Emerson lc407em1 Turns on screen only flashes, then off
  • proaudiosoft
    • Apr 2012
    • 68
    Hi, I am new to these forums, I have repaired several tv's , Just wanted to see if I could get some help on this one. The powerboard (and other boards) have no visible bad caps. Power seems ok at any marked voltage points on the power board. The inverter visibly looks ok too. When power is pressed the green light comes on, flashes 15 times, then back to red. I was thinking the problem is possibly the inverted since the screen just flashes very briefly then off like a second later. but If I unplug the inverter from the circuit, the TV still flashes green 15 times green then off. does this mean its not the inverter, or the tv is going into protection mode again without it?
    And insight or help I would so much appreciate. I can post any pictures if need be. Thanks, Roger
    Re: Emerson lc407em1 Turns on screen only flashes, then off
    The inverter board doesn't feed back an error signal to the main board on most TVs (I only know of Sony and Panasonic LCDs that do this), so you may be looking more at a power supply or main board fault. In order to tell you more, we will need pictures of the chassis layout.
    • proaudiosoft
      • Apr 2012
      • 68
      ok, thanks tom. I am off tommorow and will def post some pics. definately so appreciate it
      • proaudiosoft
        • Apr 2012
        • 68
        Here are a few pics of the layout.... Thanks
          Oh dear. This is not a very well made TV.
          Do you have a digital multimeter?
          If you don't: Beg, borrow or buy one, you will need it to test things.
          If you do: On the left hand side of this picture is the inverter board. Turn the TV on. Place your black multimeter probe on the chassis. Set meter to 200VDC and make sure red probe in VOLT, black probe in COM. Then look at the connector on the power supply whcih goes to the inverter. Probe each pin starting from the red ones, numbering as you go up. Tell us what your meter reads.
          Note -- Do not touch any part of the power supply while the unit is plugged in or shortly after power off.
          • proaudiosoft
            • Apr 2012
            • 68
            Yes I have an volt/ohm meter, esr meter and other testing equip. I just noticed D1208 is missing off the power board. the fuse was missing to when I received this tv so, looks like someone else was working on it. Also the board looks like D1208 burnt. I am going to order a new diode. I remember reading that exact diode beeing faulty on another with the same model as mine. could be the culprit for sure. I read that last night, I believe you gave input on that nicely Any advise on anything else I should check before replacing the diode? Thanks tom..... Roger
            Oh, the inverter I tested that connector last night. Oh, I will check the inverter again and let you know too. It look like the voltages were good last night, from what I could read on the power board at the connector pins anyway
              I would inspect that power supply board real close at the bottom side to see if any works are done to it, check those diodes in circle. That large 450VDC cap should have 160VDC on standdby, about 380V when powered on.
              Also report the voltage readings on that white multi-pin connector on the top right of the power supply board that goes to the other board, there are labels by the pins of the connector.
              • proaudiosoft
                • Apr 2012
                • 68
                I dont see anything else messed with in the power supply but the one zener diode removed. The diodes you circled I just checked again, they seem ok (.400 to .950 and open the other direction, no shorts).
                The pin connector readings are as follows:
                tuner+35v = 41v
                lcd + 12v = 12v
                lcd + 12v = 12v
                power on + 3.5v = 3.5v
                power on + for tv 6.5v = 9v
                power on + 3.5v for reg = 5.5v
                24v for amp = 27v
                The Large Cap you told me to test is 38v standby 11v on (tested on jumper near it). The D1208 diode seems to be missing like I said, I ordered it, but I do recall someone in another thread on a similar tv with the same PS telling them they are better off leaving it out.
                Any help continuing appreciated much
                  "The Large Cap you told me to test is 38v standby 11v on" That cannot be right. Is the meter in DC? The Negative leg of that cap the primary side ground ref for the primary circuit , you cannot use the chassis ground as the ref.
                  • proaudiosoft
                    • Apr 2012
                    • 68
                    Meter in AC. I was using the TV chassis as ground though. Using the line in ground as ground I get 6.5 in standby, and 60v with power on. Is this ground ok?
                      No, you need to get to the trace that is connected to the negative leg of that cap, you cannot use the chassis for the ground ref point since that cap is in the primary side (deadly side, so DO NOT TOUCH anything in the hot section).
                      Chassis is the ground ref point for the cold side of the circuits.
                      Meter set to DC.
                      • proaudiosoft
                        • Apr 2012
                        • 68
                        Meter set to DC.
                        Of course. I have 5v stby, and 347 on
                        • proaudiosoft
                          • Apr 2012
                          • 68
                          Anything?
                          • proaudiosoft
                            • Apr 2012
                            • 68
                            received diode today. gonna install and post results ...
                            • proaudiosoft
                              • Apr 2012
                              • 68
                              no change after installing diode. turn on, green light flashes 15 times, then powers off to red light. screen flashes on then off after around the 13th green light flash. I did notice if I disconnect the inverter the green light will flash 19 times, then steady on for a sec or two, then back to red light. is it possible the inverter is the problem, and the tv turns off without it?
                                We will have to locate the diagram next, unless someone in the forum had fixed this same board before.
                                • proaudiosoft
                                  • Apr 2012
                                  • 68
                                  here are a couple...
                                    OK, I have seen this circuit before:
                                    https://www.badcaps.net/forum/showth...erson+lc407em1
                                      I look at the diagram, so far your 5v and PFC Voltage booster (345V) are working. I need to read the manual to figure out the flashing LED codes. The circuit has sensing PROTECT1, PROTECT3, cannot find PROTECT2 yet, need to find out if one of them is bad or not.
                                        If you get the FUNAI part number for this board (begins with BA9) I may be able to find a schematic, if you don't already have one.
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
                                        • frannyjunk
                                          Hisense 40H4F no backlight but turns off after splash screen
                                          by frannyjunk
                                          So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
                                          TIA.
                                          09-24-2025, 10:59 AM
                                        • JunkmanJimbo
                                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                                          by JunkmanJimbo
                                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                                          No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                                          Please help. Thanks in advance!
                                          08-12-2025, 11:45 AM
                                        • Rav_tangle
                                          MacBook Pro 2011 turns on with keyboard light , screen dead
                                          by Rav_tangle
                                          Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
                                          I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
                                          Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
                                          is this...
                                          05-31-2024, 04:09 PM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
