panasonic tx42-p42x20b
    Re: panasonic tx42-p42x20b
    No, take out loop and use 10A range to measure current.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      #142
      good find tom and glad it was a easy fix some very good tips in this thread.
      • adamp91gvm
        • Jan 2014
        • 699
        • uk
        #143
        That's my voltmeter what I need to do ?
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          #144
          turn the dial to red 10amp and move the black test lead up to the other 10amp hole would be my guess but let tom confirm.
            Basically that but instead red probe in 10A and black probe in COM. (Although Vince's suggestion works it would give a negative reading.)
            Then remove wire jumper and stick meter across blown fuse.
            You could solder wires to ends of fuse and attach probes to them - then try to get worst case 15V current, for example when the TV turns on, when it is on Freeview/Freesat, when it is on HDMI, etc. Try to find maximum then double it for a good fuse rating.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #146
              well it was a guess but i also know myself now.
              • adamp91gvm
                • Jan 2014
                • 699
                • uk
                #147
                I know im a pain in the ass but any chance of a doodle of this just so im 100% thank you
                  Can you post a pic of fuse?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    #149
                    which bit arnt you sure on the meter leads/setting or the fuse testing
                    • adamp91gvm
                      • Jan 2014
                      • 699
                      • uk
                      #150
                      setting the a board fuse up to test it
                      • adamp91gvm
                        • Jan 2014
                        • 699
                        • uk
                        #151
                          That looks OK, can you try and plug HDMI into it, etc. try to get maximum current.
                          Soldering wires here works best.
                          • adamp91gvm
                            • Jan 2014
                            • 699
                            • uk
                            #153
                            so solder 2 long wires out of it so i can put the board back and do the same
                            • adamp91gvm
                              • Jan 2014
                              • 699
                              • uk
                              #154
                              i got a wire off a charger its rated at 10v 1.2A that ok to use as the wires
                                Should be ok. Just make the solder joints clean and solid, if you are using multistrand wire it can be helpful to wrap up and tin the ends beforehand.
                                • adamp91gvm
                                  • Jan 2014
                                  • 699
                                  • uk
                                  #156
                                  • adamp91gvm
                                    • Jan 2014
                                    • 699
                                    • uk
                                    #157
                                      So far, 0.4A is the highest you've seen? What do you see when the TV first turns on? Loud audio make any difference? Try Freesat, Freeview, guide mode, etc...
                                      Looks like a 1A fuse should do, slow blow type.
                                      • adamp91gvm
                                        • Jan 2014
                                        • 699
                                        • uk
                                        #159
                                        you are a absolute legend !!!!! u should be proud mate thank you so much to you and all that helped get it alive again
                                        • adamp91gvm
                                          • Jan 2014
                                          • 699
                                          • uk
                                          #160
                                          thats the highest i get
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • canadaboy25
                                            Panasonic TC-P54VT25 No image. A or D board?
                                            by canadaboy25
                                            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                            01-17-2021, 01:06 AM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
