MAX9590ETU+ MAX9590 Datasheet
    • 115472
    The MAX9590 provides 14 programmable voltage references and four static voltage references for gamma correction in TFT-LCD displays. Two register banks are provided to store two sets of gamma reference values. Gamma values are programmed into the banks through the I2C interface and the outputs can switch between values in 0.5µs.
    The 14 programmable reference voltages are divided evenly into seven upper and seven lower voltages for the upper and lower gamma curves of LCD column drivers.
    Each gamma reference voltage has an 8-bit digital-to-analog converter (DAC) and isolation buffer associated with it to ensure stable operation. Therefore, the reference voltages remain stable without synchronizing to the LCD horizontal timing. In addition, each buffer is able to provide a high current that further ensures a stable voltage when critical levels and patterns are displayed.
    The 14 programmable buffers wake up in the high-impedance state until the registers are programmed. This protects the LCD system from high transient currents during the startup phase.
    The MAX9590 is available in a 38-pin TQFN package and is specified for operation over the -40°C to +85°C temperature range.
    Features
    ● 14 Programmable Reference Voltages
    ● Four Static Reference Voltages
    ● Independent DACs with 8-Bit Resolution
    ● Two Register Banks for Two Sets of Gamma Values
    ● Fast Switching between Gamma Values
    ● 16.5V (max) Operating Voltage
    ● Output Swing within 150mV of Rails
    ● Peak Current Greater than 200mA
    ● Output Channels Tri-Stated During Wake-Up
    Applications
    TFT-LCD Displays Industrial Reference Voltage Generators​
  • proxneo
    Recapping Sony ICF-SW55 - verifying cap values
    by proxneo
    Dear reader
    I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
    At the moment, I have selected replacements based on the following list of values:
    3 x 470uF 10VDC
    3 x 4.7uF 35VDC
    4 x 47uF 50VDC
    8 x 22uF 6.3 VDC
    1 x 220uF 6.3VDC
    5 x 100uF 6.3VDC
    Which...
    06-21-2023, 12:38 AM
  • subroto
    Programmable and non-programmable SIO list
    by subroto
    ene kb9012 programmable
    ene kb9016 programmable
    ene kb9018 programmable
    ene kb9022 programmable
    ene kb9028qc programmable
    ene kb9010 programmable
    ene kb3930qf/b1 programmable
    ite it8585e programmable
    ite it8586e programmable
    ite it8985e programmable
    ite it8587e programmable
    ite it8522 programmable
    ite it8987e programmable
    ite it8589 programmable
    ite IT8380E programmable 192kb
    ite IT8380VG programmable 192kb
    ite IT8995E-128 programmable
    ite it8886H...
    01-13-2018, 09:15 AM
  • rashidjafar
    Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
    by rashidjafar
    I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
    Values for :-
    PC43 : Capacitor [3x1.5mm]
    PL7 : Inductor [2x1mm]
    PC39 : Capacitor [1x0.5mm]
    Any ideas would be appreciated.
    I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
    08-07-2025, 05:10 PM
  • Kobok
    Different (lower) resistor values on PCB?
    by Kobok
    Dear Alls,
    For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
    09-19-2022, 07:30 AM
  • skdsp
    Need help identifying resistor values near BIOS chip on ASUS Zephyrus G14 GA402XV
    by skdsp
    I purchased a laptop that the previous user had tried to remove and replace a BIOS chip using a soldering iron not knowing that there is a ground pad under the 25R256JWEQ chip. In that process he damaged the BIOS chip and 3 of the resistors near the IO3, CLK, and IO0 pins. I have programmed a spare 25R256JWEQ chip using a CH341A programmer but not sure what values those resistors should be. If anyone has a boardview of this area and can provide those values that would be very useful for me.
    Attached is the photo.
    Thank you!
    09-27-2025, 09:05 PM
