Faulty T-Cons.??
  • Easky15
    • Sep 2013
    • 285
    • Ireland
    Faulty T-Cons.??
    Hi, I have 4 tv's here all appear to have the same fault, when the set is first turned on the picture is ok but the longer they are on the worse the picture gets, I can take pictures if needed. I was just wondering if it is the tcons at fault is there any way of fixing them or should i just buy replacements??
  • sordids999
    • May 2013
    • 2161
    • uk
    Re: Faulty T-Cons.??
    it could be a host of things wrong i would post some pictures and some one will reply to help
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      bad tab bonds springs to mind seen a few lately.
      • ecking767
        • Oct 2009
        • 492
        don't forget to include the brand and model.
        • mmartell
          RCA Virtuoso RHOS581SM-D Picture Fault
          by mmartell
          Picture looks stretched out and it looks like every other vertical line is not being drawn though hard to see that in the pics.
          I've disconnected each half of the panel and the fault remains exact save for the disconnected side being white.
          The original complaint was the tuner stopped working so the main was replaced however the new and old board exhibit the same picture defect.
          Nothing is getting hot and pushing on the panel drivers effects no change in the picture.
          So with that does anyone know how to enter the Service Menu on this...
          02-05-2022, 10:53 AM
        • JJAAMM
          by JJAAMM
          Problem
          07-06-2023, 06:01 AM
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • janos6662000
          Ariston Hotpoint KIB633CE Induction Hob repair assistance needed
          by janos6662000
          Hi
          I bought a faulty Ariston Hotpoint KIB633CE Induction Hob
          It has 3 induction zones, 1 is working and 2 not.
          I was expecting a faulty IGBT. Indeed, that was faulty, but unfortunately it also has some damage on the driver part. The second IGBT on the same microcontoller does not appear faulty, but that zone was nto working neither.
          I attach some pictures.
          Right now my biggest problem is, that 2 of the IGBT drivers are not looking good and i cannot find what type is it.
          They are SOT23-5 package, pin 2 on GND and pin 5 on output, connected through a 27Ohm resistor...
          11-01-2025, 04:22 PM
        • Fredrik_Bostrom
          LG 60PK250N ZA No picture
          by Fredrik_Bostrom
          To start with I think I have red every single topic on this forum about the No picture fault on this TV. Seems like a common fault but I just can´t find a match i other forum threads for my TVs fault.
          Symptoms:
          No picture, not even a little primer.
          Unable to check if I have sound since I don´t have any picture to navigate the menu to be sure I´m on the correct input.
          When connecting power cable it clicks just like it used to and the red standby light on the front comes on.
          When pressing the power button on the front it clicks like it´s...
          01-25-2024, 02:03 AM
