Hello
Re Technika - inexpensive non working 19inch dvd tv lcd combo ( I believe it is made by Vestel)
I have a flat screen tv and thought that I would have an attempt at fixing it
Symptoms - no life whatsoever except for the standby light which went from red to green when the power button is operated
My naive diagnosis was that it must be the power supply,,, therefore rushed out and ordered set of capacitors ( all 4 of the output ones) 3 had been replaced a couple of years ago - but bought all 4 plus there are two on the inverter board and one of those appeared to be bulging slightly so bought those as well
First repair attempt was to replace all those capacitors, 6 in total ...... result no more signs of life than before
So next checked output from power supply.....4 outlets 12v and 4 gnd I get 12v from each of these terminals ,(this may have been the case before replacing the caps as I did not check) there are no 5v outputs from the PSU board
I have discovered that there is 5v on the main board on some of the outlets
I have tried inserting a DVD disc into the player on the set – but no activity whatsoever
There does not appear to be image – however dark – on the screen, and no hum or anything from the speakers
The only sign of life is that the neon on the front goes from red to green when the power button is pressed
(I do not have the remote for this set at the moment)
Any suggestions or help would be greatly appreciated as it becoming a bit of an obsession!
Thank you in advance
19" LCD TV RECIEVER
Model x19/18 TCD-UK
Model Ref Technika LCD 19 DVDID-208
Model TEC-X19S18Z99G-848
Power 100-240 50/60Hz 40w/1w
power supply FLYPW1-205B
INVERTER FLY-IV190415
MAIN (LTM190M2-L31 XW08010002) B TD707C 7462
The MAIN part number breaks down to LTM190M2-L31 - this is a Samsung LCD
The B TD707C 7462 refers to the AV board made by Swisstec -
19" LCD TV RECIEVER
Model x19/18 TCD-UK
