SONY KDL-40NX700 2 red led blink problem
  • ozguven
    • Dec 2023
    • 9
    • TURKEY
    When the power is turned on, a snapshot appears on the screen and it turns off. 2 red LEDs are flashing.
    I disconnected the power module cable going to the main board. I threw a power on jumper with 3.3 v from outside. The relay is working and there is 12v and other voltages in the power socket.
    Where else should I look? All fuses appear to be intact.​
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4316
    • Italy - Milan
    Check the service manual for that 2 blinks, i suspect backlight..
    • ozguven
      • Dec 2023
      • 9
      • TURKEY
      This is what is stated in the manual.
      TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
      mode then displays the 2 blink fault. Could be a short in the power supply of
      any of the circuits.
      When turned on, the backlight turns on momentarily. Then everything shuts down. I tried to measure it with a voltmeter until it shut down. Something like 85v. The voltmeter cannot read quickly until the relay closes.​
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4316
        • Italy - Milan
        Try to disconnect the tcon and see if blinks becomes 5
        • ozguven
          • Dec 2023
          • 9
          • TURKEY
          yes, I didn't say Tcon Power. Then it blinking 5 times.
          • ozguven
            • Dec 2023
            • 9
            • TURKEY
            I also suspect the rear lush led bars. I want to be sure of dismantling everything.
            • ozguven
              • Dec 2023
              • 9
              • TURKEY
              I wrote it incorrectly. I also suspect the back light led bars. I want to be sure of dismantling everything.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                If i remember these sets have edgelit leds these are older sets now i think 2010 era so my guess is bad leds
                • ozguven
                  • Dec 2023
                  • 9
                  • TURKEY
                  Yes. The device manufactured in 2010.
                  • nomoresonys
                    • 12145
                    • U.S.
                    It's a 40 inch screen, you shouldn't have a problem taking it apart if you go slow and take your time, just treat the panel like a baby.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4316
                      • Italy - Milan
                      Don't run.. dismantling panel is always risky, test the tcon at bench with bench psu, check the various converters, or at least if psu goes protect mode..
                      • ozguven
                        • Dec 2023
                        • 9
                        • TURKEY
                        Now I removed the panel. I tested the LED bars. LEDs on one side did not light up. There are 4 bars in total. Grouped in pairs of 2. I tested the double group of bars I tested one by one. 2 LEDs in one of the bars are faulty. I wonder if this is the source of the problem.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          yes once you replace the strips the tv should work fine again (i have just repaired a tv just one led had failed and caused no backlight at all)
                          • ozguven
                            • Dec 2023
                            • 9
                            • TURKEY
                            OK. Thanks.
                            I will change it as soon as possible and share the result.
                            • ozguven
                              • Dec 2023
                              • 9
                              • TURKEY
                              LED bars arrived today. I made the change and tested it. It works perfectly. Thanks to everyone who helped.
                              • vinceroger69
                                vinceroger69 commented
                                Editing a comment
                                Thats good to hear and another tv saved from landfill.
                            • Vebririon
                              panasonic TX-P50V10E 6 blink led problem
                              by Vebririon
                              I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                              Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                              I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                              05-17-2025, 10:16 AM
                            • Chrissygizmo
                              Sony KD-55XG9505 lines on screen problem
                              by Chrissygizmo
                              Hello again everyone,
                              This is my latest mission, to try getting this Sony tv back to normal working order…
                              I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                              02-19-2025, 11:31 AM
                            • EazyBone
                              Sony 85x90CK 4 red blink
                              by EazyBone
                              So I got this Sony and purchased it working.. got it home and it was 4 blinks red. Seller actually refunded me thankfully. Now it's massive to take apart and I know 4 blink can be the panel sometimes but not always..
                              But I found a method through other ways with grounding out the bl error pin on the LD driver board. Now the tv turns on and works.
                              Pin is number 27. It was either remove the resistor right next to the solder pad or solder the pad to ground. I soldered the pad.
                              Now what is this going to do to the tv? Is it just going to die shortly down the road?...
                              07-18-2025, 12:53 PM
                            • crackedprint
                              Sony HCD-HX80R Amplifier Volume Control Problem
                              by crackedprint
                              I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                              I have tried a Cold Reset as per the service manual.
                              I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                              I have looked all the way through the service manual and tried many online...
                              01-21-2025, 12:18 PM
                            • cheeky2
                              Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                              by cheeky2
                              For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                              See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                              01-08-2024, 05:56 AM
