Vizio V555-G1 stuck on wallpaper; now stuck on V logo
  • x_orange90_x
    • May 2015
    • 727
    I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After it restarted it went right back to the same error and then frozen wallpaper.
    Attached are photos of the error and the wallpaper. I tried the reset several times and tried two different remotes. It doesn't respond to anything.
    Edit:
    I plugged in a thumb drive with the latest update and nothing showed up on screen, so I left it alone for a couple hours. When I returned the tv was sick on the V logo and I could not power it off via button press. I unplugged it, held the power button, plugged it back in but it instantly powers itself on and gets stuck on the logo forever. I found a procedure to force a hard reset via pressing button combinations on the remote, but you have to start with the power off and NOW I can't this stupid thing to turn off without being unplugged! Looks to me like crippled firmware. It boggles my mind that they can push out updates that literally brick people's TVs and it's just okay. There has to be some way to force a reinstall of the firmware or downgrade it to something that works.
  • diif
    • Feb 2014
    • 6978
    • England
    Perhaps the NAND or Flash is worn out.
      • 12209
      • U.S.
      Something to try: Unplug tv, press and hold power button on tv not remote for 30 seconds, leave tv unplugged for 15 minutes, plug it in, press and hold power til it comes on.
      • x_orange90_x
        • May 2015
        • 727
        I did try this to no avail.. Plus, plugging it in instantly powers it on regardless of pressing or holding the power button. Before it would remain off when plugged in, so in that sense it was more "usable" I guess. Also, while stuck on the logo, holding Input and Volume Down does nothing. I'm wondering if trying to update the firmware caused this, or if it just naturally crashed and rebooted to this state because I left it on so long. Likewise I'm wondering if I was better off with it frozen on the wallpaper 🙁
        I do think it's a NAND issue. I don't think this set has EEPROM because it's a smart tv. I'm going to try resetting a few more times later. If that don't work in gonna pull the board and heat up the BGA and NAND and see if that changes anything. A replacement isn't super expensive, but still not really cost effective.
          • 12209
          • U.S.
          I see, it may have been an update gone wrong, I always turn off auto updates, I assume you have all external devices unhooked while trying.
          • x_orange90_x
            • May 2015
            • 727
            Yes nothing but power cord. I don't know what may have happened before I got it, but as of right now it looks corrupted.
            • x_orange90_x
              • May 2015
              • 727
              I tried again this evening and still getting stuck on the V logo. I also tried plugging it in with the update drive plugged in for about an hour. Never did a thing
              • EazyBone
                • Jun 2023
                • 1340
                • United states
                Vizio is horrible for doing updates for older sets in my experience so maybe not that. They are notorious for having bad cpu connections that break and need reball or reflow whatever you want to call it. I'd try that. Likely your problem (based off my small knowledge lol)
                • Diah
                  • Feb 2013
                  • 6376
                  try to connect it via port HDMI with CEC function. function so you can control it with other device RC. or plug in keyboards--- mouse via USB and press F keys.. it could pass the first boot.... this is SmartCast OS...so bad it depend on other sources
                  • x_orange90_x
                    • May 2015
                    • 727
                    I will try this tonight!
                    EazyBone I was thinking of doing this as a last resort. I just got a new hot air station so I'm prepared!
                    • EazyBone
                      • Jun 2023
                      • 1340
                      • United states
                      Just do it right. My guess from very limited experience lol is this is the problem
                      • x_orange90_x
                        • May 2015
                        • 727
                        The interesting thing tho is how it just powers itself on when plugged in. Would a BGA issue allow that to happen?
                        • x_orange90_x
                          • May 2015
                          • 727
                          I tried last night and no change. Maybe I didn't get it hot enough. I might try again. I have nothing to lose
                          • Diah
                            • Feb 2013
                            • 6376
                            its not BGA issue... you need to tell the main SOC label if its MT or ST to know if its had issue caused by BGA.... its boot and you have BL... .. so show here yours SOC brand and the NAND/eMMC label and their circuits other wise you are toasting the MB with No reason
                            • x_orange90_x
                              • May 2015
                              • 727
                              It is MT.
                              • x_orange90_x
                                • May 2015
                                • 727
                                Something I have noticed is sometimes when I plug it in there will be part of what I'm guessing is a No Signal box at the bottom under the V. It will inch away like a No Signal box too until it's completely off screen never to return.
                                Edit: I can't find any parts or info as far as EEPROM or NAND for this exact tv. It appears I'm the only person who has ever had this problem with THIS model 🙄
                                Is there any way to short any pins on the chip to reset it? I really don't want to buy a board because its more than the tv is worth.
                                • Diah
                                  • Feb 2013
                                  • 6376
                                  try freeze the NAND very well then plug it in wall
                                  • x_orange90_x
                                    • May 2015
                                    • 727
                                    I don't know which chip is NAND. I have to try and get ahold of some freeze spray.
                                    • Diah
                                      • Feb 2013
                                      • 6376
                                      only the NAND with blue dots on it
                                      • x_orange90_x
                                        • May 2015
                                        • 727
                                        That would be the one at the bottom of the previous picture correct? It says Kingston. Looks like a blue dot to me. I looked it up and it's an eMMC
                                        • paulxxxx
                                          Vizio E701i-A3 stuck at logo, need service manual
                                          by paulxxxx
                                          The TV stuck at logo and cannot be turned off unless the cord is unplugged.
                                          I was given two main boards and exactly the the same thing happens to both of them.
                                          I have checked all voltages on the connector on the power board that goes into the main board and they all look OK.
                                          There are no signs of damage on any of the 3 boards.
                                          Would someone help me with a pointer to the manual? It's supposedly to be the same as E601i-A3.
                                          Thanks!
                                          09-08-2023, 01:11 PM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • Bob1394
                                          Vizio M65-C1 | Logo appears for 10 seconds then off
                                          by Bob1394
                                          I have used the search, and am stumped.
                                          My Vizio M65-C1, Vizio logo appears for about 10 seconds then goes off.Power LED blinks 15 times then the TV powers down.
                                          I have read through many threads on the M65-C1 including the following threads. I feel like I must be looking right past the solution to my problem:
                                          https://www.badcaps.net/forum/showthread.php?t=81088
                                          https://www.badcaps.net/forum/showthread.php?t=84241 (not clear on the Eprom actions)
                                          Observations
                                          1) [Interaction] Power turned on via TV button (or remote)...
                                          02-08-2023, 01:03 PM
                                        • justice171
                                          JVC LT-50N795 Stuck on Wisdom Share Logo
                                          by justice171
                                          I'm working on a JVC TV for a client that's stuck on the "Wisdom Share" logo screen.
                                          It's a model LT-50N795 with a board number TP.HV510.PC822. I attempted a firmware update via USB, and while the upgrade was completed successfully, the TV is still stuck on the Wisdom Share screen on reboot.
                                          Has anyone encountered this issue before, or does anyone have any suggestions on possible solutions?
                                          Thanks in advance!
                                          11-04-2024, 02:55 AM
                                        • Super360
                                          Vizio E701i-A3 Vizio logo flashing then turns off
                                          by Super360
                                          Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                                          07-25-2024, 07:06 PM
