14 blinks TC-P50ST30
  • nwflight
    • Aug 2013
    • 56
    I cannot find the exact same symptoms.
    TC-50ST30 manufactured May 2011 six months over one year warranty was watching it and screen just went out. Unplugged and plugged back in red power light comes on but no reaction to remote or anything. holding power button down for 5 seconds then red power light flashes 14 times. Have to unplug to turn off. Have downloaded repair manual but still want to call Panasonic before I touch anything. Could it be as simple as just replacing a fuse? Nearest Panasonic repair is over 200 miles away. Was retirement gift from kids and I am dying without it, found CRT in dump for now.
  • tw2005
    • Oct 2011
    • 6458
    Re: 14 blinks TC-P50ST30
    Personally I'd be taking Panasonic on for an out of warranty repair. I don't know what consumer laws you have there but in 2011 over here they introduced laws which state the item needs to be fit for the purpose and last what would be considered a reasonable amount of time.
    18 months is too short, sadly it seems be a common issue. Over here we have Consumer Affairs to challenge these situations, just depends how much effort people are prepared to put in to fight it.
    Sounds like shorted Vsus at startup, highly likely it won't be a fuse.
    A snip from the 2011 FHD Plasma training guide ST30
    Shutdown but No Blink code - Power LED stays on (Check for Shorted Vsus* / Vda** / P15V).
    2 – 3 – 5 blinks are not used.
    Changes – 2010 models > SC20 disconnected = 6 blinks .
    2011 models > SC20 disconnected = 8 blinks.
    13 blinks -> Internal communication error on A board.
    14 blinks -> Loss of F15V from P bd. P6/pin 10 or A Bd detection.
    Decrease of SOS detect time when SC20 is disconnected (no false det)
    Another snip
    NO BLINK, SOLID RED
    LSI Error
    Shorted Vsus ,Shorted Vda, Shorted P15V
    14 BLINKS
    This code is triggered if there are abnormalities during data exchange with the standby CPU ROM.
    No F15V connected to the A board at plug-in (Open connection of both pins 10 & 11 between P6 and A6) Shorted F15V developed after the TV is up and running. Holding the power switch for over 5 seconds after the unit has gone into shut down and it’s in lock mode with the power LED solid red (Note: the LED stays on if the power button is momentarily pressed).
    • tw2005
      • Oct 2011
      • 6458
      Training Guide
      • nwflight
        • Aug 2013
        • 56
        That is exactly what I have. If you just press the power button the power light stays on and you can hear a relay click. I held it on just to see if it reboots like my dish PVR then the 14 blinks and you have to unplug to turn off. Remote with new batteries does not appear to do anything but turn it on. It went off like the timer said 6 months over warranty and good bye. I will try and see if they will let me trade it in between Sears and Panasonic. Our small town dump has 8 CRT made in the 2000s still working. At 100$ per month plasma may not be in my life. Thank you for the help. and thank ou for the manual , it will be invaluable as I start the road to repair.
        • tw2005
          • Oct 2011
          • 6458
          What, trade it in and buy another TV? I'd try and take them on and get them to fix it for free.
          otherwise it probably only needs a SC board to get it running so the $100/month should drop to $10/month if they keep failing at 18months.
          See how you go first with Panasonic, doubt yours is a rare instance. Read a few posts now and over here it seems SC board issues again with a similar model we have.
          http://www.austech.info/electronics/...u30a-help.html
          • nwflight
            • Aug 2013
            • 56
            Panasonic will not commit to anything untill I bring it to a authorized service center. Closest is 1000km away. Sears might kick in 100$ to repair. So here goes, will try to fix myself and will not buy Panasonic or sears for quite some time. Looking at a Sony led 50 inch. Already spent hours on hold , might as well be trying to fix it.
            Sears guy says no laws in Canada like Australia has but agrees lots of issues with this tv , however when working one of the best.
            • nwflight
              • Aug 2013
              • 56
              From reading this forum itlooks like it is best to start with tv on it's face lying down to pull the back off. Plan is to replace or repair P card as indicated from manual re: trouble shooting.
              • tw2005
                • Oct 2011
                • 6458
                No, don't fall into that trap. Highly unlikely it's PSU, someone just made that very mistake with 14 blink on a P42S30 in this forum, no change.
                First step is if you have a multimeter , measure the resistance at Vsus lines to the SC and SS and see if dead short. TV off .
                If shorted then you'll have to isolate Vsus power to each board (SC , SS) and check at the SC and SS connectors.
                Or , remove the Vsus power lead from the SC, turn the TV on, if the front LED starts flashing like it's starting up and then stops with a different SOS code (other than solid or 14 blinks) that would indicate what was just removed was shorted.
                If no change, reconnect (check there's no residual voltage present), do same for SS
                Could be SC or SS.
                Finding a SC board for this could be the challenge. I do remember reading a post from a guy whose TV was in wty and even Panasonic had none, suggests a lot of failures.
                • nwflight
                  • Aug 2013
                  • 56
                  Have the back off with it on its face but I can change that.
                  The P board is covered with fuses so as an old sawmill electrician thats where I would go but will follow your advice. I have an old darcial movement analog meter but could go to town and find a better one. Home hardware or NAPA is all we have , any sugestions I do not want to blow anything with my meter plus memories of working with mosfets are coming back . I am grounding myself often. Thank you.
                  • tw2005
                    • Oct 2011
                    • 6458
                    usually with the Panasonics, you can have the back off and still work with them sitting on the stand.
                    I usually once I've removed the back , bolt the stand and work with it upright. I'm not familar with your model so may they've changed?
                    if the meter can measure resistance, that's all you need at this point.
                    • tw2005
                      • Oct 2011
                      • 6458
                      I'm going to have to go shortly, just post what you find.
                      • nwflight
                        • Aug 2013
                        • 56
                        Greenlee 210A multimeter 140$, I am into it now for better or worse.
                        shorted SC card. unplug and hit start switch get 7 blinks.
                        Looks like a job to get it out.
                        • nwflight
                          • Aug 2013
                          • 56
                          Does anyone know wht the resistance should be between pin1 ans pin 3 at SC2 . Where vsus enters the SC board.
                          Cannot see anything visual but no resistance twixt pins.
                          • tw2005
                            • Oct 2011
                            • 6458
                            You can see from a few hundred K ohms to M ohms. I assume twixt means between.
                            So you're saying you have dead short on that connector? If so that is the fault.
                            next trick will be to also check the buffer boards for shorts as well and to locate a SC board.
                            Board maybe repairable, had a guy over here who found 3 shorted FETs and got away with replacing just those. generally it's not that simple.
                            Is your SC board, marked TNPA5351 AQ, or TXNSC1PHUU ? looks like I'm wrong about supply, quite a few out there now.
                            http://www.shopjimmy.com/panasonic-t...u-sc-board.htm
                            http://www.ebay.ca/itm/PANASONIC-TXN...item2c71532a18
                            http://www.ebay.com/itm/Panasonic-TX...item3ccaaa2c5f
                            http://www.ebay.com/itm/PANASONIC-TX...item565899ecc5
                            Are the buffer boards TNPA5336,5337 Rev AB ?
                            • nwflight
                              • Aug 2013
                              • 56
                              TNP A5351 DIP A4 . I do not see the AQ
                              nothing visible wrong on board. I have the schematics but are hard to read. Looks like 3 caps to start the circuit but look ok. The manual you posted has one checking a transistor looking discrete device for shorted but in my case that part is ok.
                              I have an 800 number for parts that the Panasonic supervisor gave me when telling me I am on my own 6 months off warranty.
                              ready to check buffer boards when you have the time. That photo is my board exactly.
                              Panasonic parts number in Canada 1-800-663-6060 I have not tried it yet.
                              • nwflight
                                • Aug 2013
                                • 56
                                Sorry for ignorance but what letters would be a buffer board?
                                Found the AQ on the sticker.
                                  SU, SD or SM.
                                  • nwflight
                                    • Aug 2013
                                    • 56
                                    Sc board on its way from shop jimmy. 80$ approx includes 30$shipping.
                                    • nwflight
                                      • Aug 2013
                                      • 56
                                      5336AB, 5337AB Is there a safe way to test these? Helpful guy from shop Jimmy says they often sell all three together.
                                      • nwflight
                                        • Aug 2013
                                        • 56
                                        Thinking about removing components from sc board one at a time until short clears. I see 3 transistors in a row that may have been warm from the looks underneath but the legs do not ground. However the six down the middle of the board all legs are grounded.
                                        Any suggestions of a source for these components.
                                        • Biruslapio
                                          Panasonic P58V11B 8 and 12 blinks error "fix"
                                          by Biruslapio
                                          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                          04-13-2021, 07:13 AM
                                        • Nairolf
                                          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                          by Nairolf
                                          I have a Samsung DM32D display.
                                          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                          Here’s what I have tried so far:
                                          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                          From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                          Today, 03:47 AM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • Taurus12
                                          Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                                          by Taurus12
                                          Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                                          I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                                          i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                                          Any recommendation on what I have to do next? Thanks in advance
                                          06-10-2025, 05:05 PM
                                        • jchon
                                          Sony A1e 5-blinks help
                                          by jchon
                                          Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                                          I found the service manual, which was critical to know where to probe.
                                          https://www.manualslib.com/manual/20...1e-Series.html
                                          With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                                          Unfortunately the 5-blinks...
                                          06-28-2023, 11:52 AM
