AS15 Gamma IC
  • newtothis
    • Mar 2013
    • 1556
    • england
    AS15 Gamma IC
    Ok just replaced a faulty AS15 on an AUO T-con.
    Visually it looks perfect... Switched set on an no longer have the inverted colours... But now I have a new issue.. I cannot provide pics as my phone charge port has snapped and being Christmas I have to wait for a new one to come...
    So.. Colours are fine.. Problems are that the image is ever so slightly grainy, certainly not as sharp as it should be!... Next issue is that I have my PC plugged into the TV and off the top of any window there are faint lines running across the screen from them... they move with the window when moved.
    Any ideas?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: AS15 Gamma IC
    Are you sure the VGA cable you're using is good? Sounds like a low quality cable.
    A working TV? How boring!
    • newtothis
      • Mar 2013
      • 1556
      • england
      Re: AS15 Gamma IC
      Works fine in my TV I am now using.. Its a HDMI.
      fault is definitely with the set
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        Re: AS15 Gamma IC
        I would check voltages at the test points on the Tcon. Especially VGH, VGHC, VGL.
        • newtothis
          • Mar 2013
          • 1556
          • england
          Re: AS15 Gamma IC
          Noticed green isnt showing correctly, Going to go over the IC again and reflow each pin to make sure.
          • netgearnetgear
            TOSHIBA 32C100U1 - Faulty display (double images and lines)
            by netgearnetgear
            Good day all,
            I have a Toshiba TV, model 32C100U1 that turns on, displays fine for 5 min, sometimes 10 min and even 25 min then it starts to show double image, wrong colours together with lines as seen in the attached. I have measured and documented the tcon voltages both when the Television works fine and when the problems described occurs. It is important to note that the voltages are the same on the tcon board. The LVDS cable, tge panel ribbon all test good. I resoldred all the main ic's connections pins, connectors and even reflowed gamma chip. I tried to block some of the...
            10-27-2025, 08:07 PM
          • gobby009
            ambiano eletric window cleaner
            by gobby009
            hi guys bought a ambiano eletric window cleaner from a charity shop had a full charge when i bought it ran fine went to charge it and it wont charge the chargers fine so had a look at the motherboard.in the picture i have continuity from the charging port negative pin to the 2 negative points matked in black on the board.but on the posotive side i only have continuity to the first red point marked in the picture not at the second marked point.any ideas....
            11-06-2024, 10:37 AM
          • ktmmotocross
            How to prevent nvflash64 to auto close window?
            by ktmmotocross
            I want to do command "nvflash64 --version"
            but this stupid window is always auto close so i cannot read what is output.
            anybody know solution or i must go to dos?
            next question is why i cannot flash different vendor bios even when i have patched nvflash
            06-01-2023, 02:31 AM
          • alltvrepairs
            Samsung QE65Q60TAUXZT New Mainboard but wrong colours
            by alltvrepairs
            I have ordered a new main from Samsung. Tv works fine but colours are wrong. I have updated the Panel type as per panel sticker but made no difference. I have another spare good main board and copied the SPI data to the new board but still same problem.
            I have attached pics to what difference I have found a difference n the Tcon value as per (2). However haven't found from where I can modify this value. Note I have entered SM with normal remote. Currently I do not have Factory remote.
            Do we have a Service Manual for this please?
            Any assistance welcome!...
            04-18-2023, 02:37 AM
            MAX9590ETU+ MAX9590 Datasheet
            The MAX9590 provides 14 programmable voltage references and four static voltage references for gamma correction in TFT-LCD displays. Two register banks are provided to store two sets of gamma reference values. Gamma values are programmed into the banks through the I2C interface and the outputs can switch between values in 0.5µs.
            The 14 programmable reference voltages are divided evenly into seven upper and seven lower voltages for the upper and lower gamma curves of LCD column drivers.
            Each gamma reference voltage has an 8-bit digital-to-analog converter (DAC) and isolation...
            10-07-2024, 04:18 AM
