Vizio VW32L HDTV40A, Went bang, Now no power, :-o
  • Easky15
    • Sep 2013
    • 285
    • Ireland
    Just got this 32 inch vizio vw32l hdtv40a, I pluged power in to it and as soon as i switched it on something made a prety big bang and no it is completely dead with no signs of power, Is this a common fault with this set and is there any ways i can repair it?? Thanks.. ;-)
    Re: Vizio VW32L HDTV40A, Went bang, Now no power, :-o
    "i switched it on something made a pretty big bang" I would first inspect it real well to see if there is any blown parts inside. Pictures of the inside?
    • munirutech
      • Oct 2013
      • 72
      • Ghana
      hi
      did you have any ideas on electronics
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Budm, that is very diplomatic -
        "I pluged power in to it and as soon as i switched it on something made a prety big bang and no it is completely dead with no signs of power is there any ways i can repair it?? "
        I was thinking along the lines of " how the hell would we know"
        • dnafix
          • Oct 2012
          • 8
          So I opened a power supply that had been hit by a power surge and the fuse is gone and two 16n25c mosfets are shorted. I am not that good on crossing mosfets but I have two smk1430 mosfets which are n-channel and I wondered if I could use them or do I need to wait for the actual part for a week?
            Pictures and model number of this power supply? More likely the IC that drives the MOSFETs will be damaged also.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • SS454
              vizio e650i-a2 backlight flashes then turns off
              by SS454
              vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
              panel: au optronics T650HVN05.4
              72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
              link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
              Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
              https://www.shopjimmy.com/vizio-56-0...-power-supply/
              Vizio 55.75J01.001G (91.75J10.004G) Main Board...
              08-20-2020, 03:57 PM
            • mrtek
              Vizio M65-C1
              by mrtek
              Hi.
              picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
              When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
              This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
              07-14-2025, 07:28 PM
            • howardc64
              Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
              by howardc64
              Failure Symptom
              No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
              Where is the short?
              Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
              Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
              05-27-2025, 02:56 PM
            • howardc64
              Vizio SmartCast TV software bug that looks like hardware
              by howardc64
              Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
              It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
              11-16-2024, 05:17 PM
