panasonic tx42-p42x20b
  • adamp91gvm
    • Jan 2014
    • 699
    #101
    Re: panasonic tx42-p42x20b
    Originally posted by adamp91gvm
    On the 5.5 I'm getting 6 v and the 3.3 I'm getting 3.27v on the 1st pic
    That's what I get on the 1st pic
      6V is OK but please verify your multimeter accuracy -- check a fresh 1.5V AA it should read 1.5~1.6V.
      Low battery in multimeter can cause incorrect readings with cheap meters.
      • adamp91gvm
        • Jan 2014
        • 699
        #103
        It's brand new bought it sat but ill check it tomorrow and I'll get a new bat from work
        • adamp91gvm
          • Jan 2014
          • 699
          #104
          • adamp91gvm
            • Jan 2014
            • 699
            #105
            I AM RIGHT ON MEASURING LIKE THIS AINT I ?
              That's correct. I'll try make the diagrams clearer.
              Looks like your SUB3.3V is down. Let me find where that is generated and knock up a diagram.
              • adamp91gvm
                • Jan 2014
                • 699
                #107
                great thats what im getting from them areas then
                • adamp91gvm
                  • Jan 2014
                  • 699
                  #108
                  thank you
                    Can you get a picture on the opposite side of IC5600?
                    http://tinypic.com/view.php?pic=ynzvk&s=5#.UtbGxKxdXeU
                    • adamp91gvm
                      • Jan 2014
                      • 699
                      #110
                        Whoops, sorry, my error. Do you see an IC5601? Could you get pictures top and bottom?
                        Meanwhile, might as well do these tests on IC5600 (they could be useful.)
                        • adamp91gvm
                          • Jan 2014
                          • 699
                          #112
                          • adamp91gvm
                            • Jan 2014
                            • 699
                            #113
                            • adamp91gvm
                              • Jan 2014
                              • 699
                              #114
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                #115
                                the ribbon cable in the above picture is not seated properly might be making poor contact.
                                • adamp91gvm
                                  • Jan 2014
                                  • 699
                                  #116
                                  i just pulled that out just as i took the pic
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    #117
                                    cool thats ok then.
                                      Are those points which measure about 0.43V measuring 15V just before the set shuts down?
                                      • adamp91gvm
                                        • Jan 2014
                                        • 699
                                        #119
                                        no as i turn on
                                          Checks for SUB5V and SUB3.3V attached.
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                            by sam_sam_sam
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • canadaboy25
                                            Panasonic TC-P54VT25 No image. A or D board?
                                            by canadaboy25
                                            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                            The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                                            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                            01-17-2021, 01:06 AM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
