samsung UN46D6050 sound but no picture
  • DPElectronics
    • Nov 2013
    • 10
    Hello i have a un46d6050 with no pictures I've tried changing the t-con board the power board and the main boards all of which were purchased from ebay but still all i keep getting is sound and no picture just a blue screen
  • munirutech
    • Oct 2013
    • 72
    • Ghana
    Re: samsung UN46D6050 sound but no picture
    then i guess the panel if bad and need to be changed
      Check voltage on t-con fuse but it's quite likely as munirutech said that the panel is bad. Especially if it has ever been splashed with water. Try disconnecting one t-con ribbon at a time too.
      • rlega
        • Jan 2014
        • 93
        I have a Samsung UN46D6050TFXZA TV that I purchased a while ago, and have not been able to fix it. I had mentioned the TV on this thread, but at that time I thought it was the mainboard, only to find out that it sells over $110. I decided to keep the TV and find a broken one so I can take the mainboard, and that's what happened this weekend. I purchased a broken screen model UN55D6000SFXZA and luckily the mainboard and t-con are the same.
        The original problem of the UN46D6050TFXZA TV is that there is sound, but no video. You can see the tv flashes when you turn it on, and it flashes when you change channels, but no video. So I replaced the mainboard on the UN46D6050TFXZA (BN94-05038F) and used UN55D6000SFXZA (BN94-05038D) mainboard, problem persisted, sound but no video and the same symptoms described above. The mainboard is identical and on the internet it showed me the substitute parts and model was there.
        Now, I replaced the original t-con on the UN46D6050TFXZA and used UN55D6000SFXZA t-con, and the SmartTV logo came up, but you were able to see that the brightness on it was dissapearing, like using for example a knob that you control the power from high to low. The SmartTV logo when from high to low, the sound came up, but could not see the channels. I replaced the mainboard that I was using from the UN55D6000SFXZA TV (BN94-05038D), and installed the original one (BN94-05038F), the problem persisted. I replaced the t-con I was using from the UN55D6000SFXZA TV and installed the original t-con that came with the UN46D6050TFXZA, problem persisted.
        I have checked the power supply board (BN44-00423A (PD46A1_BSM)). The rectifier gave me correct readings. Inside pins 120VAC, outside pins 166VDC. Checked the 450v capacitor and it gave me 166VDC on standby, when I powered the TV it gave me a reading of 386VDC. The are two fuses on the board and they had continuity.
        I do not have the TV with me, its a my dad's house cause that's where we were working on it, but the power supply is this one:
        BN44-00423A
        Anything else that I can do?
        I'm suspecting it is the power supply.
          • 12307
          • U.S.
          make sure all your power supply voltages are proper at the connectors/cables going to the other boards, hopefully theres a legend by the connectors, careful when working with power supply, HIGH VOLTAGE on primary side.
          • rlega
            • Jan 2014
            • 93
            Some of you are way better than me when it comes to electronics and testing. I was wondering if someone had the same issue or similar, or if someone can guide me what to test on the power supply, how and where. Not much how, but which pins to select and what readings I should get.
            You are right. I'm careful when I do testing.
              • 12307
              • U.S.
              check tom66's post #3, see if you can find a manual, its in the small print.
              • tibimakai
                • Jan 2012
                • 3680
                It's not an LED issue?
                  Blue screen - slight backlight leakage?
                  • rlega
                    • Jan 2014
                    • 93
                    Hello, could not find any manuals from tom66.
                    The tv doesnt have backlight leakage.
                    I'm really scratching my head on this one
                      • 12307
                      • U.S.
                      you didnt find one when you searched or you didnt find it in the post?
                      • rlega
                        • Jan 2014
                        • 93
                        I did not find a manual here: http://www.toms-service-manuals.com/
                          • 12307
                          • U.S.
                          can you post some good clear pics., of each board and one of how they are all connected, this is an led tv, folks forget to put type of tv in initial post, it makes it tougher to have to google to find out what type it is.
                          • rlega
                            • Jan 2014
                            • 93
                            Re: samsung UN46D6050 (LED TV) sound but no picture
                            I will post some clear pics tomorrow since the TV is at my dads house.
                            Sorry I did not open a thread since this one was open, I used it, but I have added the word LED at the title of my post
                            • rlega
                              • Jan 2014
                              • 93
                              Here are a bunch of pictures
                              Hope this helps, thank you!
                              • CapLeaker
                                Leaking Member
                                • 8340
                                Have a look at the LVDS signal with the oscilloscope. While checking the LVDS signal, press the menu button and turn the menu on and off on the tv. As you do that, the waveform on the oscilloscope changes. This way you know that your main board is working o.k. or not. The LVDS signal is quite low btw.
                                • rlega
                                  • Jan 2014
                                  • 93
                                  Hello CapLeaker,
                                  I do not have a oscilloscope.
                                  I do have a question though. On the power supply board, there is a capacitor 223js1000v (CM813).
                                  I purchased a board on ebay, and the board arrived without the capacitor . The board will be shipped back, so they can solder it, but in the meantime, I'm trying to find the same capacitor so I can ordered it.
                                  I found this on ebay.
                                  Is it the correct one? If its not, could someone please let me know where I can get it?
                                    http://www.digikey.com/product-detai...1901-ND/502681
                                    Polypropylene (PP), Metallized
                                    High Pulse, DV/DT
                                    • rlega
                                      • Jan 2014
                                      • 93
                                      High Pulse, DV/DT
                                      Thank you budm.
                                      • CapLeaker
                                        Leaking Member
                                        • 8340
                                        I don't like buying caps on e-bay of any kind. Anyway... budm got you sorted out already!
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • iglitare
                                          by iglitare
                                          09-04-2025, 07:13 AM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
