47le5300
+ More Options
Posts
  • sordids999
    • May 2013
    • 2152
    47le5300
    wont turn on no backlight theres a power on touch screen sensor on the front can get that to work but thats about it
    thanks
    Re: 47le5300
    Start by checking BL ON/OFF from main board.
    • sordids999
      • May 2013
      • 2152
      Re: 47le5300
      sorry tom which one is the BL ON/OFF ive attached some pictures
      also tom if i press the button in the picture the backlight comes on
      • newtothis
        • Mar 2013
        • 1556
        • england
        Re: 47le5300
        Try this, Make sure there is an input in the TV... bet you the backlights do not turn off.
        If you have nothing plugged in the set will turn the backlights off after a few seconds
        • newtothis
          • Mar 2013
          • 1556
          • england
          Re: 47le5300
          Had same issues, if you shine a light into the screen once you turn it on and the backlights go off you should be able to see the no input signal icon... press menu on remote.. goto settings and factory reset. i have a feeling it will not turn the backlights off then either.
          • sordids999
            • May 2013
            • 2152
            Re: 47le5300
            no just tried this connected avi lead into main board nothing so pressed the button on main board the backlight lit up but went straight off
            could not see no input signal icon on the screen
            • newtothis
              • Mar 2013
              • 1556
              • england
              Re: 47le5300
              So just to confirm you cannot see any image at all with a flashlight?
              • sordids999
                • May 2013
                • 2152
                Re: 47le5300
                no m8
                • newtothis
                  • Mar 2013
                  • 1556
                  • england
                  Re: 47le5300
                  So no back lights and no image.
                  The LED driver board is built into the PSU on these models.
                  Which button have you pressed in post #3?
                  @ Tom, There are no references on the boards to indicate what pin is for what... This board is slightly different to the one I was working on the other day but same will apply.
                  • sordids999
                    • May 2013
                    • 2152
                    Re: 47le5300
                    heres the picture m8
                    SW1001 is the button i press to light the backlight up it only stays on for as long as you hold the button in
                    tried last night with light shining on screen no image showing
                    thanks
                    • sordids999
                      • May 2013
                      • 2152
                      Re: 47le5300
                      just want to bump this up decided to get back to this tv after so long but basically suspect main board failure tv totally dead so does anyone have a idea how i can jump the power supply to see if its the main board,looked in a service manual but not much info
                      thanks
                      • sordids999
                        • May 2013
                        • 2152
                        Re: 47le5300
                        on the legend on the PSU i have
                        20V POWER ON
                        20V 20V
                        GND GND
                        GND GND
                        3.5V 3.5V
                        3.5V 3.5V
                        GND GND
                        V-SYNC GND
                        DRV ON 12 V
                        SCLK 12V
                        PWM DIM 12 V
                        ERROR OUT SIN
