panasonic tx42-p42x20b
  • adamp91gvm
    • Jan 2014
    • 699
    • uk
    #61
    Re: panasonic tx42-p42x20b
    I'm going to have a look at the inductors when I get in and try upload a pic it's a pain to upload as I'm on my phone most of the time
    • tw2005
      • Oct 2011
      • 6458
      yeah I'm old fashioned. No good with the new aged smart phones. I need the full 15+ inches of a laptop.
      I only picked those inductors because they're easy to spot and essentially a coiled bit of wire so either connection will do for a pick off point.
      • adamp91gvm
        • Jan 2014
        • 699
        • uk
        #63
        I have just been looking on line and the TNPH0829 A board looks like it goes into txp50x20b and tx-p42x20e ? Is it the same board might make it easier to find one
        • tw2005
          • Oct 2011
          • 6458
          Explained in post 44.
          Pictures and service manuals of all 3, then you would have to compare the breakdown parts on the A board in particular the Flash/EEPROMs numbers. usually start with TVRR which dictates what data is loaded on them depending on the model and the region the TV is from.
          Then have at look at the chips to see if you think you can desolder and resolder to another board.
          Then you can make the final decision. how cheap are the boards for sale locally?
          • tw2005
            • Oct 2011
            • 6458
            Looks like any of those in the service manual for yours in the 42 may all have the same A board. I did not see any notes or eeprom variants noted, European models I guess, not my region so I can't comment for sure.
            The 50" will definitely have different firmware somewhere.
              42" and 50" are probably different resolution (1024x768 vs 1365x768)
              • adamp91gvm
                • Jan 2014
                • 699
                • uk
                #67
                Hi sorry to be a pain but on the earlier picture of the A board on page one could u mark on where I need to check for the inductors please thank you in advance
                • adamp91gvm
                  • Jan 2014
                  • 699
                  • uk
                  #68
                  Also just a quick one should I be getting 4v around the hdmi ports
                    How are you measuring that? Which pin?
                    • adamp91gvm
                      • Jan 2014
                      • 699
                      • uk
                      #70
                      Just off the back off the hdmi ports there are small gold holes I'm getting 4v around all 3
                        Show us where you are testing, and where is your black probe touching too?
                        • adamp91gvm
                          • Jan 2014
                          • 699
                          • uk
                          #72
                          • adamp91gvm
                            • Jan 2014
                            • 699
                            • uk
                            #73
                            • adamp91gvm
                              • Jan 2014
                              • 699
                              • uk
                              #74
                              • adamp91gvm
                                • Jan 2014
                                • 699
                                • uk
                                #75
                                Had to do it like that uploading from phone
                                  You're just probing a random pin. I don't see any problem with that reading.
                                  • adamp91gvm
                                    • Jan 2014
                                    • 699
                                    • uk
                                    #77
                                    I just thought I'd check it :s could u show me where the inductors are on the A board please
                                      Inductors look like this:
                                      http://www.koaspeer.com/images/slides/inductors.png
                                      • adamp91gvm
                                        • Jan 2014
                                        • 699
                                        • uk
                                        #79
                                        Giving me 5.8v before second click 6.0v after click
                                        • adamp91gvm
                                          • Jan 2014
                                          • 699
                                          • uk
                                          #80
                                          Gives me 15.68v for about 10 seconds then drops to 0v and no v out of the other side of it
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • canadaboy25
                                            Panasonic TC-P54VT25 No image. A or D board?
                                            by canadaboy25
                                            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                            01-17-2021, 01:06 AM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
