Panasonic plasma TC-P42S30. What is killing my SN boards?
  • mattpd
    • Oct 2012
    • 302
    I have a Panasonic plasma TC-P42S30 that I bought with 14 blinking lights. I know 14 is not listed in the service manual but I assure you it's 14. I bought a new SN board and installed it. It worked for a few minutes but with a few black lines across the screen. I wiggled one of the tab connectors and the TV shut off. I thought maybe this was my fault, so I ordered a new SN board. The TV came on again with the new board, but it still had a few black lines. This time I didn't touch ANYTHING, yet the TV still turned off after 30 seconds and has 14 blinks again.
    I'm digging myself a hole with TV. Help me get out please! The only connections to the SN board are the tabs to the panel, one ribbon cable to the main board, and the power cord that goes to psu. I assume the psu is doing something crazy.
    Re: Panasonic plasma TC-P42S30. What is killing my SN boards?
    14 blinks is an odd error but is explained in a training manual
    http://tgohome.com/ServiceManuals/Pa...nd_extra_info_[TM].pdf
    (slide 56.)
    It is NOT an SN/SS board error (those can only be 4, 6, 7 or 8 blinks.) It is an audio PWM error, possibly bad audio amplifier or shorted output.
    • mattpd
      • Oct 2012
      • 302
      Strange. Audio works great as long as TV is on. And the only way the TV will come on is to put a new SN board in (this is my third one). The board had no short when I put it in, now it has a short. It is in these components and possible somewhere else too.
      Also, I read on another website (I think justanswers, I will try to dig it up) about a guy that had 14 blinks, and his problem was sorted out with a new SN board. Unfortunately it only sorts my problem out for less than a minute.
        It might be 15V too high causing the problem.
        • mattpd
          • Oct 2012
          • 302
          So I can find any place on the power board labeled "+15vc" and test there?
            On the connector from SN to SS there is a 15V supply along same cable as Vs (200V.) The PSU also provides 15V standby power.
            • mattpd
              • Oct 2012
              • 302
              There is no connection from SS to SN. SN only has a ribbon to the A board, and the VSUS connection to the PSU, and the tabs to the panel. I did check the 15v going to the SS board and it is within spec. Also checked the VSUS going to SN and it is 200ish.
                Oh, OK, this is a different design, it goes through P board, so check the voltage on the pins on the P board.
                • mattpd
                  • Oct 2012
                  • 302
                  With the SN board plugged in the VSUS never shows voltage and neither does the 15v. With the SN board unplugged from PSU the TV gives 206v briefly before it shuts itself off and the 15v gives 15.6 very briefly.
                  When SN is unplugged TV comes on for a second with sound, and then turns off with 8 blinks. SN plugged in and I get no sound and 14 blinks.
                    8 blinks is SS error. Maybe a bad SS is killing SN. tw2007 and rayrod know a lot more than me about Panasonic plasmas.
                    • mattpd
                      • Oct 2012
                      • 302
                      Too bad you are the only one willing to help... Thank you though. I may look into getting a new SS
                        They might be busy. I need to do my maths homework, too.
                        • mattpd
                          • Oct 2012
                          • 302
                          K, have fun!
                          Just a few more pieces of info. With the SS board unhooked and SN hooked up I get 14 blinks again. I guess it check SN before SS? If I unhook BOTH boards at the same time, the TV seems to operate normally (of course I have no picture or sound) but I don't get blinks, and the TV turns off and on with each press of the power button which it would not do before.
                          EDIT: With both boards out it operates normally, with no blink, as long as I don't leave it for more than a minute. After about a minute it shuts off and gives 6 blinks... Before it would read 215v VSUS for only a second, now it reads 215v for the full minute until it shuts off. Within this minute window I can power on and off normally.
                          • mattpd
                            • Oct 2012
                            • 302
                            I just took a second look at the service manual and at the troubleshooting flow chart. It turns out there is a status LED on both the SS and SN board... It says to check both boards for the LED and if not lit replace both boards... I should have paid more attention the first time around... I have never seen the LED light up on the SS and it lights up on the SN the first time I hook it up, but only until SN shorts out...
                            I am pretty confident that replacing both boards at the same time should fix it (fingers crossed).
                            • mattpd
                              • Oct 2012
                              • 302
                              Got the tv working. It was a bad SS board that caused the SN boards to fail.
                              • BL4CKWAT3R
                                • Aug 2013
                                • 2
                                So when you found out that the TV give you a status on the SN & SS Boards by lighting up if they're functioning properly, did you hold down the power button to see it give you said status via LED lights on the SS & SN Boards? My tv is having a similar issue. Power led blinks 14 times and the tv doesn't have sound or visual. SO far i haven't notice any LED's light up on the SS & SN Boards. Can you possibly help me out?
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  Check for dead short on the Vsus line at the SS and SC boards.
                                  • BL4CKWAT3R
                                    • Aug 2013
                                    • 2
                                    And how do you check for a dead short on the Vsus line? I tried educating myself and learning what the boards and parts on the back look like and their names but all i know is what the SS,SN, and main board looks like.
                                    • fasllc
                                      • Jan 2015
                                      • 1
                                      Hello group. I just got a TC-P42S30 from craigslist, with no a/v. The PO said initially, the TV had 14 blinks. He sent in a board to be repaired. When he reinstalled the repaired board, he said the TV worked fine. Then the TV went out again and had 7 blinks this time.
                                      The PO stated he spent $50 and he was done. The TV was free. I got it for my older sister, who has been down on her luck for awhile now. She is still watching a 19" tube set at this time and I REALLY want to fix this TV and surprise her with it. My issue is I don't have alot of cash to be buying parts, the majority being used and I am concerned the used parts will go bad in no time, as did the original parts.
                                      I can buy her a LCD 'Dynex' TV for $210 shipped, but to be honest, that is more than I want to spend. I don't mind spending $100 to fix this TV, just don't want to fix it and 3 days later get a phone call. At least the new one has a warranty, but the Panny is a better set I'd imagine. The bonus is this Panny is a smart TV (I guess, I haven't seen it in operation...yet!)?
                                      SO, I guess I am looking for advice. What would you do? Repair this sweet plasma or get a lesser quality LCD? Thanks in advance for any assistance...
                                      • slidewire
                                        • Feb 2011
                                        • 10
                                        My experience has been, with Panasonic models manufactured after 2010, it doesn't always matter what the error code is, the problem is likely a shorted SC or SN board.
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          I happened several times, in the search for help from the web, to consult this very interesting forum.
                                          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                          Having said that I come to the gist of my post on the forum as the title suggests.
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                          Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
                                          by sam_sam_sam
                                          I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
                                          This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • canadaboy25
                                          Panasonic TC-P54VT25 No image. A or D board?
                                          by canadaboy25
                                          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                          The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                                          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                          01-17-2021, 01:06 AM
