Samsung PN50A510 P3FXZA Plasma Cycling On/Off
  • zape
    • Jul 2017
    • 176
    Re: Samsung PN50A510 P3FXZA Plasma Cycling On/Off
    Replaced IC101 and still clicking.
    Any ideas?
    • Unspun01
      • Jun 2011
      • 332
      C102 and C131 on this board are both same type of capacitor. You should replace both capacitors since both may be susceptible to failure.
      If you only replaced C102, you only did half the repair.
      I have repaired several A-series mainboards and C102 and C131 were all that was needed. I have not needed IC101.
      Try replacing C131 also.
      • zape
        • Jul 2017
        • 176
        I did not have a replacement cap so I tried to solder a 47uf electrolytic in a parallel to C131 but it did not help.
        Still clicking, after ~15 seconds clicking stops (but PS_ON continues to toggle), green red is blinking on the PSU, red led in front is blinking slowly.
        I have Y-SUS board disconnected (still repairing it)
        could this be the cause of clicking?
          1) When you solder the lytics cap to the to the C102, 131, did you observe the polarity? The Tantalum caps C102, 131 White band is Positive NOT negative like the band on the lytics cap.
          2) Is it low ESR cap that you use?
          • zape
            • Jul 2017
            • 176
            yes and yes
            I replaced C102 with a tantalum cap, it's the C131 where I used electrolytic.
            the thing is I replaced the C102 first, and then replaced the IC next to it.
            So I wonder if I could overheat the cap when replacing the IC
              Also look to see if the board has other NEC-TONKIN caps at other location too.
              https://www.badcaps.net/forum/showth...sung+LN52A650A
              • zape
                • Jul 2017
                • 176
                I wonder if these symptoms could be caused by Power supply board malfunction.
                Is there a way to check if the power board is OK? maybe force PS_ON and VS_ON?
                • zape
                  • Jul 2017
                  • 176
                  Here is a video of the clicking: https://photos.app.goo.gl/438gnUHw7oLNtWu57
                  • zape
                    • Jul 2017
                    • 176
                    So I disconnected Mainboard and shorted PS_ON to ground via 220 Ohm resistor
                    Still the same clicking.. Now I think it is Power supply board.
                    Any ideas? Could it be sort of protection? I noticed Va voltage is there at normal level, but VS is 0
                    • rccrasher65
                      • Mar 2014
                      • 594
                      Definately power board, shop jimmy has a repair kit for this power supply. get one for VS line repair, they provide more than what you need, replace all parts they give you, should fix your problem!
                      • zape
                        • Jul 2017
                        • 176
                        I also noticed there is a VS_ON on the PSU, could it be just Vs is turned on separately?
                        here is what I found in some random samsung manual:
                        3. If the PS_ON signal changes to Low, the Main SMPS supplies power to the Main Board and Logic Board, and Va and Vg power
                        is supplied to the DC-DC SMPS.
                        4. If the VS_ON signal from the Logic Board changes from Low to High, the Main SMPS supplies VS power to the X and Y Main
                        Board through the DC-DC SMPS, and the screen displays a picture on it.
                        • zape
                          • Jul 2017
                          • 176
                          I think I found it, and failed component is not in the Shop Jimmy kit
                          • rccrasher65
                            • Mar 2014
                            • 594
                            That's great, what component? kit is for basic use, fixes most problems.
                            • zape
                              • Jul 2017
                              • 176
                              7815 in Vg output was dead, ordered a replacement
                              This thread actually confused me and I was trying to fix the Main board and did not pay attention to the power board.
                              • zape
                                • Jul 2017
                                • 176
                                Confirming 7815 fixes it, also replaced CX820 Just in case
                                • electromech
                                  • Aug 2015
                                  • 8
                                  • US
                                  #216
                                  Bought a sammy PN50A550 back in 2008. With the help of this Group when
                                  C102 in 2011 failed I found it and replaced it with a 47uf 63v poly? radial cap (hangs off to the side) TV worked fine for 8 years. and it started with the same symptoms again. at the time I said to H___ with this and went out and bought a LCD ROKU that the AVS forums were recommending at the time. set the sammy off to the side and enjoyed my new LCD (LCD picture quality has come a LONG way since I purchased the sammy plasma). The sammy kept whispering at me "Come on boss, fix me!" so I did. Replaced the same 102 cap.
                                  Per earlier posts in this thread will check C131 and look for NEC-TONKIN caps as well.
                                  I'd like to thank the moderators and all you folks for your posts. I'd have given up on back in 2011 if it wasn't for all the help I've gotten here
                                  • jyoo
                                    • Mar 2015
                                    • United states
                                    #217
                                    Second post here regarding C102. I replaced C102 5 years ago and recently the power cycle with distorted screen and screeching noise started happening again. I thought it was C131 that others said to try so I replaced that and it didn't work. Then I put the old C131 back and replaced C102 again from 5 years ago and it fixed it again.
                                    • electromech
                                      • Aug 2015
                                      • 8
                                      • US
                                      #218
                                      Same here. I replaced C102 in the audio section with a poly on the side and it
                                      too failed after a few years. replaced it again and figure I have 4-5 more years.
                                      although LCD's have improved so much since I first bought my Sammy plasma I've already bought a TCL 55r617 to replace it before my 2nd repair on the Sammy. I'll probably park it in a less used room.
                                      • AlexVaq
                                        • Dec 2020
                                        • 9
                                        Originally posted by lp20th
                                        I found this forum while looking for fixes for my Samsung PN50A550. Same problem as described by others. TV goes into a clicking mode with no picture or sound. I wanted to share my final fix for this.
                                        As suggested in this forum, I replaced C102 and C131. Both of the original caps ended up checking out OK once I measured them out of circuit. No luck with this fix for me.
                                        As I was observing the set powered up with the back off, I isolated the relays that were clicking to two on the power supply board. By pressing on the board in this general area I manged to get the set to start working again. Most likely a cold solder joint or cracked trace on the PC board. The set worked fine for a couple of months and then it re-occurred.
                                        This time I removed the power board and found two cracked solder joints on the back side right under the relays. I attached pictures to show the location.
                                        It appears that the through holes are actually sized a little big for the pins. I noticed when I touched them up with the soldering iron, that the solder fell into the hole leaving a gap between the pin and the hole. When the board was initially wave soldered, not enough solder was there to fill the hole and over time this caused the joints to crack. Not sure which one or both were the culprits but I touched up both and the TV is now working fine.
                                        Hopefully this will help others with the same problem where the cap replacement did not work.
                                        That was so helpful! I didn't even have to replace C102, just resoldered the connections and the TV fired again. Thank you guys.
                                        • aaronwt6
                                          • Apr 2013
                                          • 855
                                          • US
                                          #220
                                          Shoulda replaced it. The problem will return shortly. Heating it most likely just made it work temporarily. The same results would have occurred from simply blowing a hair dryer or other heat source at it for a brief period.
                                            09-07-2024, 05:50 AM
                                          • high-tech
                                            Samsung UN55F7050AFXZA ver. TD01 power cycling
                                            by high-tech
                                            Hello everybody, I could use some help on this one... It's got me guessing...
                                            I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                                            (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                                            (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                                            (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                                            (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                                            9. ground (PWM2) 10. 0.9 volts cycling...
                                            09-15-2020, 03:39 PM
                                          • bcstedt
                                            Samsung PN50C540G3FXZA 50" Plasma, power cycling, Y-Main problem, Canada
                                            by bcstedt
                                            Just starting to crack into this one and wanted to get the ball rolling.
                                            At power on (plug in), power light on, relays click, repeat (sometimes)
                                            After disconnecting Y-Main from SMPS power stays on and boot up jingle is heard from speakers
                                            Removed Y-Main for inspection and testing
                                            This pic from:
                                            PN50C540G3FXZA Fast Track Troubleshooting Manual - Rev 1/10/12
                                            12-15-2023, 10:30 AM
                                            09-06-2024, 11:40 PM
