How to prevent nvflash64 to auto close window?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3622
    • slovakia
    I want to do command "nvflash64 --version"
    but this stupid window is always auto close so i cannot read what is output.
    anybody know solution or i must go to dos?
    next question is why i cannot flash different vendor bios even when i have patched nvflash
  • galkinvv
    • Apr 2023
    • Russia
    Re: How to prevent nvflash64 to auto close window?
    Such behaviour may happen while typing the command in the non-Administrator cmdline window.
    Then nvflash is opened in NEW administrator window that closes immediately after execution.
    There is 2 ways to workaround this:
    • via .bat file:
      1. use notepad++ or similar to create helper.bat file in the folder near nvflash64.exe
      2. add there a command you want and then a pause command in 2nd line, like
        Code:
        nvflash64 --version
        pause
      3. right click this bat-file and select run it as administrator
    • via cmd line opened as administrator:
      1. put nvflash in a folder with simple name in the drive C:, like C:\tools
      2. Locate cmd.exe in start menu. Right-click it and run as administrator. It will open admin command prompt.
      3. go to ypur folder with command
        Code:
        cd c:\tools
      4. run any nvflash64 commands from there. The window should staty in place after execution
    • shouri
      Dell latitude e5490 auto restart
      by shouri
      Hi guys, can someone help me?
      I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
      Board model is dm70 la-f401p rev:1.0 2017-09-20.
      At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
      After a few days test, is seems ok.
      Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
      12-10-2024, 09:27 PM
    • classicandy
      Lenovo G50-80 Auto Power On when AC is detected
      by classicandy
      Hi Everyone,
      I have a Lenovo G50-80 that auto powers On when AC (Charger) is connected. I have checked the BIOS settings and there is no option to turn On or Off that feature as it is in some HP EliteBooks. I did update the BIOS and still same.
      I then flashed the BIOS with a different bin file I downloaded here, It worked (didn't auto power on) for some time (after testing up to 5 times) but has now started again to auto power on when AC is connected.
      The CMOS battery voltage is 3v. I have also tested with two main batteries as well. I would be glad if anyone...
      03-21-2024, 05:48 AM
    • flat-earther
      how to prevent a connected charger from draining battery when not charging?
      by flat-earther
      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
      So the battery is backfeeding the charger and being drained.
      How can I prevent...
      08-07-2025, 01:04 PM
    • qsenc
      Dell 7330 LA-L581P with missing buts near bios! Just need a close photo
      by qsenc
      Anyone with a Dell 7330 LA-581P can take a close photo of the bios section as i only have board view ( no available schematic ) and i need to search for the correct values. Please see attachments...
      02-28-2025, 12:45 PM
      Ghost Battery Gate Opener battery took a crap tonight it refused to close gave me three beeps
      If I remember correctly this indicates a battery failure the other day I had to turn off the power going down the driveway to do something and forgot to turn it back on and the battery went dead but it charged back up and I thought everything was okay but apparently not because now it refuses to close and the battery power light and the line power light goes off when you give it a request to do something I have had so many devices that the battery have gone bad I am sick of it...
      12-02-2024, 07:31 PM
