Hi, I am new to these forums, I have repaired several tv's , Just wanted to see if I could get some help on this one. The powerboard (and other boards) have no visible bad caps. Power seems ok at any marked voltage points on the power board. The inverter visibly looks ok too. When power is pressed the green light comes on, flashes 15 times, then back to red. I was thinking the problem is possibly the inverted since the screen just flashes very briefly then off like a second later. but If I unplug the inverter from the circuit, the TV still flashes green 15 times green then off. does this mean its not the inverter, or the tv is going into protection mode again without it?
And insight or help I would so much appreciate. I can post any pictures if need be. Thanks, Roger
