panasonic tx42-p42x20b
    Re: panasonic tx42-p42x20b
    Originally posted by adamp91gvm View Post
    On the 5.5 I'm getting 6 v and the 3.3 I'm getting 3.27v on the 1st pic
    That's what I get on the 1st pic
      6V is OK but please verify your multimeter accuracy -- check a fresh 1.5V AA it should read 1.5~1.6V.
      Low battery in multimeter can cause incorrect readings with cheap meters.
        It's brand new bought it sat but ill check it tomorrow and I'll get a new bat from work
            I AM RIGHT ON MEASURING LIKE THIS AINT I ?
              That's correct. I'll try make the diagrams clearer.
              Looks like your SUB3.3V is down. Let me find where that is generated and knock up a diagram.
                great thats what im getting from them areas then
                  thank you
                    Can you get a picture on the opposite side of IC5600?
                    http://tinypic.com/view.php?pic=ynzvk&s=5#.UtbGxKxdXeU
                        Whoops, sorry, my error. Do you see an IC5601? Could you get pictures top and bottom?
                        Meanwhile, might as well do these tests on IC5600 (they could be useful.)
                                the ribbon cable in the above picture is not seated properly might be making poor contact.
                                  i just pulled that out just as i took the pic
                                    cool thats ok then.
                                      Are those points which measure about 0.43V measuring 15V just before the set shuts down?
                                        no as i turn on
                                          Checks for SUB5V and SUB3.3V attached.
