Samsung LN40B650 Standby light on, won't turn on
  • Tiezane
    • Aug 2013
    • 98
    Hi folks,
    First time posting here. Trying to make ends meet for my family, and have some fun, so I started finding broken TVs on craigslist that I might be able to repair and resell. I picked up an LN40B650 that will not power on, the Standby LED comes on solid red when plugged in, and the TV does not respond to the remote or the power button. The guy who sold it said one day it just failed to turn on. I've opened it up and checked a few things, none of the caps are swollen as far as I can tell, but the bottom of the two 450V caps made me curious. I've checked both the fuses on the PSU and they are fine, I've checked all the diodes and resistors, and they seem fine as well. Since I am so new to this, I'm not really sure where to go next, but I'm open to direction The power supply board is labeled BN44-00264A. I've included some of the pictures I've taken, please let me know what else you might want to see. I should also note, the only tools I have available are a digital multimeter that does not include a capacitor test feature, a soldering iron, standard tools like screwdrivers, my brain, and a willingness to learn. I've also included a schematic I found for the PSU board.
  • capkid
    • Oct 2010
    • 1339
    Re: Samsung LN40B650 Standby light on, won't turn on
    The two 450V caps look fine to me, but that doesn't mean they aren't bad. Can you post a pic of the whole circuit board layout?
    Edit: What are your voltages at the CNM802 connector on the output side of the power supply? The good thing is that you have standby power. My first thought is that your main board is bad, but it will take more testing to make a solid determination.
    LG Plasma Mal-Discharge Correction Service
    • beano
      • Aug 2013
      • 9
      • usa
      I have the Same problem let me know if you find anything I will let you know if I do
      • Tiezane
        • Aug 2013
        • 98
        Here's two pics of the power supply board (front and back) and the mainboard (also front and back). In both cases, the boards were flipped top to bottom, relative to the picture orientation, to get the pictures of the backsides. Let me know if there are any areas of interest you need a closer picture of.
        • capkid
          • Oct 2010
          • 1339
          ok, can you post a pic of the whole back of the TV with the cover off? Also, please post voltage measurements at the CNM802 connector when you have them.
          • Tiezane
            • Aug 2013
            • 98
            Originally posted by capkid
            ok, can you post a pic of the whole back of the TV with the cover off? Also, please post voltage measurements when you have them.
            I can post a little later, what spots do I need to check voltages at? That's one of the things I wasn't sure of. I have to wait until after my girls go to bed so little fingers don't try to grab high voltages
            EDIT: just saw your earlier request for voltages on CNM802. newbie question, connect to one of the ground pins on there and just check the other pins, or should I be using the chassis as ground?
            • capkid
              • Oct 2010
              • 1339
              Chassis ground.
              • Tiezane
                • Aug 2013
                • 98
                CNM802:
                1 PWR-ON/OFF .793V
                2 H_Sync 85mV+
                3 STBY5.3V 5.21V
                4 GND
                5 GND
                6 GND
                7 13V(5) 12.54V
                8 13V(5) 12.54V
                9 GND
                10 GND
                11 GND
                12 GND
                13 5.3V 5.21V
                14 5.3V 5.21V
                15 5.3V 5.21v
                16 5.3V 5.21v
                17 GND
                18 GND
                19 13V (M) 12.54V
                20 GND
                21 13V (M) 12.55V
                22 13V (M) 12.54V
                23 Inv_ON/OFF 2.9V
                24 N.C.
                25 E-PWM 4.94V
                26 GND
                27 DET_5V 4.96V
                28 N.C.
                29 N.C.
                30 N.C.
                With the cable disconnected from CNM802, when I applied power the backlight immediately came on. I tried with that cable connected, and the cable to the T-Con disconnected, and it did NOT light up. I also tried with everything but the connection to the front buttons panel connected, and got nothing, EXCEPT...I tested each pin on CN1601, and got nothing. I accidentally connected pins 1&2, and the backlight came on, and stayed on as long as the pins were connected. When the connection was broken, the backlight turned off. CN1601 is the longer connector at the bottom of the mainboard. I'm thinking the voltages all look like they are reasonable, the only anomaly was the H_Sync voltage. It started low and kept climbing, over the course of 30 seconds or so, it got up to 85mV and seemed to be still climbing slightly, I don't know if that is normal or not. That would lead me towards thinking the mainboard is the issue, not the PSU. Let me know what you think, and if there are any other measurements you would like to see still.
                Last edited by Tiezane; 08-25-2013, 08:18 PM. Reason: Tried to format voltages better...
                  The main board will need more in depth troubleshooting, you can start by testing the voltage regulators and the switching supply on the main board, try to locate the main board diagram. Also look to see how much the replacement board will be.
                  The "PWR-ON/OFF .793V" should be around 1.5V or more when you switch on the TV, it is generated by the main board.
                  • Tiezane
                    • Aug 2013
                    • 98
                    Can you elaborate? The only way I was able to get a reading at that pin was to disconnect the white cable connecting the mainboard on the left to the power supply, and touching the pin directly inside the socket. Is there a different way I should have tested that pin?
                    Replacement main board is $75+. I've been trying to find the diagram for the main board, but my searches are coming up with nothing. If anyone else has/knows where to find it, that would be appreciated. This is apparently the same main board used in all the LN**B650 models. I found a link to someone with an LN40B630 with a similar problem, and someone there suggested resetting the EEPROM (see: This link) might be helpful, is that something that would be recommended here? If so, can anyone identify which chip on the main board is the EEPROM? I'll keep looking for that diagram to see what we can find. Thank you for all the help so far folks!
                    • capkid
                      • Oct 2010
                      • 1339
                      What's the part number on your main board?
                      Edit: Never mind. I was able to enlarge the pic to see BN94-02673F and BN41-01149A.
                        "Can you elaborate? The only way I was able to get a reading at that pin was to disconnect the white cable connecting the mainboard on the left to the power supply, and touching the pin directly inside the socket. Is there a different way I should have tested that pin?" Take the reading with all the connectors conneted.
                        You have already verify that the power supply and the Inverter circuits are working by disconnecting the cable between the main board and the power supply board then the backlights come on when you apply the power to the TV.
                        • Tiezane
                          • Aug 2013
                          • 98
                          I guess what I was trying to ask was what would be the best way to test with the connectors connected. From looking at this thing, I think the only way to do that would be to unscrew the mainboard, and access the back of it while plugged in to get to the matching pin there (the one on the back of the power supply isn't reachable with the cable plugged in.) Anyway, if you say it's all good, I won't worry about that one
                          • truep
                            • Aug 2010
                            • 373
                            I have the same TV on the wall in my bedroom! I bought it for $25 because it wouldn't power on. I ended up replacing the main board. I let it sit until I finally found on for $45.
                            It's a great TV and well worth the replacement cost of a new main. Just be sure the numbers match exactly (BN96xxxxx or BN41XXXX).
                            • Tiezane
                              • Aug 2013
                              • 98
                              I was curious about that, I've seen a lot of sites that have what appear to be replacement part numbers, but there seem to be 3 or 4, and if you search for those, there's another 3 or 4 that come up and ow ow ow my head.....
                              I'm still hoping we can find a diagram of the board, and see if there's anything I can replace to get it working again without buying the whole board. If not, $45 is pretty reasonable, and I did find some online last night that I'm keeping an eye on. I just figure if I can try to replace something on that board, the worst that can happen is I fail and have to buy a new board anyway.
                              • Tiezane
                                • Aug 2013
                                • 98
                                Found the board on eBay, also for $45, should be here by Saturday, eBay says. I'll swap it in and see what happens. I'd still like to try to figure out what may have died on the mainboard, so I can try to repair it in case the new one ever goes bad, I have a backup
                                • Tiezane
                                  • Aug 2013
                                  • 98
                                  I finally managed to find a service manual, it covers the ln40, 46, and 55B650 models. It looks like the EEPROM is IC112, but in talking with another person on the phone, the manual he had showed it might be IC1201 or IC1603. It's a 24C02 EEPROM. I'm going to look for it tonight, and see if I can try the forced reset of the eeprom to bring this thing back to life at all. At this point, the worst that happens is... nothing and I have a new board coming anyway. I think I found IC1201 on the pictures I posted, but it's hard to tell. It's definitely an 8pin chip right below the HDMI 1 port, and above the RCA input block. I'll post later with results. Uploading the manuals for anyone else who needs them. The Disassembly & Reassembly, Product Specification, and Troubleshooting PDFs are too big to upload. Relevant ones attached.
                                  • Tiezane
                                    • Aug 2013
                                    • 98
                                    Finally got around to trying the EEPROM reset... and I can't find the EEPROM. IC1201 and IC1603 are not the right chips, they were marked ATMLH842 and ATMLH852 respectively. Could not find IC112 or a 24C02 anywhere on the board, and I went over it with a magnifying glass and a flashlight, and triple checked every 8-pin IC I could find. guess I'm just going to have to wait for the new board to arrive.
                                    • martino
                                      Not so "senior"
                                      • Aug 2013
                                      • 997
                                      • canada
                                      On my samsung(different model tho) I couldn't find the eeprom either.
                                      Had to remove the mainboard and on the backside of the board I found these "test points"..I soldered wires on them so that I could connect them with mainboard installed in tv...
                                      Proud owner of dozens of broken TV's and many,many,many boards.
                                      Our website and passion:http://hollenhundshepherds.com/
                                      • Tiezane
                                        • Aug 2013
                                        • 98
                                        I'll have to pop the board off again and look for those. It was late, I was tired, and trying to find it with a flashlight and a magnifying glass. Do you have a model # for your board by any chance?
                                        • Kaar3l
                                          Samsung QLED QE65Q7FNAT only standby light
                                          by Kaar3l
                                          TV: Samsung QLED QE65Q7FNAT
                                          PSU: BN4400940A
                                          MB: BN94-12832K
                                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                          09-24-2024, 01:35 PM
                                        • Nicktronic
                                          Samsung UN70NU6070F Standby Light flashes twice
                                          by Nicktronic
                                          Hey Everyone,
                                          So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
                                          I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
                                          03-27-2023, 07:01 PM
                                        • PNI E.
                                          Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                          by PNI E.
                                          Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                          03-17-2025, 04:23 AM
                                        • Jackching
                                          Samsung UN46EH5000F wont turn on. Blinks red standby light continuously
                                          by Jackching
                                          I know for sure it has a bad cap and one cold solder joint. Just wondering before i order the Caps if anyone has any experience with this model? Just making sure there isnt a common component that goes bad besides the caps....
                                          04-15-2024, 05:14 PM
                                        • ctroxtell
                                          Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
                                          by ctroxtell
                                          I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
                                          01-03-2025, 08:57 PM
