Problems After SC Board Replacement - Panasonic G20
  • sun130
    • Nov 2013
    • 10
    Re: Problems After SC Board Replacement - Panasonic G20
    Hi Tom.....While I digest all this new info, in terms of your test video, I need to check for shorts on my buffer boards so that they dont damage the newly purchased SC board. At this stage I'm not concentrating on what is wrong, if anything, with them.......Where would I put the probe on the TNPA5090 , which pin/s of the SC41,46 or 42?......I realise that even if I dont get a short, there may be other faults but nothing that will knock out the SC board I assume, or am I wrong (again)?.....
    thanks
    • sun130
      • Nov 2013
      • 10
      Hi guys......well I received my SC board TNPA5081 AY, an exact replacement for mine. Fitted it and did the check with the SC50 jumper in place, continuous green light, fans turning, looking good. I was still apprehensive about the buffers and did the checks for shorting but was still not convinced properly. Hayho, as someone on here once said, what have I got to lose......THE SC BOARD !!!.....switched on and she is waiting for a signal....A Result !!!!
      One minor observation, in the left hand bottom section of the screen is one broken vertical line about three inches long of green flicker..can only be one pixel width..(is that the right measurement)....I bet when I have a full picture it will probaby not be noticeable. Is this a bad ribbon seating on the C2 board?....any ideas?
      Thanks for the help, honestly........
      • dj01fad
        • Sep 2014
        • 92
        • romania
        Hello
        I know it is a 1,5 years old topic, but I am curious, how did you solved the problem? I was in the same situation; SC board broken, and replaced with one from a broken tv... after the replacement i had the same purple snow and altered white, and some horizontal bars, but not always. Big surprise... after disconnecting the screen ribbons and the connectors between the boards (sc-su-sd), and reconnecting them, the problem disappeared...
          by sam_sam_sam
          After all of...
          07-13-2024, 08:14 PM
        • canadaboy25
          Panasonic TC-P54VT25 No image. A or D board?
          by canadaboy25
          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
          The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
          01-17-2021, 01:06 AM
        • boosti45
          Macbook pro logic board replacement parts quesion
          by boosti45
          i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
          08-21-2024, 05:23 AM
        • Cvrado
          Led TV Board Replacement, same part number and model, different size
          by Cvrado
          Hello my friends!
          I have a question that I think you can answer and help me with!
          I have a faulty main board from an led TV. And I found the same part number board and design but is from a 43" TV and I want to use it on a 65". On its stickers , all are the same except the wattage for the LEDs backlight, both state different watts and LED Voltages!
          So I presume that the backlight inverter section from the replacement board has lower wattage then the original one, am I right?
          My concern is that the board won't draw enough voltage to the bac...
          03-02-2024, 05:05 PM
