Panisonic 42inch TCP42S30 not working!!
  • Hok
    replied
    Re: Panisonic 42inch TCP42S30 not working!!
    Hey I found TPSOS6 on the board.... it's nowhere near the replaced IGBT's... only problem is I don't know what to do with it
  • Hok
    replied
    Don't see a green led on the SN board, but I do see the SS board (green LED) - lights up for a second. Screen turns on for only a second, not 2 secs, and there is a click on the P board when it shuts itself down into SOS mode.
  • Hok
    replied
    tell me where on the board should I find the green LED?
  • Hok
    replied
    yes then shut down and 6 blink... i will put the board back in, hook it up, and check for the green LED if that would help.
  • tw2005
    replied
    Originally posted by Hok
    don't recall seeing a green LED ever on this set - not sure it has one
    On the SN board there's a tiny LED, SS has the same. So you get a normal display for 2 sec then shutdown?
  • Hok
    replied
  • tw2005
    replied
    nothing popped. The TV turns on like normal, screen comes up, then after 2 secs (or less) the screen goes black and 6 blink comes up. Repeats the same every time. Did check the IGBT's and they all seem to be in order. Same with the diodes. Resistors also all just under 8 Ohms, so they seem to be fine. Need to pop out for a few hours... if you have any bright ideas, i'll follow up when I return.
    Are you saying you get a normal display for 2 secs? was the green LED lit at all?
    No real ideas, still clutching to the hope we can sort it out. i'll be off by then,
  • Hok
    replied
  • tw2005
    replied
    To a point but the difficulty is the manual is no good for blowing the image up. I found a 50GT30 manual from another region which must have a very similar cct design I'm using to get an idea.
    Nothing popped when you powered up for the 6blink?
    So all IGBTs ahve been rechecked for short, nothing there missed?
    How about any diodes around the areas ofd the failed transistors, nothing shorted there?
  • Hok
    replied
    Is there a methodical way to go through the board by sections to narrow down where the issue may lie? Since I'm not showing a short, I wonder if that's a silly question... but had to ask.
  • Hok
    replied
    Yes, and that's a cool slide
  • tw2005
    replied
    With those transistors, just checking if it's pins 1-5, 2-3 you're measuring. Slide below was from ny board when I was working on it.
  • tw2005
    replied
    I see that IC521 and IC522 (while similar) are different than the others, but I do see pin 7 at IC684 has a sizable variance compared to the others, which came in at similar readings on pins 1 and 2.... Do you need the reference data/measurements from the SS board as well?
    No, thanks for that but that has not made anything clearer except maybe to suggest the problem is elsewhere. Was trying to use my SC as a guide but the FET driver IC is completely different and the measurements also different at hos points. i was hoping to find one completely different to the rest.
  • Hok
    replied
  • Hok
    replied
    IC501
    PIN 1 .535 M Ohms and still rising slowly after 30 secs
    PIN 2 .465 M Ohms steady
    PIN 7 28.3 M Ohms decreasing (30 seconds)
    IC684
    PIN 1 .597 M Ohms and still rising slowly after 30 secs
    PIN 2 .464 M Ohms steady
    PIN 7 6.04 M Ohms steady
    IC502
    PIN 1 .566 M Ohms and still rising slowly after 30 secs
    PIN 2 .469 M Ohms steady
    PIN 7 28.8 M Ohms decreasing (30 seconds)
    IC522
    PIN 1 17 k Ohms steady
    PIN 2 4.72 k Ohms steady
    PIN 7 25.2 M Ohms steady
    IC521
    PIN 2 4.77 k Ohms steady
    PIN 7 24.89 M Ohms steady
    Q501
    24.6 M Ohms & 24.38 M Ohms
    Q522
    24.07 M Ohms & 24.03 M Ohms
    Q531
    24.68 M Ohms & 24.34 M Ohms
    Q551
    24.08 M Ohms & 23.99 M Ohms
  • Hok
    replied
    Aah, I see how i got the reference per your diagram - because Q531 is sitting to the right of IC502... this gives me a reference for the others; will report results shortly then go off to check the IC's on the SS card.
    In addition, IC502 DOES have numbers PRINTED on it, (not imprinted) - just had to be at a severe angle to see them. Same numbers.
  • Hok
    replied
    working on it now. There's a slight frame of reference issue.... If pin 1 is on the upper left side.... The only identifying mark on the ic is a small dot, which is either on the upper left side or the lower right side... Didn't even occur to me that I may be testing the wrong pins on the IC502... How can I adjust my frame of reference for the pin numbers?
    Actually: IC502 has no numbers imprinted on the surface, just the small dot. However, IC501 and IC684 each have the following numbers imprinted on it... (the O is the dot)
    D 6
    9 3
    ONS
    (The pins run horizontally to the numbers, across the top and the bottom)
  • tw2005
    replied
    https://www.encompassparts.com/item/...0ZBZ0001822/Ic
    https://www.encompassparts.com/item/...001/Transistor
    https://www.partstore.com/SearchResu...=PMN&x=25&y=12
    https://www.partstore.com/SearchResu...p=PMN&x=20&y=7
  • tw2005
    replied
    I got an idea. I think I missed something with your readings, 25Meg ohms Q531, IC502 28.3 megohms.
    There's probably another FET driver on the board. Since they say some need those replaced I'm thinking this could be the issue but i'd like to see if we can compare the cct to the other drive cct.
    It may not be a loss yet. Don't know why i did not click, 25Meg is very high probably as good as open cct.
    Go to the same IC and transistor set at IC501, Q501 and perform the same resistance checks as done in posts 63 & 65
    There's 5 of those IC on the SS and 5 on the SN.
    IC16501
    IC16502
    IC16521
    IC16522
    IC16684
    We could get multiple comparisons and that should give us a good clue what is normal. I'm hoping all of these come up very close.
    SN
    IC522,Q551
    IC521,Q521
    IC501,Q501
    SS,
    IC131, Q141
    IC132,Q161
    IC151,Q055
    IC152, Q056
  • tw2005
    replied
    buggered or stuffed
    over here we'd say I'm up a creek without a paddle.
    That too, but not drowning.
  • MMH3
    Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
    by MMH3
    i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
    Never ever i experienced problems with that.
    Now i have one 5050sff machine, where this jumper isnt working at all.
    I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
    The history of the machine is that i used it in my office...
    03-23-2025, 09:28 PM
  • DynaxSC
    GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
    by DynaxSC
    I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
    There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
    The board is generally working now, all PCIe ports are working, Windows installs normally.
    However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
    The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
    03-10-2025, 12:27 PM
  • obelix24
    Macbook Air 2020 (a2179) - touch id not working
    by obelix24
    Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
    I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
    02-09-2025, 12:57 PM
  • hopkok
    Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
    by hopkok
    Hi masters, I need your help.
    I am working on Lenovo Legion 16ITHg6
    Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
    INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
    My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
    AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
    Power LED is not working as well, power button working well.
    UI26 ??? is there any firmware too? Powered by +3VALW_AG.
    Motherboard...
    05-04-2025, 09:35 AM
  • bociub
    laptop freezes, usb 2.0 not working, usb 3.0 working
    by bociub
    Hi there,
    It is sunday and I got a faulty hp pavilion 15-cs1006na. No available schematics on the entire world. It flashed 5 long 4 short and no post then I discovered the usb 2.0 2. pin in one of the usb-a socket bent backwards and been shorted to 2. and 3. pin of the 3.0. after removing this short in the port the laptop came alive.
    Now the laptop freezing randomly. The webcam, the built in mic and according to the device manager one more thing not working which are connected to usb. If I connect anything what have usb 2.0 plug that wont work if i plug anything what...
    08-25-2024, 03:44 PM
