samsung UN22D5010 no power
    Re: samsung UN22D5010 no power
    This is only 22" TV, it is not really worth it to get the new boards, but you can inspect all other components on the power supply, the main board, the LCD panel board, etc.
    • jose6326
      • May 2013
      • 707
      What else should I test on the psu?
      • jose6326
        • May 2013
        • 707
        I think the diodes are good
        Dm801: 1st reading OFL, 2nd reading 0.469(leads reversed)
        Dm802: 1st reading OFL, 2nd reading 0.453 (leads reversed)
        • jose6326
          • May 2013
          • 707
          Originally posted by budm
          OK, that part is more likely to be the ref Diode which is part of the regulation feedback. Since it burnt so bad, that means the surge must have come through the Cold secondary side of the circuit, so more likely you will have more damaged parts in the power supply and the main board.
          Bud the pdf you attached is of the burned component on the backside?
          reason i ask is because the electronics guy at work removed it for me today and it doesnt look like the one in the pdf
          the one i removed is a surface mount with only 3 legs
          i attached a pic of it removed
            Yes, the SMD ref diode has 3 legs, something like TL431.
            • jose6326
              • May 2013
              • 707
              Bud i already replaced the IC under the heat sink
              i replaced it with a ICE3A1065ELJ ( pdf is attached in previos posts)
              Tom confirmed i can use this one since the original had a lead time of 12 weeks and a minumum quantity of 1200pcs
              how do i figure out which diode i need on the back side of the board which you said might be a TL431?
              • capkid
                • Oct 2010
                • 1339
                Ideally, you can look up the part numbers in most Samsung power supply service manuals. There don't appear to be any free service manuals available for this TV. I keep seeing "KA431" for other Samsung power supplies when I do a search by "ICM851 Samsung"; I've always understood KA431 to be the same as TL431.
                LG Plasma Mal-Discharge Correction Service
                • jose6326
                  • May 2013
                  • 707
                  im on the digikey website and there are several TL431
                  which one should i get?
                  also should i replace the start up cap and the fusible resistor?
                  i want to make sure i order all the components at one time
                  • capkid
                    • Oct 2010
                    • 1339
                    This appears to be a good replacement: http://www.digikey.com/product-detai...64-1-ND/863961
                    Bud will know better than I would. It looks like your resistor is ok, but I might consider replacing it. I couldn't see the bands' colors well in your pic, but another pic online shows them as yellow, black, silver, and gold: 0.4 ohms 5% tolerance. It wouldn't hurt to replace the cap; most will recommend Panasonic FM, FC, or FR series caps.
                    • jose6326
                      • May 2013
                      • 707
                      yes you are correct on the resistor
                      i will order the cap and resistor
                      what about the chip on PC801S?
                      should i replace that as well?
                      digikey does not carry the resistor
                      • capkid
                        • Oct 2010
                        • 1339
                        I doubt that PC801S is faulty. I'd just replace the resistor, cap, and ICM851.
                        • jose6326
                          • May 2013
                          • 707
                          digikey and mouser do not have the resistor
                          i will order the rest and continue to search for the resistor
                          • capkid
                            • Oct 2010
                            • 1339
                            The resistor may be ok, but I'd feel more comfortable replacing it.
                            • jose6326
                              • May 2013
                              • 707
                              Im waiting on parts from digikey
                              What should I check on the main board?
                                OK, the opto's iNternal LED (the black 4-pin device) is connected in series with the ref diode, so if the ref diode blew up, then, the opto is more likely to be damaged also.
                                • jose6326
                                  • May 2013
                                  • 707
                                  Can you point this out for me on the pic?
                                  Is this on the psu or main board?
                                    PC801S close to that burnt component ICM851, you can see that in the app notes diagram I have shown also.
                                    • jose6326
                                      • May 2013
                                      • 707
                                      You are talking about the opto labeled "30C"
                                      Should I order an extra one to replace the one above it (RM863)
                                        This one https://www.badcaps.net/forum/attach...2&d=1376019195
                                        • jose6326
                                          • May 2013
                                          • 707
                                          I was going to order that but Capkid said it was probably still good
                                          I will order it
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • mrtek
                                            Samsung UN43NU6950FXZA No power
                                            by mrtek
                                            Hi
                                            Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                                            Main fuse = OK
                                            Back light LED = OK. Power them with aux power source
                                            LED output = OK 156V
                                            I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                                            Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                                            07-20-2025, 08:06 PM
                                          • hill01
                                            Samsung UE75MU7009TXZG Endless Power Cycle
                                            by hill01
                                            Hi everyone and thanks in advance for any help I might get here
                                            My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
                                            About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
                                            Since a few days, the TV won't turn...
                                            11-17-2021, 02:52 PM
                                          • Journey11
                                            Samsung TV won't turn on ... keeps cycling the power relay on & off
                                            by Journey11
                                            Hi All,
                                            First time posting here ... my name is Kevin but my friends call me Journey.
                                            I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                                            After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                                            It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                                            07-04-2024, 02:44 PM
