Screen change
    Screen change
    i have the following models a wharfedale L32TA6A and a sharp LC-32SH130K ,both 32 inch,is it possible to change screen from the wharfedale in to the sharp
    Re: Screen change
    im guessing only if the panels are made by the same manufacturer with the same model number and the same connections
    then yes you probably can
    but i will wait for the experienced guys to let you know
      Re: Screen change
      You need to look up the spec sheet of both panel to match the Inverter board and the T-CON board pin out and the required operating voltage and current.
        Re: Screen change
        Where could i find such info ?
          Re: Screen change
          Get the model number of the LCD panel assembly, there should be a sticker on the LCD panel, then just Google that model number.
          For example, you can see the white sticker in this pictures here:
          http://s807.photobucket.com/user/bud...tml?sort=3&o=3
          The pictures in this album is showing what I had to do to get the same LCD panel company but different model number to work, lots of works.
          http://s807.photobucket.com/user/bud...?sort=3&page=1
            Re: Screen change
            LTA320WT-L05 this is the panel for the wharfedale,have not opened the sharp yet.
              Re: Screen change
              Just Google the model and you will find the spec sheet for LTA320WT-L05
                Re: Screen change
                would it be possible to find the panel number for the sharp LC-32SH130K,instead of opening it up ?
                  Re: Screen change
                  No, because same model can have more than one brand of LCD panels, circuit boards, etc.
                    Re: Screen change
                    3110t-0598a this number imprinted in LCD ?
                      Re: Screen change
                      That does not look right, no manufacturer name on the tag?
                        Re: Screen change
                        That number is on the front around the screen
                          Re: Screen change
                          That SHARP probably uses SHARP LCD panel, so a swap would not be usually possible unless into/from another TV using a SHARP panel (certain Philips, LG, Samsung TVs.)
                            Re: Screen change
                            Not the wharfedale I've mentioned then
                              Re: Screen change
                              The part number you have listed is a Samsung LCD part. Sharp only rarely use Samsung panels.
                                Re: Screen change
                                If the fitment is ok would it be ok to swap over.
                                  Re: Screen change
                                  No, because the panel signals used by the main board probably won't be compatible, also Sharp usually do not use 24V inverters so that would not be a straight swap either.
                                    Re: Screen change
                                    Ok,what about a 17pw15-8 boardwhich I have in another set which is dead would the board out if the sharp be compatable ? 17pw82-2 ?
                                      Re: Screen change
                                      No, probably not. Only way to be sure is compare connectors but from memory they're completely different. Are you saying the Sharp you have is a Vestel based pile of crap? It may use a Samsung panel then, but if the Sharp/Vestel clone is much newer, it is unlikely the panels will be compatible, they change so often.
                                        Re: Screen change
                                        Just had another look the screen inside of the sharp is a lg panel lc320wxn
