Panisonic 42inch TCP42S30 not working!!
  • Glitcher
    replied
    Re: Panisonic 42inch TCP42S30 not working!!
    some of the fets are actually in parallel so if one is shorted, both will appear shorted, so youll have to lift the leg to actually figure out which is bad.
    Also keep in mind, that not all of them are fets, but some are also diodes which will measure shorted from pins 1 and 3 (this is normal).
    What are the part numbers for the ones you found? and can you post a photo of the entire board?
  • Hok
    replied
    ok just found 4 more - apparently shorted fets, lifted the legs and they won't pass voltage (tried the open gate then test for falling voltage) neither do they have any resistance, so i've either destroyed them or they're destroyed already.... these are Q451, Q441, D621, D622... Still have a short, but only in one direction (red to pin 1 and com to pin 2) other direction reads great
  • Hok
    replied
    Perhaps only 3 of these igbt were bad - 3 read resistance of 9-12 Ohms, while the fourth reads 0.2 Ohms. nevertheless, still getting a short at SN2
  • Hok
    replied
    Thanks, Glitcher... Is it possible to test the mosfets that remain without lifting a leg? I did just lift a leg on one common culprit and it's reading 0 ohms now, whereas is was 46K ohms before lifting the leg so perhaps i'm doing something wrong?
  • Glitcher
    replied
    I just recently repaired a TCP46S30 with an SC board failure, with the usual 3 bad fets. The short between the main connector should be gone when measuring in both directions. If all the bad components are removed, the short should be gone. At least on my model it did, but im not sure if its the same.
  • Hok
    replied
    Would anyone care to walk me through the troubleshooting of the SN board?
    I have removed q401, q402, q421, and q422 from the board. Bit of a pain with a 25 watt iron...
    I am still getting a short at SN2 from pin 1 to pin 3 (though I'm not sure i'm doing this right - assume com goes to ground as always i.e.- red to pin 1 and com to pin 3)
    However, I am testing other components which are included in the #$# repair kits on ebay and can't be sure if 1) the results are correct, since they are all in circuit and 2) what kind of results i'm looking for and 3) If I remove all failed components without replacing them would the short at SN2 miraculously disappear?
    any takers?
  • Hok
    replied
    Hi folks, complete novice here with the same issue on Panasonic TC-P42S30 set. I am a veteran DIY'er but not very knowledgeable of electronics. However, I'm ready and courageous enough to dive in and give this a shot.
    Thanks to tw2005, Tom, and other users on this forum, as well as austech forum and the great training manual that Tom uploaded, I have narrowed down my issue to the SN board.
    I would like to continue troubleshooting the board, but I am unable to do so without a bit of help. I hope that some of you might step to my aid...
    I believe I have identified 4 bad IGBT's and have lifted their legs, but would like to verify that and continue to test other components on the board if possible. I don't know if I am testing the resistance at SN2 pins properly. With Com lead on pin 1 I get 31k Ohms, but with leads reversed i get a short. Which one should I believe?
    And, how should I proceed to test other components on the board? I am trying to test mosfets but am getting varied readings and can't figure out which ones, if any, are bad.
    Could it be that the four I found are the only bad parts... (the gates don't close when i try to short drain-gate, so I'm guessing this means they are bad.)
    Would love to continue this project, so if anybody could offer a good place to start I'd be very grateful.
  • tw2005
    replied
    Originally posted by Waggy
    I have tried replacing the power supply board but still has 14 blinks, suggestions?
    As what CAPKID mentions, read post 3, check the link out, read my post 6 and check those links.
    Check this link out also https://www.badcaps.net/forum/showthread.php?t=30502
    as I have additional info regarding 14 blink and solid LED indication. Post 2 and guide in post 3 should be of some use.
    Most likeley will be shorted SN or SS boards, not the PSU as you have worked out with a replacement and no change.
    14 blink
    Shorted F15V developed after the TV is up and running.
    Holding the power switch for over 5 seconds after the unit has gone into shut down and it’s in lock mode with the power LED solid red (Note: the LED stays on if the power button is momentarily pressed).
  • capkid
    replied
    Did you check the link I posted? The original poster had a bad SS. Again, I'd read through that thread and test before assuming that replacing the SS board will solve your problem.
  • Waggy
    replied
  • tw2005
    replied
    As per CAPKID, Check for shorted Vsus lines on the SN and SS boards. You can get wrong and some weird SOS blinks when there's a dead short on those.
    https://www.badcaps.net/forum/showth...RJP30E4&page=2
    https://www.badcaps.net/forum/showth...ight=tc-p42s30
  • RJARRRPCGP
    replied
    My Panasonic TCP42S30 suddenly turned off when I was watching it. I unplugged it and plugged it back in and still nothing happened, but when I turn it on the red light blinks 14 times then pauses and blinks 14 times again. It also has no picture AND no sound. Help!?
    May have been damage from a poco issue. Did you see anything else in the building stop briefly?
  • Waggy
    replied
    Yes I opened the back. Everything looked fine from what I could see.
  • capkid
    replied
    Panasonics don't normally have cap issues. Here's a thread for a similar issue:
    https://www.badcaps.net/forum/showthread.php?t=23815
    I wouldn't jump to the conclusion reached in the thread I provided without doing some checking.
  • guyonphone
    replied
    Hello Waggy,
    Have you opened up the back and checked the power supply for bulging/leaking capacitors, that's where I would start.
  • Waggy
    started a topic Panisonic 42inch TCP42S30 not working!!
  • MMH3
    Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
    by MMH3
    i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
    Never ever i experienced problems with that.
    Now i have one 5050sff machine, where this jumper isnt working at all.
    I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
    The history of the machine is that i used it in my office...
    03-23-2025, 09:28 PM
  • DynaxSC
    GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
    by DynaxSC
    I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
    There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
    The board is generally working now, all PCIe ports are working, Windows installs normally.
    However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
    The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
    03-10-2025, 12:27 PM
  • obelix24
    Macbook Air 2020 (a2179) - touch id not working
    by obelix24
    Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
    I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
    02-09-2025, 12:57 PM
  • hopkok
    Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
    by hopkok
    Hi masters, I need your help.
    I am working on Lenovo Legion 16ITHg6
    Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
    INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
    My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
    AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
    Power LED is not working as well, power button working well.
    UI26 ??? is there any firmware too? Powered by +3VALW_AG.
    Motherboard...
    05-04-2025, 09:35 AM
  • bociub
    laptop freezes, usb 2.0 not working, usb 3.0 working
    by bociub
    Hi there,
    It is sunday and I got a faulty hp pavilion 15-cs1006na. No available schematics on the entire world. It flashed 5 long 4 short and no post then I discovered the usb 2.0 2. pin in one of the usb-a socket bent backwards and been shorted to 2. and 3. pin of the 3.0. after removing this short in the port the laptop came alive.
    Now the laptop freezing randomly. The webcam, the built in mic and according to the device manager one more thing not working which are connected to usb. If I connect anything what have usb 2.0 plug that wont work if i plug anything what...
    08-25-2024, 03:44 PM
