37" Vizio VX37L Keeps Turning off
  • tieny
    • Feb 2012
    • 478
    I have a 37" vizio VX37L that keeps turning itself off when I turn it on.
    So plugged in, with vizio amber light in front, I press the power button, amber light turns white and the tv turns on. About 3 seconds laters the TV turns off and the vizio led in front goes back to amber.
    I'm measuring 4.63V on the PS_ON, when it turns on.
    I'll post up photos of the main board, and info on the regulators in a bit.
  • tieny
    • Feb 2012
    • 478
    Re: 37" Vizio VX37L Keeps Turning off
    So I found a total of 13 regulators on the main board.
    U6
    GI8L 17-33L
    0v 3.29v 5.21v
    U4
    GI8L 17-33L
    0v 3.31v 5.21v
    U8
    GI8L 17-33L
    0v 3.29v 5.21v
    U9
    GH3L 17-18L
    0v 1.82v 3.29v
    U10
    GH3L 17-18L
    0v 1.82v 3.29v
    U5
    AMC1117
    0.70v 1.95v 3.31v
    U16
    GF2L 17-25L
    0v 2.53v 5.20v
    U7
    GH3L 17-18L
    0v 1.81v 3.29v
    U18
    AMC1117
    0.25v 1.50v 3.29v
    DU4
    AMC1117
    0v 0.13v 1.04v
    DU1
    7805CT
    0.67v 0v 0v
    DU3
    GF2L 17-25L
    0v 0v 0.44v
    DU2
    GJ8L 17-33L
    0v 0.39V 0.43V
    How do those readings look?
    Also I'm getting 4.63V for PS_ON, is that high? Isn't it suppose to be 3.3v? If it is, would the main board or power supply be causing it?
      Are those voltages tested with the TV is turn on or in standby mode?
      "DU4
      AMC1117
      0v 0.13v 1.04v
      DU1
      7805CT
      0.67v 0v 0v
      DU3
      GF2L 17-25L
      0v 0v 0.44v
      DU2
      GJ8L 17-33L
      0v 0.39V 0.43V"
      These do not look right if the TV is ON.
      PS_ON =>3V
      • tieny
        • Feb 2012
        • 478
        Those readings are during standby.
        With the TV turned on the readings are:
        DU4
        AMC1117
        0v 1.26v 3.36v
        DU1
        7805CT
        12.06v 0v 5.05v
        DU3
        GF2L 17-25L
        0v 2.51v 5.10v
        DU2
        GJ8L 17-33L
        0v 3.30V 5.10V
        • tieny
          • Feb 2012
          • 478
          I think those readings are good.... I don't know anything about DU1, 7805CT but I'm going with my gut feeling that its not the problem... ugh another unsolvable one..
          I've been searching on google for a similar problem and found this
          http://www.justanswer.com/tv-repair/...ue-screen.html
          Its stating that this problem is caused by a bad LCD panel?? Is that even accurate at all?
            It is just the 5V regulator. So the voltage readings when TV is ON are also OK.
              Disconnect the side button board if possible and see if it still turns off.
              • tieny
                • Feb 2012
                • 478
                I disconnected the side button board and turned on the tv with the remote but the tv is still turning off.
                • tieny
                  • Feb 2012
                  • 478
                  I noticed a blue LED diode on one of the inverter board that lights up bright and slowly fades off when the TV turns on. I've never seen this before, is it possibly indicating a problem with the inverter board, or a possibly a bad ccfl lamp? That would explain the reason for assuming a bad lcd panel from the link i put in post #5.
                  • tieny
                    • Feb 2012
                    • 478
                    Dissassembled everything, checked CCFLs and they all seem good and working...
                    The problem again with this TV:
                    TV powers on fine, shows a blue screen with the no signal message, and then shuts off. While the TV is on, I cannot get the OSD menu open or change any inputs on the tv or with the remote. It just only says "No Signal" (With this fact I'll assume a bad main board...?)
                    The guy I got it from said itll only stay on if theres a source hooked on it and itll shut off to save power if theres no input. (I thought that was just BS) but he hooked on the hdmi and actually got it to play a picture, so i bought it.
                    So I tried hooking on both hdmi inputs but the tv won't even stay on. I have no idea what the hell the guy did...
                    But if this is in fact a bad lcd panel like "justanswers" stated then I guess itll going to be recycled, unless anyone else has an idea.
                      It does sound like bad main board if you cannot control it with the remote or buttons.
                      • tieny
                        • Feb 2012
                        • 478
                        Bleh, main board problems...
                        Guess this one is a bust.
                        So I'm parting this one out on ebay. Even the main board, maybe someone else can get it and fix it for cheaper. If anyone needs any parts from a Vizio VX37L just let me know.
                        • tieny
                          • Feb 2012
                          • 478
                          I just found the problem.
                          It seems with these vizio tv's whenever its on the RGB input, it will shut off when there is no signal input for it. Took me buying another main board to figure this out...
                          I found out that it will take about 15 seconds until the OSD menu and input menu will be accessible. However since it was on the RGB input it would shut off before the 15 seconds and thus i wasnt able to change the input at all. So I hooked on my laptop allowing the TV to stay on waited until i can open the menu and then was able to change the input. So about 15 seconds after the TV is turned on it will work perfectly, opening and closing the menus.
                          Using the new main board as soon as I turn on the TV I can access the menu immediately so this the main board is definitely at fault. I don't know the exact component causing the fault but at least the TV is perfectly usable with the old main board.
                            Oh but I thought you have no control at all from remote or buttons, and also does not work with HDMI source when you tried it:
                            "but he hooked on the hdmi and actually got it to play a picture, so i bought it. So I tried hooking on both hdmi inputs but the tv won't even stay on. I have no idea what the hell the guy did"
                            Live and learn.
                            • tieny
                              • Feb 2012
                              • 478
                              Thats true I didn't have any control at all from remote or button. It was only until the TV "warms up" after it turns on. But since it was initially on RGB it would always shut off before "warming up." and I wasn't able to switch to any other inputs. Thus the problem where itll be stuck with this loop...
                              I'm still not sure what the previous owner did. I swore I saw that hdmi cable, or maybe I was crazy and it was actually VGA. O.o
                              • litenan
                                • Sep 2013
                                Thanks tieny, I was having the same shutdown problem with my vizio, was thinking on just trashing it. I had let someone borrow it for a few months and when I got it back it was doing just what you described. She must have hit the rgb button on the remote and figured it was broke. Anyway thank you, thank you, thank you fer that tip.
                                • dymondgirl
                                  • Jul 2014
                                  • US
                                  Thanks tieny. I'm having the same exact issue...my daughter kept trying to change the input to get the dvd player to work and in the process, must have hit the rgb button. I can't get the tv to stay on long enough to get to the menu to change the input. How exactly did you do it by connecting to the laptop/computer?
                                    • 31020
                                    i think RGB is an error by the guy who posted it.
                                    i think it's refering to the VGA connector.
                                    • dymondgirl
                                      • Jul 2014
                                      • US
                                      stj - thanks. connected a VGA connector from tv to the laptop and it allowed me to get to the input menu and change. this worked - tv back on!
                                      • rustytierod
                                        • Sep 2014
                                        • 81
                                        Can anybody tell be the spec for C223 on the slave board?
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • pedromvu
                                          Vizio M65-E0 not turning on
                                          by pedromvu
                                          Hi, I know these TVs are common to have problems like this, but unfortunately I was not able to find repair guide for this specific model or for something with this kind of power board.
                                          The thing is this doesn't have the 5vsb pin which is used to determine from which board the issue comes.
                                          Everything in power and main board was inspected without any apparent problems, but haven't measured everything.
                                          The voltages from Power to Main board are as follows:
                                          NC = 0
                                          A = 0
                                          BL_on/off = (Some millivolts, probably considered 0)...
                                          11-18-2022, 12:28 PM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                        • howardc64
                                          Vizio SmartCast TV software bug that looks like hardware
                                          by howardc64
                                          Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                                          It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                                          11-16-2024, 05:17 PM
