bn4400261b or main board fault
  • is_it_a_bird
    • Feb 2013
    • 59
    • United Kingdom
    HI
    I have a Samsung LE32b530 and it is not coming out of standby.
    Downloaded the schema from another forum post(thanks Tom) and checked all the likely suspects ie fets fuses cold joints, all ok
    If I power up the tv with the main disconnected I get
    on/off = 1.51v
    inv on/off = 2.09v
    As soon as I plug the main board back in both these voltages go to zero
    The 5.3 pin stays constant with main plugged in or out at 5.24v
    Any ideas, could this be a main or a psu/inverter fault
    I dont get a backlight flash either with main connected/disconnected
    Thanks for any help
  • truep
    • Aug 2010
    • 373
    Re: bn4400261b or main board fault
    With it plugged in, check the PS on pin on the power supply.
    First with the power off, and then with it on.
    • is_it_a_bird
      • Feb 2013
      • 59
      • United Kingdom
      0v with main board connected 1.51v disconnected
      I should add that the standby light is solid and not doing anything when pressing side buttons, if I remember rightly when you plug samsungs in the standby light starts flashing, but I may be wrong
        Sounds like main board fault, first place to check would be voltage regulators and core supplies.
        • is_it_a_bird
          • Feb 2013
          • 59
          • United Kingdom
          Cheers Tom, just one worry, when you disconnect the main from the ps/inverter shouldnt the backlights do their two seconds and shut down??
          If so they dont :o(
            Depends on the design, some Samsung are different.
            • is_it_a_bird
              • Feb 2013
              • 59
              • United Kingdom
              Right OK, will have a look at the main tomorrow, thanks for all your help :o)
              • is_it_a_bird
                • Feb 2013
                • 59
                • United Kingdom
                Hi
                Just plugged the TV in and it is now responding to the side buttons and remote, so I did a master reset
                "press exit for 12 seconds"
                "press "left""
                "Press Enter"
                Now I have done the reset that bloody annoying turn on sound has come back, and I can see OSD but not a blink from the backlights not even the flash and shut down.
                Any pointers please
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  Do you now get voltages on the on/off pins of the inverter?
                  A working TV? How boring!
                  • is_it_a_bird
                    • Feb 2013
                    • 59
                    • United Kingdom
                    I am getting a steady 4.45v
                      Any pictures of your boards?
                      • pkunzip123
                        • Feb 2012
                        • birmingham
                        I have a samsung le32b530p, when powered on i have no backlight with faint display, if i disconnect the mainboard, the backlight runs but of course there is no display because mainboard is disconnected
                        Please help, i have some knowledge of lcd tv's, and can use a multimeter, any help is much appreciated
                        • selldoor
                          Slow Learner
                          • 7870
                          Did you read the post just above yours?
                          • Dani_2024
                            by Dani_2024
                            10-28-2024, 05:06 PM
                          • ygorsan
                            by ygorsan
                            🧩 Problem Summary:
                            • I
                            07-28-2025, 08:34 AM
                          • JDC
                            (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                            by JDC
                            ONN 100012588
                            Issue: No Power, Then Rebooting After Main Board Change
                            Short answer: replace main board and power board
                            Technical answer: replace main board and Q306 & Q307 on power board.
                            Long answer:
                            TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                            07-15-2022, 07:39 AM
                          • cheeky2
                            by cheeky2
                            05-25-2024, 03:27 AM
                          • mrautom8
                            Samsung TV UN75H6350AFXZC main board schematics?
                            by mrautom8
                            Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                            Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                            While relay is on, all voltage rails are present and steady (scoped) on main board.
                            I love a good logic puzzle but getting lost without any schematics.
                            No shorts on ANY capacitor main board.
                            Thermal camera shows 3.3V inductor getting warm instantly but...
                            10-19-2025, 06:32 PM
