Samsung LN46A650 backlight turns off after a while
  • tibimakai
    • Jan 2012
    • 3680
    I have picked up this TV in very nice condition, pretty cheap.
    It would turn on and after a while the backlight would turn off, with sound still on and image still on.
    First thing that I did, I have replaced all the capacitors with Panasonic capacitors.
    It seemed like it took care of the problem. I have left it for hours to run for like two days and it was fine.
    Then, on the third day, after a while the backlight turned off again.
    TV still runs fine with sound and image, but no backlight.
    I'm measuring some of the ICs and they are pretty hot ~52 C*.
    I'm wondering if this is heat related or is something else.
    The whole power board and mainboard has a big steel perforated cover on them.
    This on it may block even more the ventilation.
    Tmorrow, I will take some measurements.
    What should I look for?
    Any ideas would be appreciated.
  • capkid
    • Oct 2010
    • 1339
    Re: Samsung LN46A650 backlight turns off after a while
    You could try a hair dryer and cold spray to see if you can consistently reproduce the issue.
    LG Plasma Mal-Discharge Correction Service
    • leonard
      Leonard085
      • Aug 2010
      • 10
      • Ireland
      what is the psu type, example bn44-***
      and is the invertor separate from the psu pcb
      • tibimakai
        • Jan 2012
        • 3680
        I'm not home right now, but I think that this is my board:
        http://www.shopjimmy.com/samsung-bn4...wer-supply.htm
          Schematic
          Related service documents
          • tibimakai
            • Jan 2012
            • 3680
            It's 100 degrees in my garage, I can't work in there.
            I have left a 20" fan pushing air on the TV from the back side without any covers on it and it did the same thing, so maybe it's not heat related. I don't have any sprays at the moment.
            • aaronwt6
              • Apr 2013
              • 855
              • US
              Looks like PS and Inverter all on one board. I see one on ebay as cheap as $40 shipped. I'd probably take the plunge for a TV that size.
              Of course I guess it could be one of the CCFLs but seems unlikely if the picture is uniformly bright when its on.
              • tibimakai
                • Jan 2012
                • 3680
                I should probably take it apart and look at the tubes, to see if any one of them is acting up.
                  I wouldn't immediately consider that; I'd look at the main board and PSU/inverter first.
                  • aaronwt6
                    • Apr 2013
                    • 855
                    • US
                    My first guess is the power feeding the inverter transformers is dropping out. The $40 board just seemed pretty nice to me given the value of a 1080p 46" set in good condition.
                    Of course troubleshooting the board is never a bad thing. I've learned a ton here in the last few months.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      I have taken some connector measurements before and after and these are the differences:
                      Small connector gong to the balancer board on the left:
                      LD: before= 9.84V after= 9.95V
                      Small connector going from PS to main board:
                      PWM: before= 3.87V after= 2.5V
                      No changes on the main connector between the PS and main board.
                      I have noticed a familiar diode on this PS board MUR460. If I remember well, this diode used to fail on some other devices no?
                        MUR460 can fail but causes no backlight at all (ever), would not be likely to cause your fault but you can rule it out by checking PFC cap voltage (450V cap) it should be around 380V to 400V. If it is near 170V there is a fault.
                        I'd try forcing VPWM high (to 5V thru 1kohm resistor); may be that main board is dimming backlight (energy save if no signal, or dark scene), causing a bad bulb or the inverter to struggle to maintain correct output.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          Today I have put a small(turbo) fan close to the main board and it did not turn off. There is another metal cover that should be over these boards and at one point there is a heat transfer sponge like material, but I don't think that it would matter that much.
                          I have took a picture with the board, still mounted.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            384V stays on, when the picture goes out.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              Any other ideas?
                                Where is this heat transfer pad?
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  Which one?
                                    PSU SCH
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      I'm not home now, but I remember that there is only one small sponge like transfer pad somewhere in the middle of the cover which covers the PS and mainboard PCBs.
                                      I belive that the heat transfer pad is for the mainboard. I will ckeck it when I'm home.
                                      There are at least two processors that run around 55 *C and they don't have any heat sinks.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        The main processor on the main board, has a heat sink on it and the heat transfer pad is between the heat sink and the metal cover.
                                        I have replaced that sponge like heat transfer pad, with the other "wet" type and it didn't fix the issue.
                                        • kalemaroni
                                          Samsung QE50Q60AAUXXH turns off as soon as backlight turns on
                                          by kalemaroni
                                          Plugging the power in will turn on the backlight after about 5 seconds and then immediately shuts down.
                                          If I unplug either of the two cables with the yellow outline in the picture the backlight stays on and the startup sound plays but no image. Any ideas how to proceed with this please?
                                          07-16-2025, 04:53 AM
                                          09-07-2024, 05:50 AM
                                        • C152Heavy
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
                                        • www
                                          LG L192WS-BN backlight turns off after 1 second
                                          by www
                                          I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                          I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                          03-24-2024, 05:26 PM
                                        • frannyjunk
                                          Hisense 40H4F no backlight but turns off after splash screen
                                          by frannyjunk
                                          So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
                                          TIA.
                                          09-24-2025, 10:59 AM
