47le5300
  • sordids999
    • May 2013
    • 2161
    47le5300
    wont turn on no backlight theres a power on touch screen sensor on the front can get that to work but thats about it
    thanks
    Re: 47le5300
    Start by checking BL ON/OFF from main board.
    • sordids999
      • May 2013
      • 2161
      Re: 47le5300
      sorry tom which one is the BL ON/OFF ive attached some pictures
      also tom if i press the button in the picture the backlight comes on
      • newtothis
        • Mar 2013
        • 1556
        • england
        Re: 47le5300
        Try this, Make sure there is an input in the TV... bet you the backlights do not turn off.
        If you have nothing plugged in the set will turn the backlights off after a few seconds
        • newtothis
          • Mar 2013
          • 1556
          • england
          Re: 47le5300
          Had same issues, if you shine a light into the screen once you turn it on and the backlights go off you should be able to see the no input signal icon... press menu on remote.. goto settings and factory reset. i have a feeling it will not turn the backlights off then either.
          • sordids999
            • May 2013
            • 2161
            Re: 47le5300
            no just tried this connected avi lead into main board nothing so pressed the button on main board the backlight lit up but went straight off
            could not see no input signal icon on the screen
            • newtothis
              • Mar 2013
              • 1556
              • england
              Re: 47le5300
              So just to confirm you cannot see any image at all with a flashlight?
              • sordids999
                • May 2013
                • 2161
                Re: 47le5300
                no m8
                • newtothis
                  • Mar 2013
                  • 1556
                  • england
                  Re: 47le5300
                  So no back lights and no image.
                  The LED driver board is built into the PSU on these models.
                  Which button have you pressed in post #3?
                  @ Tom, There are no references on the boards to indicate what pin is for what... This board is slightly different to the one I was working on the other day but same will apply.
                  • sordids999
                    • May 2013
                    • 2161
                    Re: 47le5300
                    heres the picture m8
                    SW1001 is the button i press to light the backlight up it only stays on for as long as you hold the button in
                    tried last night with light shining on screen no image showing
                    thanks
                    • sordids999
                      • May 2013
                      • 2161
                      Re: 47le5300
                      just want to bump this up decided to get back to this tv after so long but basically suspect main board failure tv totally dead so does anyone have a idea how i can jump the power supply to see if its the main board,looked in a service manual but not much info
                      thanks
                      • sordids999
                        • May 2013
                        • 2161
                        Re: 47le5300
                        on the legend on the PSU i have
                        20V POWER ON
                        20V 20V
                        GND GND
                        GND GND
                        3.5V 3.5V
                        3.5V 3.5V
                        GND GND
                        V-SYNC GND
                        DRV ON 12 V
                        SCLK 12V
                        PWM DIM 12 V
                        ERROR OUT SIN
                        • HTR-Informatique
                          by HTR-Informatique
                          02-09-2025, 06:51 AM
                        • frannyjunk
                          Hisense 40H4F no backlight but turns off after splash screen
                          by frannyjunk
                          So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
                          TIA.
                          09-24-2025, 10:59 AM
                        • AJ847.63e
                          HP Envy X360 13-bf0073TU (6X0Q8PA) Touch Screen Compatibility. Screen P/N N15665-001 - BOE NV133WUM-A65
                          by AJ847.63e
                          Hi All,
                          We've got a HP Envy 12th gen that has been dropped and the LCD panel itself has cracked. The glass is fine just the panel itself is cracked. We ordered a replacement screen assembly using the part number off the HP part surfer website.
                          Upon installation the touch screen now does not work either in UEFI or win 11. Device manager under the "intel Precise touch and Stylus) menu notes "This device cannot start (code 10) Status_Device_Power_Failure".
                          I've tried all the usual troubleshooting steps like reinstalling the driver, uninstalling...
                          04-04-2024, 05:29 PM
                        • turmix
                          AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                          by turmix
                          Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                          The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                          At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                          During another reassembly, I made a mistake, and...
                          01-29-2024, 03:48 AM
                        • FallenOne008
                          Asus G712L No Screen Backlight
                          by FallenOne008
                          Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
                          The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
                          03-31-2025, 08:27 PM
