the dual diode.
                                          the outer two pins are connected in the loop with the other transformer. So basic diagram does not show exact setup, that is why it is confusing. The two outer pins has no connection to ground.
                                          So we ground the Cathode but the comparator still tripped some how.
                                          • cloo
                                            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                            by cloo
                                            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                            After doing a factory reset this problem was gone and the picture was back to...
                                            01-06-2025, 06:02 AM
                                          • reporter1979
                                            2 red blink code on old led tv Sony KDL-40W2000
                                            by reporter1979
                                            Hi all, the TV KDL-40W2000 was flashed by a lightning.
                                            Firstly I got the 3 red blink code.
                                            Following other threads I changed the power supply board and got always 3 blinks.
                                            So I changed also the mainboard and now I get 2 blinks error code. Tried also with the other ps board, still getting 2 blinks.
                                            The TV turns on for a minute or two with green led and blank screen, if I press buttons the green led blinks fast. It turns to 2 red blinking led after a while.
                                            What else can I do?...
                                            02-17-2023, 11:50 AM
                                            LCD LED TV Service Menu Codes
                                            TCL LED TV Service Menu Code
                                            LG LED TV Service Menu Code
                                            10-31-2024, 03:58 AM
                                          • Storyteller12
                                            Sony XBR-65X900E 4 Blink Code
                                            by Storyteller12
                                            I have this set. It turns on and is watchable for a few minutes but then shuts off and flashes 4 red lights.
                                            I don't work on Sony much but assumed it was backlights from what I read.
                                            Opened up the TV and tested all the backlights with led tester and the all work.
                                            I know sometimes that doesn't mean anything since it's not running at full current but I hate to spend $120 on backlights (shopjimmy) is the only one that even has them just to find out I missed something.
                                            So anyway to test these lights similar to the way we test...
                                            12-31-2022, 02:17 PM
                                          • rmacintosh
                                            Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
                                            by rmacintosh
                                            I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
                                            The symptoms of the tv ar as follows:
                                            • Plug AC in to back of TV
                                            • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
                                            • The 3 blink code is given by the power LED
                                            • If the TV is unplugged and then
                                            03-14-2020, 12:24 AM
