vizio E320-A1 not working
  • FPayne4362
    • Apr 2012
    • 6
    • usa
    Re: vizio E320-A1 not working
    The problem is simple its the eeprom that needs replacing. It sends the signals. Check voltage on eeprom
    • splitcrete
      • Dec 2012
      • 387
      • usa
      It looks like U702 was changed before I would test that regulator.
      • crepiduse
        • Nov 2010
        • 69
        Which EEPROM and is this the same as the E320-A0?
        I have a E320-A0 with sound, no picture.
        • phan1978
          • Sep 2016
          • 32
          Hello everyone! I know this thread is old but I have another question. I am having the same issue. The TV will not power on at all. No lights, nothing. I am testing with a volt meter on the rainbow colored set of wires going from the power board to the main board and I am not getting any volts. Any info here would be greatly appreciated.
          • phan1978
            • Sep 2016
            • 32
            see pics of the board that the OP posted on page 1
              There are two vesrions of the power suply board used in the same model TV and they look almost identical, so your board is the EXACT match to the OP for sure?
              See SJ for the exact model you have.
              http://www.shopjimmy.com/catalogsear...=vizio+E320-A1
              Partial part number (CL801UXE3) can be found on a sticker.
              Partial part number (CL801UXE3Q) can be found on a sticker.
              We are going to troubleshoot using the pictures, so the correct pictures are VERY IMPORTANT!.
              BTW, the main AC fuse is good, and you are getting 160VDC or so between the two legs of the main filter cap?
              • phan1978
                • Sep 2016
                • 32
                Here are two pics.
                • phan1978
                  • Sep 2016
                  • 32
                  Board is CL801UXE4
                  getting about 63 volts on the fuse
                    OK, your board per sticker is 'CL801UXE4'
                    Vizio / Insignia ADTVCL801UXE4 Power Supply Unit
                    http://www.shopjimmy.com/vizio-insig...upply-unit.htm
                    Pictures provided by shopjimmy.
                    Board is $25. So what do you want to do?
                    • phan1978
                      • Sep 2016
                      • 32
                      well, I want to make sure that is the problem because I have been seeing the same symptoms and the issue was a bad EEPROM
                        Originally posted by phan1978
                        Board is CL801UXE4
                        What did you use for GND for the meter?
                        When checking in coming AC to the board, you have to measure between LINE and Neutral.
                        DCV measurement in the primary side circuit, you will use the negative leg of the main filter cap as the GND ref. for the meter.
                        So what DCV do you have MEASURED between the two legs of the main filter cap?
                          But you have to have at least Standby Voltage to run the main board first, so you have at least one problem dues to dead power supply which you need to get it running first then you can find out what other problem you may have beside the power supply board.
                          What is the history of this TV?
                          Bad EEPROM will not cause the power supply not to put out ANY Voltages.
                          • phan1978
                            • Sep 2016
                            • 32
                            Your last post may be a touch over my head. I have the dial on 200V (wavy line over the V). I touch the black to the GND on the 13 pin rainbow wires and I touch the red on the metal of the fuse holder.
                            • phan1978
                              • Sep 2016
                              • 32
                              got 74 volts this time
                              • phan1978
                                • Sep 2016
                                • 32
                                tv history. my friend had it for 3 months and one day it just wouldn't cut on. he just gave it to me to look at it. I am now getting around to it. He said he didn't notice a storm or surge around the time it stopped working
                                  You CANNOT use the COLD SIDE GND or Chassis GND as the ref for the meter when measuring the incoming AC, you have to measure between Neutral and at one end of the fuses at a time.
                                  Why don't you just check the DCV between the two legs of the main filter cap?
                                  BTW, do not touch anything on the HOT side of the board or you may get killed.
                                    BTW, do you have correct tools to do component level repair, especially for the SMD parts?
                                    • phan1978
                                      • Sep 2016
                                      • 32
                                      Is that the long black horizontal capacitor left of where the plug goes?
                                      • phan1978
                                        • Sep 2016
                                        • 32
                                        I have a soldering iron, solder and copper thread.
                                          C9810 is the main filter cap.
                                          https://www.badcaps.net/forum/attach...2&d=1472951354
                                          • mrtek
                                            Vizio M65-C1
                                            by mrtek
                                            Hi.
                                            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                            07-14-2025, 07:28 PM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
                                          • MisterAIL
                                            PS5 digital / No Power / No Beep / Good power supply
                                            by MisterAIL
                                            Brought a non functionnal PS5. Apparently only a bad PSU...
                                            No beep, nothing.
                                            After some tests i found this :
                                            - PSU is fine (12 volts stable)
                                            - 12 volts line is shorted
                                            - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                            - By the way, nothing change. No signal, no power, no beep.
                                            Mesuring all rails with my workbench psu (12 volts input)
                                            - 0.00 amp drawing
                                            - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                            03-12-2024, 03:24 PM
                                          • Mcfeetroy
                                            Fishing bite alarm drains battery
                                            by Mcfeetroy
                                            Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                                            08-01-2025, 03:52 AM
