After being turned on for about 5 minutes the screen will start to blink black -- as quick as an eye blink. The longer it stays on the more often it blinks until it is blinking fast enough to run a rock concert light show or cause siezures. It happens no matter what input or picture mode is selected and, other than the blink, everything else, picture, sound, etc. works perfectly.
It's a pretty simple TV with a small button board, a main board, a power board and an inverter board. There are a lot of things that could effect all modes and inputs but I figured the most likely one would be something to do with the power board or the HV inverter board.
All caps on all of the boards look good -- no swelling, no discoloration of the cap or surrounding areas.
I measured the output voltages from the power board and all are exactly where they should be. I noticed that the +24vdc going to the inverter would "tick down" when the screen would blink but I'm guessing that was just in reaction to the quick load change coming from the inverter. With the inverter disconnected all voltages were correct and stable.
I measured the primary and secondary windings of all of the inverter HV transformers with an ohm meter and they all appeared correct -- low imp primary, high imp secondary and all approx. the same.
So, while I don't have anything definitive, other than observation, my gut tells me this is an inverter problem. I'm not an electronics tech [though I worked as a radar repairman in the USAF and know a little bit] and the only instrument I have is a multimeter.
Anyone familiar with the Insignia line? Do these symptoms ring a bell? If so, what is the most likely defect that will cause the LCD backlight to blink like this?
Thanks in advance.
Howard -- Blinking in Seattle
Thanks in advance.
