Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
  • ctroxtell
    • May 2022
    • 26
    I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different chip labeled 1MGH 168 AN36 on a different board section and the 3202 chip on this board does not get hot. I'm still learning about components, but measuring in diode mode to some of the capacitors around the chip that are getting hot shows 0.0v if I measure with my red probe on the ground to both sides of about 4 of the surrounding capacitors. Am I correct in saying these capacitors have a short? Thank you for any advice.
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    You need the correct board not a mismatch x version.
    Scroll down each one and you'll find your x board isn't for your tv it's for different set.
    https://www.shopjimmy.com/samsung-bn...7000fxza-ce36/
    https://www.shopjimmy.com/samsung-bn...700dfxza-ua02/
    • ctroxtell
      • May 2022
      • 26
      The only one that list the WXZA model is https://www.shopjimmy.com/samsung-un...-version-be11/ and it shows that "
      Manufacturer Part Number 1:
      Samsung BN94-00053T|Samsung BN94-16115X|Samsung BN94-17775A|Samsung BN94-17775V
      So it is a compatible board from my understanding.
      • EazyBone
        • Jun 2023
        • 1362
        • United states
        So the TV turns on and just blank image?
        I would check the buffer boards for shorted capacitors. I have had tvs like this I couldn't figure out.. although the 260f chip isn't normal so they board obviously is bad.
        • nomoresonys
          • 12328
          • U.S.
          probably received a bad board, if they can't replace it get a refund and buy another.
          • ctroxtell
            • May 2022
            • 26
            The TV will not even turn on, I have no standby light. I found the service manual for the TV and it says "
            If LED is OFF
            Check LED 1.7Vdc (pin 14 ) and VCC for 5Vdc (pin 4 )
            9
            If missing suspect Function Assy/Cable/Main board"
            If I measure from pin 4 to the TV frame, I get 5V, but from pin 14 to the frame, I have nothing. I just wanted to ensure the way I was checking the surrounding capacitors was correct. I've requested a replacement and am waiting to hear back from TV Parts Today.
            • ctroxtell
              • May 2022
              • 26
              Just wanted to do a final update, the boards were bad. Maybe I will attempt to repair them, if so I will post updates.
              • EazyBone
                • Jun 2023
                • 1362
                • United states
                So the TV was fixed with a new board? What exactly
                • ctroxtell
                  • May 2022
                  • 26
                  Yes, ended up needing a replacement main board. Used a BN94-00053T, TV Parts Today obviously had sent a cracked power board and bad main board.
                  I've got an issue with the main board for another TV for which they sent me a replacement main board as well, none of the HDMI ports recognize what is plugged into them, name wise. They show up as "Unknown", I can name them but as soon as I unplug them they revert.
                  • nomoresonys
                    • 12328
                    • U.S.
                    Yes, that shop has a bit of a reputation for sending out unverified boards.
                    • Kaar3l
                      Samsung QLED QE65Q7FNAT only standby light
                      by Kaar3l
                      TV: Samsung QLED QE65Q7FNAT
                      PSU: BN4400940A
                      MB: BN94-12832K
                      I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                      09-24-2024, 01:35 PM
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • ohren
                      Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                      by ohren
                      I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                      I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                      The models launched in 2018 and 2019 respectively....
                      09-08-2023, 05:24 PM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • Michael Long
                      No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                      by Michael Long
                      I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                      Dead / No Power / No Standby Light results after power company had three
                      consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                      After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                      09-13-2022, 06:55 AM
