Insects and TV repair ARRRRRRRRRRRR
  • 120volts
    • Oct 2013
    • 57
    I was wondering what if anything YOU PEOPLE due to prevent insects from getting into your shop or home.
    I found a source to get one or more flat screen TVs a week.
    The thing is I have no idea where they came from or whats wrong with them.
    I never thought much about insects until one day on the way to work I saw a plasma TV on the side of the street.
    Of coarse I couldn't resists, I pulled over and grabbed it.
    At work we had a spray booth and at lunch time I thought it would be a great place to remove the back of the TV and blow out the dust.
    So I brought it in and just as soon as I removed the back," ARRRRRRR" about 30 Cockroaches came running out.
    Well luckily no one saw, I put the back on the TV and threw it in the company dumpster.
    Two days later the company had an exterminator spray the 30,000 ft building.
    I'm still curious to this day what it cost them.
    Since then I always remove the back of TVs outside before bringing them in.
    Dan "TV Tinkerer"
  • tw2005
    • Oct 2011
    • 6458
    Re: Insects and TV repair ARRRRRRRRRRRR
    So glad I just finished breakfast before viewing this.
    • bassn1968
      • Sep 2013
      • 4
      • US
      recently had a similar issue when a woman ask me to look at her tv I set it in the house and didnt open it until the next day, now I am have borax all over my hose to make sure I dont get an infestation.People should be considerate enough to tell you they have a problem.I put the set together and returned it to her unrepaired!
      • 120volts
        • Oct 2013
        • 57
        You guys got Roaches in Texas?
        I got a PLASMA TV from a known BedBug infested home.
        It was winter, I wrapped it in a plastic bag and left it outside for a month.
        I then realized it was only a 480 res I got rid of it fast.
        Dan "TV Tinkerer"
        • ohmmy
          • 182
          When I was on an Xbox 360 fix kick, I'd get at least two consoles with every bundle that had either dead roaches or what looked like warms (maybe cocoons)
          Well the last xbox I had was the grossest yet! Literally filled with roaches. Even adult sized ones inside the disc drive that I assume they must have went in as babies and grew because no way they could squeeze in that sealed little unit.
          That was last draw, I stopped the Xbox thing, they run hot so perfect breeding grounds.
          • 120volts
            • Oct 2013
            • 57
            Lol
            Dan "TV Tinkerer"
            • SeanB
              • Jun 2013
              • 41
              • South Africa
              Dropped 2 foggers in a room last week, next day the floor was a scattering of roaches on their backs waving legs at me. Here we have tough roaches, step on one soft and it will almost carry you away. they eat the rodent bait and survive.
              If the roaches are a problem then the rats will scare you, they are as big as the feral cats.
              • mmartell
                • Oct 2013
                • 3189
                I think I just threw up in my mouth...
                Honestly this is something I hadn't even considered. Thanks for the heads up.
                • aaronwt6
                  • Apr 2013
                  • 855
                  • US
                  I install dish network on the side. Used to do it more frequently while I was in college. I've seen many a receiver that died due to roaches. I've cracked the top on one before and had literally a layer of roaches an inch thick. Could even see the circuit boards.
                  • truep
                    • Aug 2010
                    • 373
                    Do you guys remember the origin of the term "bug" in the computer industry? It referred to insects shorting out tube compuetr circuits.
                    • aaronwt6
                      • Apr 2013
                      • 855
                      • US
                      Little before my time on the tubes but I'll certainly remember that from now on. The receivers I'm referring to though were certainly fried by those roaches. The motherboards were so corroded it's really amazing they were functioning for as long as they did.
                      • RJARRRPCGP
                        • Jul 2004
                        • 6301
                        In Massachusetts, it's usually mosquitoes, lol.
                        ASRock B550 PG Velocita
                        Ryzen 9 "Vermeer" 5900X
                        Arc A770 16 GB
                        eVGA Supernova G3 750W
                        Alienware AW3423DWF OLED
                        • 120volts
                          • Oct 2013
                          • 57
                          I don't think to much about mosquitoes.
                          I just Run indoors when the sun start going down.
                          And if one gets in the house no one sleeps until it's dead dead dead and flushed down the toilet!!!!!!!
                          Dan "TV Tinkerer"
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            had a roachy pc last week.bestec bomb packed full.
                            yes it killed the mobo.
                            saved the ram,hdd,cpu,and the heatsink since it was easy to wash and looked like it would do fine in a led mod.
                            all bugs were dead but it still couldnt hit the dumpster fast enough!
                            • Uniballer
                              • Jul 2013
                              • 334
                              I believe it was a moth in a relay in the Mark II relay computer just after WW2.
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                I toted home a Magnavox 50 inch plasma that was filled with roaches a couple years back. When I popped the back open roaches scattered everywhere in my living room! The mainboard was absolutely corroded beyond repair. I had roach issues for 6 months. Exterminator came three times, finally gone. This is just the messy part of out hobby/job I guess.That thing went to the recycler quick! Kept the panel to put in a cracked screen Philips though, it was still good.
                                • Dang
                                  • Aug 2013
                                  • 440
                                  I live here in sunny old England and thankfully we don't have these issues, I've had real bad dirt and fluff build up but roaches or any other insects, nothing thankfully, not to say we don't have roaches here, we do but it seems not to the same extent.
                                  • splitcrete
                                    • Dec 2012
                                    • 387
                                    • usa
                                    When I pick up a tv I bring a clean shop rag with me.I wipe the top, and back of the set. If the dust stays on the tv it most likely has roaches. Roaches pee, and poop on every thing and its like dust glue. When I go into a house I look around if it looks filthy I just say no deal. Haven't had a bug yet. When I sell a set I clean it inside and out trying to make it look as new as I can.
                                      master hoarder
                                      • May 2008
                                      • 12164
                                      • Bulgaria
                                      That is scary!
                                      I used to pickup computer stuff from Craigslist and dumpsters until I got this:
                                      https://www.badcaps.net/forum/showpo...&postcount=122
                                      https://www.badcaps.net/forum/showpo...&postcount=126
                                      Ever since then, if I get something, I take it apart outside in my backyard as soon as I get it. If it looks even remotely nasty or even smells questionable, I toughly blast it with a jet of water from the garden hose. After that, more washing with detergent. Roaches are the last thing I want in my house.
                                      In my friends repair shop, we were given a Nintendo 64 once with a broken power jack (or something similar). It did smell funny when we got it, but luckily I was not the person that got assigned to fix it. When my friend took it apart and pulled the cover - run for your lives, said the 1000 or so roaches that ran out of it!
                                      Without further thoughts, we put the thing outside, far away from the building and called the lady who left it to pick it up. It was rainy that day too, but we didn't care. If anything, the rain probably did it some good with the cleaning.
                                      • Glitcher
                                        • Mar 2013
                                        • 673
                                        • USa
                                        I had a tv filled with roaches. I usually bring the tv home and put it on the floor of my room, and sometimes on my beds since I have like no space. One time I bought the tv to my room, but I saw one roach running around the tv and into the holes, so I thought oh I should probably do this in the bathroom (thought to myself its only one roach). Then in the bathroom I saw a couple more like 3 so I was like okay I am definitely not opening this thing in the house... Took it outside and opened it up and behold the hundreds of dead roaches inside.. and a few scattered.
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          by sam_sam_sam
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-12-2024, 02:30 PM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                          HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 08:10 PM
                                          HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
