ambiano eletric window cleaner
  • gobby009
    • Oct 2014
    • 63
    • uk
    hi guys bought a ambiano eletric window cleaner from a charity shop had a full charge when i bought it ran fine went to charge it and it wont charge the chargers fine so had a look at the motherboard.in the picture i have continuity from the charging port negative pin to the 2 negative points matked in black on the board.but on the posotive side i only have continuity to the first red point marked in the picture not at the second marked point.any ideas.
    • 31258
    can you see the part number on the 8 pin chip?
    • gobby009
      • Oct 2014
      • 63
      • uk
      not clearly im thinking this 4056a 3rd16v.thanks
      • petehall347
        • Jan 2015
        • 4444
ID:	3501750 https://encrypted-tbn0.gstatic.com/i...zMv4cttJLkeg&s
        • gobby009
          • Oct 2014
          • 63
          • uk
          So with the charger plugged in my multimeter in dc voltage on the vcc leg reads 0.16 volts so i assume the chips bad right?
            • 31258
            if you dont see atleast 4.5v between the chips ground and vcc pins you can check the resistance between the pins.
            if it's not shorted then it's not getting power because a resistor or fuse is dead
            • itsthatidiotagain
              CDS‑200B ultrasonic cleaner - (other generic Chinese cleaners are somewhat similar)
              by itsthatidiotagain
              CDS‑200B ultrasonic cleaner - AKA James Ultra 7050 etc.
              There are many versions of cheap Chinese ultrasonic cleaners, and a fair few share this design, with a removable tank with handle. There are also fixed tank versions which look to use the same basic layout and presumably the same PCBs.
              I picked one up "spares or repair" on ebay, and the cleaner was dead, but the fuse wasn't blown.
              A quick diode check revealed D7 was shorted. D7 is a 12V 1/2 Watt Zener. I had one in my stash, so this was about as close to a "five minute repair" as...
              06-23-2025, 03:22 AM
            • budwich
              Lithium 12v tool battery charger... no negative connection?
              by budwich
              I have a drill and battery but no charger so I bought a "universal charger" 120ac in ... 12vdc out (not really universal in lithium world). Anyway it has three contacts, positive, negative and "T" (temperature sensor). I connected those contacts to the contacts on the battery. No charging happened and only the status light is on (green solid) which the label indicates "100% charged".... but the battery isn't near that at around 9v and dying. There doesn't appear to be any difference whether the battery is connected or not. I got suspicious and pulled the...
              03-18-2025, 09:12 AM
            • AlexVG
              Replacing the WiFi module on a vacuum cleaner iROBOT i7
              by AlexVG
              I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
              I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
              (This board does not respond, only the LEDs light up in a circle.
              The liquid damage is catastrophic and restoration is impractical).
              (I bought this board to get the WiFi module and camera).
              The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
              If...
              10-22-2024, 07:20 AM
            • spleenharvester
              Apparently red = negative now?..
              by spleenharvester
              I cut in half a two-core DC5525 male-female extension cable to splice in an LC filter. My computer didn't come back to life after plugging it in, and then a few seconds later... BOOM!
              Naturally my first thought was that I'd fitted the capacitors the wrong way round. Nope, the cable uses red as negative and white as positive. I didn't think to check that the barrel matched the colours as I've literally never encountered this before in my life, but you learn something new every day apparently!
              RIP two new Panasonic FMs 😞 Fortunately my system and power supply are OK...
              10-03-2025, 12:44 PM
            • Tyroonis
              Identify component - QPF Chip from Eufy Robovac L70 Hybrid Vacuum Cleaner
              by Tyroonis
              I have a robot vacuum cleaner here.
              An Eufy Robovac L70 Hybrid.
              A chip has burst due to a short circuit.
              The following is legible on the chip:
              Mpsm44
              m2612
              883138
              I'm not sure if there is another number after m2612, as that's exactly where the hole is.
              Can anyone help me identify what this component is?
              Unfortunately, I couldn't find anything.
              I also don't have any plans or board views of the...
              08-14-2025, 02:32 PM
